Reply
Thread Tools View Mode
Old 10th Aug 2012, 13:52   #1
KryptiK
Minimodder
KryptiK has yet to learn the way of the DremelKryptiK has yet to learn the way of the Dremel
Project - OBSIDIA-Shiro - UPDATE:Project Completed, finished the laser cut madness
The Design
The name OBSDIA-shiro is derived from the volcanic rock - obsidian, which is very hard and sharp (typically black in its colour) and the Japanese word for white - shiro. The design utilities the contrast between these two extremes in colours with the combination of red accents to create an subtle aggressive feel to the case. I tried to bring out beastly qualities through very distinct oblique and straight edges and the resulting shapes that were formed resemble the front and back legs of a 'beast'. The red trusses neatly frame the side panel windows and draw your vision towards the hardware inside.
The layout of the components was inspired by existing cases like the Raven series by Silverstone with the rotated motherboard configuration which allows for improved air cooling capabilities. Also, the front fins were inspired by heatsink designs; thought it would be appropriate to cover the front fans with this concept (would be awesome it they actually had a functional aspect that allowed for heat dissipation - unfortunately made of acrylic)
Background Info
I would like share my Major Design Project build log with the guys and gals of the bit-tech community. For my Design & Technology HSC course I have chosen to design my own scratch built case (aka OSIDIA-Shiro). I'm currently in the process of finishing off the project that I have been working on since the beginning of the year. God knows how long I've been working on the 3D CAD drawings in Solidworks. The design itself has changed dramatically but the overall form and aesthetics have been kept. Finally have a design that I'm satisfied with.
I'll be sure to keep this build log updated to my current progress.
Really should have kept the final design a secret but... the hell with it couldn't wait any longer to show everyone.
The entire chassis is made from several laser cut sheets of 600x300mm acrylic sheets of 6mm and 3mm thicknesses. Held together with IPS Weld-on #3 and a bunch of M3 and M4 bolts. As you can see in the image that a few pieces also need to be bent.
Sponsors
Special Thanks to Lamptron and James Campbell for supporting this project.
The Build Log
Feels like I'm under the pump since the project is officially due on the 27th of August, so I need to have something that's finished and presentable for the markers to look at.
Should of started this thread earlier but was very busy with studying for the trials exams (cough). And its nearing the end of the trial exam schedule so I have time to post this thread and finish building it. One more exam left.
Most of the first few posts are things I did a while back.
Fortunately I have access to a laser cutter at school. First day of laser cutting. Came home with a huge mess of cut parts. Might have lost a few on the way.
This side panel window with magnet mounting holes didn't cut properly You would think that if you had the laser cutter with settings for 6.01mm thickness for acrylic material (6mm thick) that it would cut through. I could feel under the sheet that it cut all the way through.
It needed some light persuasion from a mallet to whack those pieces out. But it resulted with some ugly edges (knew it would happen but had to give it a try anyway). So this needs to be cut again
On the other remaining side window I inserted some 3x10mm neodymium magnets. They apparently have a pull strength of 1.9kg which should be more than adequate for holding the 6mm acrylic panel in place. It took a bit of force to remove it from my ruler.
Here's a peek at the few components together.
So after that incident with the 6mm laser cutter setting, I learned my lesson and used a test piece of 10mm clear acrylic to play around with intensities before I started to cut.
On the right is the perfect setting - giving a clean polished edge while
left was a higher setting - resulting in fusing/melting of the sheet and causing distorted edges
KryptiK is offline   Reply With Quote
Old 10th Aug 2012, 22:41   #2
Snowcrash
Minimodder
Snowcrash's Avatar
Snowcrash has yet to learn the way of the Dremel
Cool design, man, and good looking parts too
Would be great if you could show how the parts are joined together and the rest of the little details.
Btw, no doubt you'll be fine with the 6mm, but are you sure the 3mm parts will be sturdy enough? unless these are relatively small pieces, acrylic of this thickness tends to bend rather easily if it's put under pressure...
Looking forward to seeing how this one progresses
Snowcrash is offline   Reply With Quote
Old 11th Aug 2012, 00:26   #3
KryptiK
Minimodder
Most of the components are joined with bolts and brackets. Used mostly for joining two 6mm thick parts M4x12mm for structural/support and M3x12mm for the rest. In some areas I choose to glue parts together as it would give the case a cleaner look.
