Thread Tools | View Mode |
#41 |
Professional Sleever & Modder
we want mooore!
#42 |
↓ Don't trust that face!
I figured you had access to some school shop equipment for the bends, and I didn't want to poo on such a cool design, otherwise I would have spoke up. Heat gun bends never seem to go the way you want unless you make some elaborate bending jigs or molds.
Looking fantastic right now.
__________________
#43 |
modeteer
the biggest key with heatgun bending for acrylic is to heat it slowly, keep it fixed once its where you want it, and cool it back down to ambient slowly also. Always worth testing out a few samples before you actually bend your part.
The fast it heats and cools the more material warp your going to see |
#44 |
Supermodder
Damn this is cool. +sub
#45 |
Minimodder
I've been doing a lot in the past few days, so wait no longer. The project is approaching the finishing line and a lot more updates will come.
Some of the holes I've tapped where kinda useless and unnecessary, so they gotta go ![]() ![]() ![]() ![]() Also resized more holes so the alu rods would fit in easier. ![]() Reason for this is to prevent things like this from happening. Should have been a bit more gentler when assembling... Recut the broken component out of four 3mm sheets and laminated them together with weld-on because I ran out of 6mm sheets to cut from. ![]() ![]() Been working on the project everyday, only get a few hours of daylight when I get back home. Attempting more bending with the heat gun ![]() Hot stuff ![]() First try turned out fairly well ![]() But also had to replicate a mirror of that before it got too dark. No real bending jig was used, just a 10mm rod and some scrap mdf (the heat resistant gloves saved my hands from being cooked, was doing it w/o them when I first started bending) ![]()
#46 |
Minimodder
Oh, also assembled majority of the front fin assembly.
Polished the alu tubes, didn't achieve a mirror finish - kept scuffing when inserting the fins. ![]() ![]() Didn't have any more of a particular fin type, so improvised by filing down some spares. ![]() ![]() ![]()
#47 |
Genious work, keep the flow !
#48 |
Minimodder
Just to let you guys know, the case is finished. Will post lots more info after the 27th of August. Don't have any time to upload and images and write up the log atm since it's been very stressful over the past few days in getting design to a finished state as well as completing a very long written folio accompanying the entire design process.
#49 |
What's a Dremel?
Good Job! Turned out very well, with only some minor bending issues. I know how hard you worked and it sooo payed off, except...stay to drawing on cad.... lol.....
#50 |
Minimodder
The case can be considered 'finished', (well its functional) but I still want to continue fixing some issues that I encountered along the way and also add a few modifications to the design.
Assembling, you can see how everything fits together basically. ![]() ![]() So, continuing with the last update. ![]() The front fin assembly fits together quite nicely, the top cover is detachable which allows for quick removal of the fans. ![]() ![]() Finally fixed the HDD cage. It's well balanced and rigid. ![]() ![]() Used the leg of a chair that had the right diameter for my bends. ![]() ![]() ![]() To achieve the closest representation of what I wanted it to look like. I just eyed it off, with lots of trial and error in reheating and shaping. ![]() With everything assembled and a system loaded up (hardware inside is a bit shabby and my psu cables weren't nearly as long as I thought they were). Planning on doing some sleeving in the near future. ![]() ![]() Those handles themselves (black component) are only secured to the transparent acrylic component (done this because i thought it would make it easier to position the handles) with the acrylic adhesive bonding at a few points and then bolted to the top panel.
#51 |
Coming along very good! Cant whait to see it finished !
#52 |
Supermodder
Awesome work love it
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#53 |
Supermodder
Looking superb mate, excellent work.
Only negative I can think of is the socket cap screws/bolts holding it all together would look a lot better in black.
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb Coolermaster 600w Silent Pro Modded Lian Li PC-0700 |
#54 |
Minimodder
Update!
Great news, Lamptron has sponsored this project. ![]() Also, the case was submitted for the HSC and marked by external markers on the 28th of August. Will find out the results in December. Here's a few pics of the setup for presentation. The project was described as 'Contemporary P.C. Tower Case', could use the project name that I given it for some reason. You can see some of my crazy prototypes and concepts on the left edge of the image. ![]() ![]() The cable braiding on the G9 is a little worst for wear. ![]() I want to give a shout out to Daniel Kennedy - Epic PC Cases, for writing a design evaluation on the project. Will continue to further update the progress of finishing touches/modification. |
#56 |
Pump Killer
Congrats on a great build!
![]() Sorry for my ignorance, but what is "HSC" ?
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#57 |
Supermodder
Fantastic work. How much does it weigh?
#58 | |
Minimodder
Thanks for all the support guys
"The Higher School Certificate (HSC) is the highest award in secondary education in New South Wales. To be eligible for the award, students must complete Years 11 and 12, satisfy HSC course requirements and sit for the statewide HSC examinations." In the Design and Technology course students must complete a Major Design Project and something that I always wanted to do was design my own case. Not totally sure since I haven't weighed it on scales. I wouldn't consider the case to be 'light weight' but it can be lifted easily (with hardware installed). The handles feel strong and hold the weight quite well. |
#59 |
Minimodder
Here are some new images of the chassis and an update on some news, my project was nominated for the DesignTECH exhibition
![]() "DesignTECH is an exhibition of outstanding Major Design projects from Higher School Certificate Design and Technology students." - http://www.boardofstudies.nsw.edu.au/exhibitions/ ![]() ![]() ![]() ![]() ![]() Images were photographed by Andrew Kim. |
#60 |
Supermodder
Great case that's for sure! I really like the details
__________________
Current projects: Tydirium is on the way! Previous mods: | [/url]|Sandcrawler Mod| |Illuminated Mind| [url="http://forums.bit-tech.net/showthread.php?t=246505""]Graphite 5 Follow me on Facebook |
| Tags |
| acrylic, kryptik, laser, obsidia-shiro, scratch build |
| Thread Tools | |
| View Mode | |
