#61 |
Ultramodder
Once you are done fiddling around and you try running bigadv/bigbeta and let us know the total PPD you get
![]() Power draw would be helpful too! Cheers. |
#62 | |
Multimodder
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. |
#63 |
I *am* the guy with two left hands
Default value is zero because those are the official maximums defined by Intel, and zero means you want to keep default values.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04 |
#64 |
Folder of the month April 2012
Glad you have your second chip up and running.
I have no knowledge of your system but imagine it would benefit substantially from the Kraken 0.7-pre15. Perhaps an alternative strategy would be to return everything to stock, install Kraken and then gradually tweek your settings whilst folding. When the Kraken is in use the core load displayed by System Monitor should be stable. Good luck !
__________________
#65 |
Multimodder
The Kraken
Hi One Box
I am sure the kraken would help. I have downloaded thekraken 0.7-pre15, untared it and compiled it. When I try to install it I get "problems occurred during wrapping, no wrapping performed (code 2)". It could be because I am using FAH V7, but Tear says he has added support for V7. It could be an issue with the location of the files. I am new to Linux so it is a bit of a steep learning curve.
__________________
#66 |
Supermodder
Hi Slowlemon,
Where abouts did you put the kraken? Not very familiar with v7 in linux as I went for v6.34.
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. Last edited by Scorpuk; 7th Sep 2012 at 09:34. |
#67 |
Sorry I only use 6.34 on my 4P system so cannot comment on V7 with the Kraken.
Perhaps it would be easier to use 6.34 where the Kraken will work without problem ?
__________________
#68 | |
Multimodder
So far as I can make out my folding directory is /var/lib/fahclient, thekraken-0.7pre15 (folder) is in /home/username and thekraken (program) is in /usr/bin. Just been reading the .txt docs that came with thekraken. In the readme it says that only a3 and a5 cores are supported and it gives instructions for installing with V7. In the change log it says that a4 support was added in version 0.7pre14.
__________________
#69 |
Multimodder
Thekraken working
Hi All
I have eventually sorted this out. I needed to type "sudo thekraken -i" not "thekraken -i". I am a Linux noob .
__________________
#70 |
Multimodder
Progress
Hi All
I am starting to make real progress with this now. I have installed thekraken and switched over to bigadv projects. It`s started a P8101 work unit and time per frame is about 22min, that should be good for 168K PPD. Power draw is 240W so that`s 700PPD/W ![]() . I should be able to get more accurate figures when I have more data to work with.I have not been able to test performance with/without thekraken on the same projects so I have no idea how much difference it makes. Because I have two processors running at different speeds the dynamic load balancing feature should be a big advantage. On SMP projects I was getting about 93K PPD. Still to do: 1.Find a way to get more turbo boost. 2. Fit more case fans and/or quieter case fans (the NZXT 140mm fans make a slight buzzing sound). 3. Fit lights (maybe) 4. Move it to the lounge. I want to even out the heat distribution for winter.
__________________
#71 |
Your power consumption is amazing
![]() My 4P uses 435W for 162K PPD on a 8101
__________________
#72 |
Folding@Home CC Captain 2010/11/12
Awesome mate, based on what you have done I have just gave in and purchased 2 x E5 2660 CPU's from a reputable seller in Hong-Kong, REALLY hope they are genuine and work etc although he does offer a DOA and 60-day warranty on them so should be all good!!
Just trying to decide on whether I should get an Asus Z9PE-D8 WS or pay the extra for a EVGA SR-X ?? Will be starting a thread for my findings as well
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ | |
#73 |
Multimodder
Update
Hi All
Progress has slowed a little bit. Average time per frame is now 22m 53s, that`s worth 158K PPD and 660PPD/W. Correction TPF is 22.53min, that`s 22m 32s, 162K PPD and 675PPD/W. Coolamasta welcome to the madness. These 2P Xeon systems are not going to challenge an AMD 4P with high end chips but they thrash an AMD 2P. The efficiency is very good, one reason I went this route is because I could see how good the Sandy Bridge desktop chips are for folding so I figured Sandy Xeons must be a good bet. The E5-2660s should be perfect for folding.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. Last edited by Slowlemon; 10th Sep 2012 at 20:31. Reason: Bad maths. |
#74 |
Modder
Are you getting the cpus from Mr Dinsdale ? He is usualy very good but hasn't sent my last order out and is ignoring my messages. A paypal claim will have to go in soon, the E5 2660s he offers are good chips, B0 stepping and run at 2.4ghz - 2.5ghz with a fsb tweak to 104. The B0 have full virtualisation support unlike some of the later revisions which may come in useful allthough virtualbox is very poor at handling 32 threads and uses its own virtualisation process. Get the ASUS board for sure it is excellent if expensive and works very very well. The platform is very efficient and its ppd/watt makes everything else look a bit silly. If only those cpus were unlocked but no E5s are - they could run at 4.4ghz easily and the ppd at those speeds would be insane makes me so mad we have to put up with these silly low clocks.
#75 | |
Modder
#76 |
Multimodder
Bad News
Hi All
I have heard that Scorpion49 who contributed to this thread has had to sell his folding kit to pay for hospital bills. I do not have any details but wish him all the best.
__________________
#77 |
Supermodder
Not so good.
Hopefully he gets better soon.
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. |
#78 |
Multimodder
Questions for Ben
Hi All
Ben have you been able to check the clock speed of your Xeons in Linux? I assume you did some stress testing in Windows to check out your overclock. I would be very interested to know if there is any difference. I do not have Windows installed on mine so I can`t compare like for like. From the research I`ve done I think i7z does show the true CPU clock speed. How many computers do you have folding? Your PPD is through the roof .
__________________
#79 | |
Supermodder
Slowlemon,
Try the folllowing in a console: Code:
cat /proc/cpuinfo The tail end of mine: Quote:
__________________
#80 | |
Modder
Its all a learning curve and probably like yourself started with quad core cpus and gpus and then realised only too late about bigadv16 and the insane ppd it puts out. I would like to run a 4p amd rig but the purchase price of the various parts while not bad value is just out of my range at the moment. I also think running sandy ep might be a bonus if an avx client is released but it is anyones guess if this will happen. It seems that avx gives a 2x boost but not all the Fahcore code can be vectorised so we most likely wont see such a huge boost. Its all meant to be fun and it is nice to see your machines running 100% 24/7 doing something useful plus the points system gives us some amusement and empties our pockets trying to keep up with each other which isnt good realy ! Food for thought is the next generation haswel xeons - 14 cores, 35mb cache, 20% increase clock for clock over sandy and 22nm with power saving enhancements. A couple of these will probably produce 600,000ppd+ and use 280w from the wall. Frightening isnt it and you can bet the good old ES chips will be on ebay ! P.S. just checked you folding output for the last couple of days and it looks like you have turned a couple of extras on, its not going to be so easy to overtake ! Last edited by Ben Lamb; 15th Sep 2012 at 20:17. |
| Thread Tools | |
