Reply
Thread Tools View Mode
Old 22nd Sep 2012, 06:04   #21
mybadomen
Multimodder
mybadomen's Avatar
mybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremel
made a mistake sorry
mybadomen is offline   Reply With Quote
Old 25th Oct 2012, 00:52   #22
mybadomen
Multimodder
mybadomen's Avatar
UPDATE 9 !
Acrylic Laser cutting is done and now here ready to go. There will be more work done to the Acrylic but that i will do in house. Huge Thanks goes out to Tyler Industries for there great Acrylic work.
Also the 2 custom Primochill CTR reservoirs have arrived. These reservoirs are not yet released and have been made to a custom length or 24 inches long for the build by Primochill. Release Date on the Primochill CTR Reservoirs is Nov 1st and i have been messing with them for a while now and they are very high quality and incredible looking reservoirs.
Photo of one of them as the other is in the box to avoid getting damaged as i work.
Also have been messing with different color coolants from Primochill's new "Intensifier" Product line. These Dyes are amazing from what i have seen so far. here are a few samples i made just messing around but i still haven't decided for sure the final color going into the JukeBench build.
Here is a white which was made by adding 2 15mil Primochill Intensifier Base bottles to a whole gallon of distilled. (Only 1 15 mil bottle of Base if going to color it , 2 bottles is just for white)
Photo of the white in action (Could easily make more white or less white )
Pink anyone? Just a light pink as i was messing around before changing coolant colors.I was aiming for Pepto Bismal color just for fun.
This Blue came out really cool also but wont be the color for the JukeBench.
Well that really it for this Update but getting the Acrylic and special reservoirs is Huge as thats what i needed to move on with this build. So Keep watching.
Also for more Info on the Primochill CTR Reservoirs or the Amazing new Intensifier Dyes that i totally fell in love with see here : http://www.primochill.com/
Take Care my friends at OCN and please subscribe if haven't already.
MybadOmen
Old 6th Nov 2012, 00:14   #23
mybadomen
Multimodder
mybadomen's Avatar
UPDATE 11 !
Hiya Fellow Modder's /Overclocker's/Folder's and Gamers. As promised i am back to release another update one the JukeBench build. I didn't sleep at all through the night just so i can finally get some progress going to show you guys. Even though like i said there is no rush on this Mod.
Ok i will stop blabbing and get right to it. This update is me starting to build the actual Jukebox base onto the Dimastech bench.
Here is the bench all stripped down again ready to Mod and then paint. Ant the Acrylic is sitting on tops with a protective layer on it all. Just thought id mention that before people ask why i am using wood.
Materials:
First thing i had to do was make a way to Squish the Acrylic between a piece of Aluminum which will strengthen the acrylic so it don't crack and just help to keep it sturdy. Also i wanted it to be removable if i ever wanted to remove it.
This is what i did: I first needed a 2 1/2" wide by 16 3/4" long aluminum plate for each side. So i measured that out to make a base line to go by on both sides.
These dots represent 2 1/2" plus they are also in a particular spot for what you will see in a bit.
Clamping the ruler assures a nice straight line by avoiding any movement drawing on long runs.
Here im about to cut the 2 1/2" x 16 3/4" Aluminum plates from this sheet of Aluminum. Always wear safety glasses like the ones you see me using, as i have been in the hospital on more then on occasion with metal in my eye. Not fun.
By the way these are the best safety glasses i have ever worn and you can get your own set at Mnpctech and they are incredibly inexpensive and also very High quality.
Link to Safety Glasses from Mnpctech : http://www.mnpctech.com/Safetyglasses.html
Ok Just Marking the measurements out:
And finally off and Modding. I used that guide on the jigsaw 2 times and ended up having to finally cute then freehand.
2 nice pieces of Aluminum. For those that don't know Aluminum can be wet sanded and polished to look very similar then chrome. But its better then chrome
Just lining them up but wont finish them till the end so i don't scratch them up:
These are the holes that will go through the Aluminum and Acrylic and the Bench will be threaded.
This always scares me is drilling through thin acrylic. To fast of the bit grabs . Big Crack.. Luckily all went smooth..
Ok there is a photo missing here . It should have been me drilling the Bench holes out but. I had the camera in 1 had and drill in the other.Dropped the drill and broke the bit. So no photo .Lol
Speaking of breaking things. This is what happens sometimes when trying to tap without cutting oil. I am painting the case shortly so i don't want any oils near the Bench at all.
Success ! and yes those are the long hard drive screws that usually have a rubber grommet. Worked perfect for this.
Just to show how sturdy it is this way .The bench is on its side and the acrylic isn't really to light but its also a success so far.
Starting to look like something.
You can see in this Photo my design was a little flawed but just a few minute fix. This will be the Back of the bench with a 220mm Exhaust Fan. Remember this build isn't just cute its also a Monster!
