#21 |
What's a Dremel?
That is a sweet build. Was looking to build something like that myself but took a dremel to a Cosmos 1000 instead.
Two questions though. What size tubing and fittings did you use? And how secure is the video card? Is the acrylic enough to keep the video card waterblock from touching the motherboard? Great build and keep up the good work. |
#22 |
Multimodder
Looks really good. I LOVE this build.
#23 |
Minimodder
THanks Knighthammer!
Mnemonicman - i started off with an EK-kit H30 360 LT which comes with - TUBE Masterkleer 12,7/9,5 CLEAR and all the relevent fittings too... then i just needed two extra 1/4 pipe fittings for the Heatkiller fx560 block and some elbows to tidy the fit. The Gpu holds quite nicely against the acrylic layer, with only a small amount of flex in the top one while the build was laying down. the waterbloock is very narrow and theres a gap of 10-20mm between it and the motherboard. FOr a while i was reaching a finger in to hit the onboard start button! Theres more than enough room between them to run the 12.7mm OD pipe up between and lay the excess flex cable from the riser card. Hope this answers your questions! |
#24 |
Minimodder
Looks very nice!!!
I want to see it finished soon! Congratulations buddy! |
#25 |
Minimodder
Amazing work!
I'll stay here to see it finished |
#26 |
What's a Dremel?
Redd13 - Thanks for the response, and yes you did answer my questions. Again fantastic build.
#27 |
Minimodder
Small update.
THanks for all the comments.. loving the feedback! have sorted two little brackets... which just need to be attached by screw (for easy removal) then its onto the outer cover! so close to completion i can taste it! |
#28 |
Minimodder
Here they are in place... working like a treat! Also got the patterns for the outside panels done over the weekend... Now just need to get them cut. |
#29 |
Minimodder
Yay!
Laser cut acrylic cases ![]() Cool slim layout. Reminds me of those mini nettops but a large more practical version. |
#30 |
Minimodder
Thanks!
my final goal is to produce a slim case that can hold normal size computer parts.... |
#31 |
Minimodder
Ok nearing completion, got the sides cut and heres shots of them taped on... just gotta clue it together and slide over the top.... then on to tidying and final testing!
(note the sides still have the protective backing on! Also have to sort some LED lighting on the inside so it really glows through! |
#32 |
Supermodder
Who did the laser cutting for you?
#33 |
Minimodder
The company i work for deals closely with an Acrylic manufacture company called Acrylux...
They have a 1.5x2.5m laser cutting machine! Like what you did with that 360! Last edited by Redd13; 22nd Aug 2012 at 08:40. Reason: Additional |
#34 | |
Supermodder
And thanks. I like it lots.
#35 |
Minimodder
Well if youmention how you heard of them im sure they can sort you out...
If you can draw the dxf too like i do then they 'll do you an even greater price (www,acrylux.co.uk) Be nice to see what else your gonna do! |
#36 |
Minimodder
Yay my led controller turned up early!
Its a nice little module that can run 5 meters and still be hidden away! |
#37 |
Minimodder
Sorry for the delay folks, still working on the LED's but the cover is looking a bit tidier now...
#38 |
I think we can make that fit
Very nice job it's amazing to see what can be stuffed in to a small area with the proper planning. I look forward to seeing it completed with the LEDs and all.
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
#39 |
↓ Don't trust that face!
Pretty cool.
I'm fond of low profile rigs too, ...and plexiglas.
__________________
#40 |
Minimodder
Thanks Mechh69 and Cheapskate.
It#s quite a tight fit... and took alittle time to slide the cover over the top... Plastic pipes stck to acrylic! Heres a couple more shots of it running and i'll sort some dark ones in the next few days! |
| Thread Tools | |
| View Mode | |