Had to use the big daddy M10 for this other component (I'll show you later)
Tapping holes with M4 thread. It made life a lot easier by tapping all the hole first before gluing the brackets.
Some more tapping, this time M3. Probably took all morning that day trying to get all components threaded. Tapping acrylic is a lot more forgiving than alu, I broke a tap while trying to do so when I was prototyping.
Before gluing I thought it would be best to clean the surfaces with isopropyl to remove impurities (since most of the parts were collecting dust around my house). On some edges there was soot left over from the laser cutting process.
Using Weld-on #3 that my friend lent me in a mysterious bottle labeled "glue"
I was difficult trying to get my hands on a syringe with a tip (would have need easier if I were a druggo). Some pharmacies and chemists have needle exchange programs - their the ones to buy em from
Parts that are not joined directly with a bolt-bracket-bolt configuration are like these where I carefully aligned the part 3mm from the edges.
The brackets are composed of two parts that are joined together like so.
Finished gluing the brackets.
Stay tuned going to add more juicy info soon
Old 11th Aug 2012, 00:43   #4
KryptiK
Minimodder
Painting time!
First up, some wet sanding with 600grit. Made a makeshift sanding block with Styrofoam (its great for those curved edges)
Nice and frosty
Took a tip from Bill Owen in his tutorial for spray painting with aerosol cans. Soaking it in warm water, giving the can better flow.
After first few coats and wet sanding.
The parts are quiet fragile, dropped one of them...
Waited for the paint to cure and joined it back together and resprayed. You wont even see the part when its assembled but that little chip is annoying me.
The overall finish is reasonable quality. I'm no professional
Old 11th Aug 2012, 01:04   #5
Steve_of_Death
Minimodder
Steve_of_Death has yet to learn the way of the Dremel
gonna be amazing when you finish it
Steve_of_Death is offline   Reply With Quote
Old 11th Aug 2012, 01:05   #6
KryptiK
Minimodder
Oh I might as well show you guys what part of the case was going to look like. My original idea was to make it out of aluminum, which the idea was scrapped because of my lack of skill and accuracy with working with tools
This increases my appreciation even more for Attila's skills in working with alu is phenomenal
So anyways here are so more pics. A very shiny motherboard tray. It's high gloss black acrylic.
Bottom fan grill supports dual 120mm fans (could fit a radiator under there as well) with ports for cable management.
Front 360 rad fan mounting.
A peek at some of the assembly. So many bolts!
and with the side panel window on. Didn't take the protective film off (don't want to scratch it)
The cluster of M3 bolts in the top left on the rear leg is ugly
should have glued that bracket onto the leg instead
This is what a mostly assembled side of the case looks like. The odd looking black parts were glued on while the other parts are bolted together.
Old 11th Aug 2012, 01:19   #7
J-Lyons
Minimodder
J-Lyons's Avatar
J-Lyons has yet to learn the way of the Dremel
This may be the best design I have ever seen.
J-Lyons is offline   Reply With Quote
Old 11th Aug 2012, 01:21   #8
KryptiK
Minimodder
Here are some images from Solidworks. Btw this was my first time ever using this 3D CAD program, over the past few months I've had some massive improvements. Self taught how to use it (it was surprisingly intuitive to learn, the tools work as I would except them too)
The rotated motherboard tray design was inspired by Silverstone Raven series of cases. noticed that these cases only had one handle on the top which is odd, so I've included two handles so I can actually be carried. My design supports mATX specs and the ability to mount a 360 rad at the front and 240 rad at the bottom. The pump would go in the back, underneath the PSU.
From my Photoview 360 plugin in Solidworks, the photo-realistic renders aren't a true representation of the aesthetics in my opinion. The colours and lighting need to be adjusted
I would love to read your opinions and evaluation on the aesthetics of the project. Right now I'm working on gluing some more parts together, will update soon.
Old 11th Aug 2012, 01:25   #9
J-Lyons
Minimodder
J-Lyons's Avatar
I am speechless...
