#1 |
Minimodder
Project- "The White Knight Z9" Finished-05/23/13
Hi, this is my first post on bit-tech forum.
At first, I'd like to introduce myself. ![]() 16 year old schoolboy from Slatina in Croatia. My name doesn't matter. I'm really interested in modding, and that other stuff. ![]() I apologize for my bad english in advance. List of components: MBO: Msi Z77A-G43 CPU: Intel Core i5-3570K RAM: Corsair Vengeance blue 1600MHz GPU: Sapphire 7850 2gb- DUAL-X cooler HDD: WD Black 500gb SSD: OCZ Agility 3 60gb PSU: XFX PRO 550w Now, let me introduce my project. 16th of October 2011 I bought a Zalman Z9 case. And shortly after that I already started with various modding. 1. I painted front panel, top, and mesh on the left panel. 2. Bought Silverstone Aero Slots, and paint it in white. 3. Bought SMD LED strip on eBay and mounted it up above my keyboard. 4. Made some cheap water cooling 5. Bought a new sound card(Asus Xonar DG) 6. Painted i/o shield in white. 7. Cuted 5.25" bay into 3.5" that I can put 2 3.5" fan controlers. 8. Put the new switch, because original one died. 9. Got the fans from eBay. 10. Got the thermometers from eBay, and mounted it on 5.25" bay. 11. My friend professionaly painted front and top panel. 12. Got the LED strips for case. 13. Made some small reservoir so I can push the air bubbles out. 14. Bought SSD(OCZ Agility 3 60gb) 15. Bought the real radiator(250mm*150mm) 16. Painted pci slots of graphics and sound card, in white of course. 17. Made better reservoir and bought tubing. 18. Made psu shroud, and cover for radiator of plexiglass. 19. Got some blue sleeve while I wait MDPC-X sleeve, and sleeved 8 pin cable. 20. Got Corsair SSD adapter, paint it. 21. Painted coolant. Now let's put some pictures. Sorry about quality(iphone) my fault for that white lines, used shitty paper. ![]() switch for LED's big box for SSD mounted it on back side beast small difference 3m 1$ filling some pictures with new tubing can't see laser on pictures ![]() everything cutted like it? painted blades my favourite pic after sanding, corsair logo is missing. white matte first coat second coat finish finish ssd mounted now pictures with camera ![]() ![]() ![]() ![]() ![]() ![]() Here's the video of painting coolant. Noise is made by graphics card. http://www.youtube.com/watch?v=thLQrvOqq8c&hd=1 Last edited by dombak1608; Today at 08:46. Reason: Update |
#2 |
What's a Dremel?
Nice work dude
#3 |
Multimodder
Interesting idea! I also have Zalman Z9, but it still black. Why you use so huge power button? Are you dislike the stock button?
__________________
sorry for my English |
#4 | |
Minimodder
Thanks mate, I hope so.
![]() Quote:
#5 | |
MODfiend.. ~twitch~
__________________
Ω Omega Desk Ω |
#7 |
Minimodder
fino si ti to odradio
svaka cast |
#8 |
What's a Dremel?
#9 |
Fenrir The Wolf
Nice to see your project log on Bit-tech.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#10 |
MD of Mutant Zombie Armies Inc
i've admired the Z9 for a long time and almost got one a while back. Seeing this almost makes me wish i had. really nice work mate. i LOVE the ghetto reservoirs
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#11 |
Minimodder
New hardware, 24pin extension.
Thank you all for your comments.
I bought a new hardware. MBO: MSI Z77A-G43 CPU: Intel Core i5-3570K RAM: Corsair Vengeance blue 1600MHz 8gb(2x4gb) And placed it to case. ![]() Case without hardware ![]() Hardware ![]() CPU and beast of cooler ![]() I love it! ![]() ![]() Much better ![]() Mounted hardware ![]() ![]() Working ![]() ![]() ![]() ![]() 24pin extension Plans for the future: 1. Wait for the MDPC-X black sleeve, and heatshrink 2. Wait for the ATX remover tool 3. Sleeve the cables 4. Extend the cables of fans on the top 5. Buy the switch 6. Save some money And plans for the far future(next year): 1. Buy new PSU 2. Buy a new graphics card 3. Buy the blocks for graphics card, and CPU. I hope that I will make a new update soon. ![]() Cya
Last edited by dombak1608; 9th Aug 2012 at 21:17. Reason: Forgot to add something |
#12 |
Would you like a fishie stick?
