Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 3rd Aug 2012, 05:28   #1
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
Why is this laptop overheating?
i received this gateway w340ui from a friend some time ago because it started acting up on her. she had already replaced it with another laptop so i stuck it in the corner and didnt mess with it for a long time.
lately ive been trying to get it working and its been fighting me but i may have it tracked down to a cooling issue. ive tested the RAM with memtest overnight with no errors, and the CPU fan cycles like normal (it doesnt run full blast constantly, indicating overheating) so i dont think its the ram or the cpu that are overheating. everything but the CPU is passively cooled and i have the motherboard out and laying on the desk in the open so i wouldnt think cooling would be an issue, but i wasnt able to get it to run long enough to install windows until i pointed a large desk fan at the motherboard and shut the computer down to cool every time windows installer wanted to reboot the system.
ive been feeling the chips on the board and the only one that even gets slightly warm is the GPU, which does not have a heat sink. i need to install drivers before i can run any stress tests on it to see if it piles up under load but it seems odd to me that any of the passively cooled chips would be overheating with the board laying out in the open like it is?
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i7-870 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|AMD 7970GHz Edition|2x Barracuda 1TB RAID 1
Wicked_Sludge is offline   Reply With Quote
Old 3rd Aug 2012, 05:56   #2
dancingbear84
error 404
dancingbear84's Avatar
dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.
Why do you think it is a cooling issue? Have you checked the hdd for errors or bad sectors? Have you cleaned the exhaust vent of the cpu cooler. In my experience the gap between the heat sink and fan can get filled with a "blanket" of fluff a couple of mil thick.
__________________
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is offline   Reply With Quote
Old 3rd Aug 2012, 06:04   #3
Wicked_Sludge
as i said, i believe its a cooling issue because the system would not stay stable enough to even install windows until i pointed a desk fan at it and shut it down to cool periodically during install.
i did scan the HDD (its clean) as well as trying a second drive which produced a similar failure. i have reseated the cooler twice using AC5. the cooler and board are immaculate.
__________________
My Rig:
Old 3rd Aug 2012, 09:06   #4
Xahl
Your mum's a Dremel
Xahl's Avatar
Xahl has yet to learn the way of the Dremel
hmm I had a similar-ish problem where my laptop would just reboot after a period (as if overheating) until the point where it just wouldn't turn on, which is a motherboard - power supply problem usually. I ended up having to get a new machine, which unfortunately doesn't help you but it might help indicate where the problem might be...
__________________
i5 2500k @ ghz | Corsair H80 | Asus HD 6850 | 8GB Corsair Vengeance @ 1600mhz | Corsair Force Series 3 60GB SSD | Intel Z68 | Corsair Builder Series 500w | Corsair Obsidian 550D | Logitech G15 & G400
Xahl is offline   Reply With Quote
Old 3rd Aug 2012, 14:50   #5
ferret141
Ultramodder
ferret141's Avatar
ferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyan
Some hardware fault is probably the issue. But hs anyone ever considered cooked thermal compound.
ferret141 is offline   Reply With Quote
Old 3rd Aug 2012, 15:12   #6
lancer778544
isnt really an ultramodder...
lancer778544's Avatar
lancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyanlancer778544 is a Super Spamming Saiyan
Might be worth booting to a Linux distro and checking temps from in there if it can last the boot process.
__________________
Intel Core i7 6700k | Asus Z170-Deluxe | 16GB Crucial Ballistix Elite | MSI GTX 970 OC | 256GB Samsung 840 Pro | 1TB Seagate Barracuda | Corsair AX860i | CM Storm Trooper | Asus Xonar D2X
lancer778544 is offline   Reply With Quote
Old 3rd Aug 2012, 15:54   #7
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
ta da!
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP³ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 3rd Aug 2012, 23:07   #8
ferret141
Ultramodder
ferret141's Avatar
Originally Posted by The_Crapman View Post
ta da!
Sorry for not reading thoroughly enough.
Old 5th Aug 2012, 12:47   #9
Blogins
Panda have Guns
Blogins's Avatar
Blogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming SaiyanBlogins is a Super Spamming Saiyan
My initial thought would be a faulty laptop PSU adapter or connection, the most common fault. Does the system have any problem sitting in the BIOS screen for a good few hours without stability issues?
