Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Aug 2012, 13:27   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Ozone Radon Opto review
http://www.bit-tech.net/hardware/201...-opto-review/1
brumgrunt is offline   Reply With Quote
Old 3rd Aug 2012, 18:57   #2
g_gimbert
Multimodder
g_gimbert's Avatar
g_gimbert has yet to learn the way of the Dremel
I've been using one of these for a few months now and this review is spot-on.
The mouse is pretty good, but is let down by slightly iffy ergonomics. I found I've adapted easily enough to the thumb button placement, but lack of anywhere to rest the little finger is the main issue. The LED's that light up to indicate which sensitivity level is selected are pointless too - they cannot be seen from an angle so are only of any use if you look directly down at them from above, which is pretty unlikely.
However, I do really like it, and the shape isn't really an issue if you use a claw grip (personally I use both a claw and palm grip depending on what I'm doing). I think the soft-touch plastic is a great feature - much better than cheap shiny plastic.
__________________
Intel Pentium 2180 @ 3Ghz, MSI X38 Diamond, OCZ Platinum DDR3 4GB,MSI AMD Radeon 6870 1GB HAWK, Creative X-Fi PCIe, 10GB Seagate, 160GB + 200GB Maxtor, 500GB WD, 1TB + 2TB Samsung, Optiarc DVD-RW SATA.
Cornerstone 21" CRT + ViewSonic VX924 * 2, Creative 4.1, Logitech LX700, Windows Vista Home Premium + XP SP3.
The Cake Is A Lie
g_gimbert is offline   Reply With Quote
Old 4th Aug 2012, 15:19   #3
TheDodoKiller
Supermodder
TheDodoKiller's Avatar
TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.
I'm sure it's a good mouse, but I'll never buy anything from Ozone again.
I've owned 2 headsets from them- a Spark and a Strato Evo.
Both of these headsets broke- The strato was to replace the Spark- which had a broken microphone.
Since contacting Ozone support, I've heard not a dicky bird from them. Not even 'Sorry, but nothing we can do since it's out of warranty' I've come to doubt they even have some sort of customer service department.
I certainly won't ever buy an Ozone product again.
__________________
- AMD 1090T OC'd at 3.6 Ghz - Asus Crosshair IV Formula - Reference Asus 6950/70 - Silverstone FT02 B-W - Kingston HyperX 3K 128GB SSD - Samsung F3 1TB - Kingston HyperX 1600 Ram 4GB - Coolermaster V8 -
TheDodoKiller is offline   Reply With Quote
Old 7th Aug 2012, 16:21   #4
Lee @ Scan
Scan Computers
Lee @ Scan's Avatar
Lee @ Scan has yet to learn the way of the Dremel
I've tried this mouse out at a friends and its a step back when you compare it to their Ozone Smog mouse (which I have and frankly can't find anything wrong with it at all)
Lee @ Scan is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