Old 11th Aug 2012, 08:45   #10
KryptiK
Minimodder
Another update!
Today I was mainly gluing brackets to components. The 3mm sheet was bolted to the bracket and the bracket then glued like so. The fan grill panel was aligned to the corner.
This part was kinda fiddly to get the bracket aligned perfectly parallel since it was basically floating around (besides the connection to a parent part).
Since I didn't have any more 6mm white acrylic i used two sheets of 3mm bonded together. Not sure if this part will bend properly with a heat gun.
I'll try some bending tomorrow
Old 11th Aug 2012, 08:52   #11
KryptiK
Minimodder
After all that gluing I really wanted to see what this baby looks like
not bad and so far its going smoothly
fairly sturdy structure even though I haven't added all the cross bracing and its not that heavy either
Old 11th Aug 2012, 09:01   #12
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
bloody hell mate, this is incredible!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is offline   Reply With Quote
Old 11th Aug 2012, 09:02   #13
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
Fist time im seeing this log that is turning out REAL nice and tidy!! gonna follow this one closely!
You not worried those rare earth magnets are going to inter fear with anything inside the box?? they generally have a pretty large and powerful field
__________________
Ω Omega Desk Ω
Squigly is offline   Reply With Quote
Old 11th Aug 2012, 09:26   #14
KryptiK
Minimodder
Cheers it took quiet a while to get it all together. Lots of planning was done, but I think it needed some more.
This is the type of magents i'm using
http://aussiemagnets.com.au/product/...2C-100%29.html
True that the field is relatively large (tested it out myself, placed one magnet on its edge and rotated another at a distance around 10cm away and the field is still faintly present). Even though it has a large mag field its exponentially weaker. The HDD's are positioned at least 15cm away; magnets shouldn't interfere with any of electrical components anyway.
Old 11th Aug 2012, 09:50   #15
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Looking great so far, I wish I had access to a lasercutter...oh the possibilities!
Meelobee is online now   Reply With Quote
Old 11th Aug 2012, 12:58   #16
Dave Lister
DemonHighwayman
Dave Lister's Avatar
Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.Dave Lister is a hoopy frood who really knows where their towel is.
This is looking awesome dude ! sort of industrial and sporty blended together, love it let's see some more.
__________________
Main Rig:Case: CoolerMaster Cosmos S, Motherboard: Asus M4A785TD-V Evo, CPU: AMD Phenom II X6 1100T, RAM: 8Gb 1600Mhz Corsair Vengeance GPU: XFX ATI 5870, Primary HDD: 128Gb Kingston SSDNOW 200, Optical Drive: LG Super Multi Blue
HTPC:Case: Gutted out VCR, Motherboard: Asus AT5IONT-I, CPU: Intel Atom D525 @ 1.94Ghz, RAM: 4Gb 1333Mhz Kingston GPU: Nvidia Ion 2, Primary HDD: Hitachi 500Gb, Optical Drive: NEC ND-6500A Laptop Drive
Dave Lister is offline   Reply With Quote
Old 11th Aug 2012, 14:26   #17
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
impressive!
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 11th Aug 2012, 16:24   #18
aeidau
Industrial Designer
aeidau's Avatar
aeidau has yet to learn the way of the Dremel
Keyshot will give you better renders for .SLD files
Looking good mate
__________________
Industrial Designer & System Architect
Originally Posted by Shoggy
...I was wearing blue underpants to gain some extra performance...
aeidau is offline   Reply With Quote
Old 11th Aug 2012, 17:03   #19
Mizugetsu
Multimodder
Mizugetsu's Avatar
Mizugetsu has yet to learn the way of the Dremel
This is so awesome
Mizugetsu is offline   Reply With Quote
Old 11th Aug 2012, 18:31   #20
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Neat design. I like the 'stance' it has. We ran into a similar problem laser cutting thicker plexi. It retains heat long enough to melt the seam back together in the tighter cuts.
The water bottle full of solvent bugs me. I was instantly reminded of the "The Young Ones" episode with the homicidal maniac potion in a Coke can.
"I just bet someone will drink that later..."
Cheapskate is offline   Reply With Quote
Reply
Tags
acrylic, kryptik, laser, obsidia-shiro, scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