Looks really good, keep up the work!!!
__________________
Fractal Design DEFINE R4, 3 Noctua NH-D14, Intel Core i7 3770k, Phanteks PH-TC14-PE, Asus P8Z77-V Deluxe, 2 Nvidia GTX 670, Asus Xonar D1, Seasonic X-Series 1K, 2x8GB gskill 2133mhz, 3TB barracuda, 256 OCZ Vertex 4 |
#13 |
Minimodder
New PSU, fans.
Update my modding friends!
I bought a new PSU and 2 fans on sale. PSU: XFX PRO550W Fans: Arctic Cooling F12 TC And I also painted the waterblock holder, left side panel, and PCI brackets(again-because first time I wasn't happy with my work ).Some pictures: ![]() ![]() ![]() ![]() ![]() sanding the brackets ![]() ![]() finished ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I don't know what to do with cables. ![]() Does somebody knows how can I turn off the temperature sensor on this f12 tc fans? Last edited by dombak1608; 21st Aug 2012 at 21:10. Reason: Forgot to add some pictures |
#14 |
What's a Dremel?
Very nice work you've done. so far. I have to admit, I don't think I would be brave enough to make my own reservoir like you initially did, but I like where the whole thing is going.
#15 | |
Minimodder
BTW. I'm planing to paint the copper parts on radiator and reservoir. |
#16 |
What's a Dremel?
I just worry a bit about not fully sealed containers of liquid that close to some very expensive parts. Though I'm sure it is perfectly safe, as long as no one is shaking your case around or anything drastic like that.
#17 |
Minimodder
Painting copper parts
Hey, ho!
I painted copper on radiator in matte black. Also I figured that I can't put the second fan on left side panel because of psu shroud. So now I can put only one fan on it. Photos: ![]() ![]() ![]() ![]() ![]() ![]() ![]() I don't have any pic while I painted that copper parts
#18 |
Minimodder
Well done, nice build , I suggest you to consider for your next GPU upgrade the KFA2 graphic cards with white PCB, there are already a few KFA2 graphic cards made with white PCB, for the PSU the PC Power&Cooling is releasing also white painted PSU
http://www.ninjalane.com/newspost5297.aspx |
#19 |
Minimodder
Big update 29-Sept-12
Hi,
Time to make a new update! I didn't have time to make an update. These days I was busy with some small project on brother in law's attic. We put white LED strip on edge of the billiard table. Here is a video of it (I know that it isn't a case mod): http://www.youtube.com/watch?v=qWu67WVbeOc I got my 19mm blue ring switch from ebay ![]() Shortly after that I welded what I needed ![]() Ring looks great ![]() Now it's time to use dremel ![]() How it looks mounted ![]() ![]() But, there's a problem ![]() I can't put front side on case Now it's time to use "real" tools ![]() To get this ![]() And final look ![]() ![]() When I finished with the switch I modded my MX518 a little. First, take it apart ![]() Then sanding ![]() And painting ![]() ![]() Final look ![]() After that I got my new GPU Sapphire 7850 2gb with DUAL-X cooler Package ![]() Unwrapped ![]() Box in the box ![]() Small things ![]() Sticker which I won't use ![]() The GPU ![]() Blue PCB ![]() ![]() Compare to 9600GSO ![]() 9600GSO is a bit longer ![]() Looking good ![]() ![]() ![]() I won't buy water block for GPU(maybe in far future). As I bought 5m of White LED strip for the billiard table, 80cm were excess. I mounted it on the back of my screen. ![]() And how it looks ![]() I'm satisfied! ![]() Now my plans are: 1. Sleeve the extension (I bought MDPC-X sleeve on Croatian forum from some guy, and He cheated me and few more people, We didn't get our money, and Sleeve- Life lesson )- I have blue sleeve, and I ordered Black heatshrink on ebay.2. Order black sleeve, and sleeve some random cables in case. (When I get some money) 3. Engrave the logo on plexi 4. Buy better CPU water block (When I get some money) 5. Maybe make a plexi backplate for GPU As You Can see, money is mine biggest problem. Thank you for reading all this. ![]() See ya in next update!
#20 |
life is wonderful
my first case was too with automobile ovens but I did to castes and to me it was simpler than them to place
in branch pipes it is possible to cut a carving for a fitting looks more beautifully for confidence from above still to miss the mark with silicone |
| Thread Tools | |
| View Mode | |