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)|
|Kingston HyperX Savage 16GB DDR3 2133mhz (Memory)|ZOTAC GTX 980 Ti / ASUS GTX 980 Ti (SLI Graphics)|
|Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)|
|Samsung 840 Pro 256GB (SSD - Boot)|Crucial MX100 512GB (SSD - Games)|
Blogins is offline   Reply With Quote
Old 5th Aug 2012, 18:48   #10
Wicked_Sludge
i havnt been able to run any 3d graphics tests. furmark just crashes on launch and 3dmark requires directx 10 which i guess this ati Xpress 200M does not support. i did successfully run the WEI test.
i just ran prime95 with speedfan going and it froze within 3-4 minutes with the following temp readings:
temp1 - 55
core0 - 46
core1 - 45
based on that im even more sure its not a CPU heat problem (but i have no way of monitoring the GPU). i must now let the system cool off for a while because when i try to power it on, i just get a black screen. no POST or anything. once it cools off i will let it sit on the BIOS screen and see if it freezes (im pretty sure it does though).
i suspect the power supply is OK. ive used it with two other laptops and they both work OK...
__________________
My Rig:
Old 5th Aug 2012, 19:20   #11
Blogins
Panda have Guns
Blogins's Avatar
The only thing I can suggest is attach a copper heatsink to the ATI chip. Just do a soft install with some TIM and see if that helps. Doesn't have to be anything pretty, as long as it's adaptable to fit it'll do for testing!
__________________
Old 5th Aug 2012, 20:17   #12
lancer778544
ati Xpress 200M
I'm gonna put money on that being the culprit. I've had to replace a couple of motherboards with that exact chipset due to garbled graphics outputs when warm.
__________________
Old 5th Aug 2012, 20:21   #13
hughwi
I *am* a Dremel
hughwi's Avatar
hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.hughwi is the Cheesecake. Relix smiles down upon them.
Seconded, this chipset seems to get FUBAR'd after a few years of running in a lappy with no heatsink.
__________________
Main Rig: Asus Z97I-PLUS | Intel Pentium G3258 w H80 | Corsair CML16GX3M2A1600C9 LP Vengeance RAM | EVGA NVIDIA GTX 750Ti SC | Corsair RM650 | 2 x Crucial 256GB M4
hughwi is offline   Reply With Quote
Old 6th Aug 2012, 08:57   #14
Wicked_Sludge
Ive also been leaning toward a bad GPU pretty much this whole time, i just have no way to confirm it. i dont have a heatsink small enough to fit the chip, but i did stick a half-height PCI bracket to it to act as a sink of sorts but the system still acts up. im starting to think it may be toasted from previous overheating
__________________
My Rig:
Old 6th Aug 2012, 09:06   #15
Deders
I Mod, Therefore I Own
Deders's Avatar
Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.
How old is the laptop? it could be another chip that doesn't have active cooling or it may be because some of the solder has gone bad causing resistance.
__________________
i7 6700K @4.6GHz - Asus Z170 Deluxe - Noctua NH-D15 - Gainward Phoenix 1080 GLH 8GB @2050 & 11000 - 16GB Gskill RipjawsV DDR4 @3200 - Corsair HX850i - Nanoxia Deep Silence One - Samsung 950 Pro NVMe - Samsung Spinpoint F3 1TB - WD RE4 2TB - WD Caviar Blue 640 - Dell U2913WM Ultrawide - Logitech G19 - Corsair M65 - Sony STR-DN1050 Receiver - Q Acoustics 2000i 5.1 speakers.
Deders is offline   Reply With Quote
Old 7th Aug 2012, 07:32   #16
Wicked_Sludge
so for the past 2 days i couldnt get anything but a blank screen out of this thing. finally, tonight i disconnected and reconnected what i assume to be some kind of small battery (red circle) and it POSTed and i got to the BIOS screen. i dont believe this is the cmos battery, which i have circled in blue.
the system sat for 3 hours on the BIOS screen and was still operational. as soon as i tried to boot into windows, it froze on the starting windows screen. ditto when i tried again. it seems any load at all is enough to lock it up when the system is warm.
i think this machine was given to me in '07. it would have only been about a year old at that point and since ive had it its spent most of its years collecting dust.
__________________
My Rig:
Old 7th Aug 2012, 07:35   #17
Deders
Deders's Avatar
Could try looking up the part or serial number on the battery?
Most laptops have a lifespan of about 5 years unfortunately
__________________
Old 7th Aug 2012, 07:46   #18
Wicked_Sludge
good call. it appears to be the modem (i was way off!).
id say unplugging it and the machine coming back is coincidental, but its not the first time ive gotten it to boot by doing that.
just for fun, i started it up with the modem removed. the system booted into windows and i managed to run prime95 for 3 minutes before it locked up. i attribute being able to boot this time to it cooling down for 5-10 minutes.
__________________
My Rig:
Old 7th Aug 2012, 07:49   #19
Deders
Deders's Avatar
Have you checked the soldering for dry joints? Capacitors etc for bulges?
__________________
Old 7th Aug 2012, 07:51   #20
Wicked_Sludge
theres only a handful of caps on this board and they all look good. as for solder joints, theres a metric ****ton on this board. ive glanced it over but studying even half of those connections boggles the mind!
__________________
My Rig:
Reply
Tags
gateway, laptop, naked, overheating
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