And no i didn't sniff it. Lol anyway the Acrylic Glue (Will have to sit for 24 hours before moving on )
Can you see her in your head yet? Omg i hope she keeps looking better and better.
Ok here is the last Photo for this update. Before i post it i want to tell a little story. I was reading build logs randomly like i always do and i came across this guys building Phase changers or something crazy insane. His username was Dimas. I started following his work and started seeing more and more of his Benches. I fell in love with the Easy/Hard 2.5 bench which is what you see me Modding. Anyway i found out it was Italian made. Come on everything Italian made is incredible quality. I cant remember how it actually happened but they seen i loved the bench and somewhere along the line i ended up Building a Sponsored Dimastech Bench which was a nice break from doing case. Plus i never hardly game i Benchmark and Overclock and thats about it mainly. I do play the campaigns on most new games though.
Anyway when i got my sponsors this is what i was going to Build. (Those who know me ,know i change everything right in the middle of a build sometimes) Anyway this one i really changed and im sure i will more before its over.
First Design :
I know some of you are probally saying wow that would have been cool. And yes it would have but not unique enough for me. JukeBench is perfect because it makes no sense at all.. A Total beast of a PC that can handle LN2 ,DICE or just hefty watercooling and i wrapped in in a funky jukebox. But the Jukebox is set to the RoG theme for colors.
Anyway just thought id tell you guys a little story about the build since you had to wait so long for an Update.
Last Photo.. Thank You Dimastech !!!
Welders up and running with a brand new spool of good wire ,Replaced my Air compressor so that's ready to go .
So Stay Tuned Much More Modding to Come !
Don't forget to check out my New Phantom 820 Mod that i will be doing the same time as this one.
I'll be back soon my Friends so stay safe and take care... (Wear you Safety Glasses ! )
MybadOmen
Old 11th Nov 2012, 16:59   #24
mybadomen
Multimodder
mybadomen's Avatar
Update 12!
This update is just short and sweet its a Photo of the base pretty much together to start building off of. Board in the center was just for support till the glue was fully cured.It has since been removed.
And of course the update wouldn't be complete if i didn't show the heart and soul of this monster JukeBench and that's the Asus Rampage Extreme IV X79 fitted with an i7-3930k and 16 Gigs of Quad channel Corsair Dominator's C9 2133mhz. Also as you seen in photos about its fitted with every water block imaginable from EK.Also to add to the Horsepower is a Pair of HD7970 Gpus at 1250/1750.
Seriously tell me this don't look like a v8 getting ready to go in a street rod Can tell where my background was before PC's.
And here it is the belly of the beast :
Hope you guys like it so far ..Keep watching for more soon.
Take Care
MybadOmen
Old 15th Nov 2012, 05:46   #25
mybadomen
Multimodder
mybadomen's Avatar
Update 13!
Getting ready to drill the holes and cutouts to mount the new parts i got from Mnpctech. I got 2 PC Mod Digital Thermometer's to give me the ambient temps inside the JukeBox part of the build and the other one to give me either the outside ambient temps or inside where the rads and PSU will be sitting. (Most likely outside the case Ambient) And because the will look cool on the Mod of course ..
Also i will also be adding the Popular Billet Machined Aluminum Case Feet from Mnpctech to the bottom of the bench to give it a really cool look.I love the small details like that it really sets a build apart.This will be my first time using these feet but i seen them on many builds and had to have them.
Here is a quick Peek of them before i start Installing them .
You can get all sorts of Modding supplies from the guys at Mnpctech as they are Hardcore Modder's themselves and know what we need.
For the Mnpctech website just click the banner:
Be back soon with the updates of me installing them. Take Care guys and please remember doing 2 Mods and a Client build at the same time and its only me here with limited tools. But im doing my best.
MybadOmen
Old 23rd Nov 2012, 10:51   #26
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.
Custom Tech bench builds, Next big thing?
Glad to see more progress on this build!
mnpctech is online now   Reply With Quote
Old 30th Nov 2012, 04:59   #27
mybadomen
Multimodder
mybadomen's Avatar
Yeah i messed the top up bad so stuck trying a different method . Hopefully it looks good still with the new top. Still acrylic 1 more shot and if i cant get the arch right i will most likely goto Metal for the roof as this is taking way to long.
Old 1st Dec 2012, 20:44   #28
HobbieZones.com
Multimodder
HobbieZones.com's Avatar
HobbieZones.com has yet to learn the way of the Dremel
Primochill CTR reservoirs would look nice on my system also 2 of them and then add some Mayhems Aurora Tharsis Red Concentrate.
Maybe Santa will bring them.
Nice build ya got getting about pc upgrade time again and looking at this MB.
HobbieZones.com is offline   Reply With Quote
Old 5th Dec 2012, 14:32   #29
mnpctech
bit-tech sponsor
mnpctech's Avatar
yea, I caught that sheet you were using, it was big... very tricky to heat and get the right arc in it..
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
