#1 |
Cheesecake Nom Nom
renaming slots V7, HFM
does anyone fold smp and gpu with V7 and use HFM for remote viewing?
because when you add the V7 client to HFM the name for the cpu and gpu is the same and you dont get the option to change it.. i.e if you look at my folding summary i have i7 920 slot 0 and slot 1... one is the cpu and one is the gpu but you cant change the name of just the gpu?
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, GTX680 OC'd Last edited by kirk46; 31st Jul 2012 at 10:00. |
#2 |
Supermodder
I dont think there is a way.
I just name my slot CPU and GPU. Click on my summary below to see what I did.
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. Last edited by Scorpuk; 31st Jul 2012 at 10:34. Reason: Well I did until I reinstalled. :-) |
| Thread Tools | |
