#81 |
Multimodder
Update
Hi All
I have spent most of this weekend experimenting with this system to try and understand the CPU throttling issue. So far it appears that everything is working perfectly. The CPU frequency scaling feature in Linux is working as it should do and does not seem to be limiting performance. The Intel turbo boost is working and the CPUs are throttling to stay within their design parameters. The difference between the two chips could simply be due to variations in manufacture. One is running at about 2220MHz and the other at about 2340MHz. I have been running with the slow CPU in socket 0 and the fast CPU in socket 1. I tried swapping the processors round to see if that has any effect but the system will not post with the faster CPU in socket 0. I think building a multi-socket computer using ES chips from Ebay is not straightforward .It looks like the only way I am going to get more speed is to overclock the base clock. Wish me luck.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. Last edited by Slowlemon; 16th Sep 2012 at 16:58. Reason: Typo |
#82 |
Cheesecake Nom Nom
good luck
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, GTX680 OC'd |
#83 | |
Modder
I have done everything I can to get mine running faster and nothing works. cpuinfo says the cpus are running at 2080mhz no matter what I do, I am hoping that it does not register turbo speeds. I have given up on it now as it was making me mad but no sign of these supposed 2.8ghz clocks. I recon it could be running at 2080mhz which is poop but these xeons must be awefully fast to produce decent ppd at this low speed. |
#84 |
Multimodder
Overclocking
Hi Ben
Yes that`s a typo, should be 2340MHz . CPUinfo will not show turbo speed, it shows base clock times base multiplier (104 x 20 = 2080MHz). I have been able to get my base clock up to 104MHz same as yours. When I try 105 it locks up and refuses to POST (code 34 something to do with memory).I tried increasing VSA to 1.100v but it made no difference so I have chickened out and left it at 104. I thought that the CPUs would throttle back to compensate for the increased base clock but they don`t, both processors have increased by 4% so they are now running at 2309MHz and 2434MHz. That will have to do until I can come up with something better.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. |
#85 |
Multimodder
Results
Hi All
The dual Xeon rig is back on Bigadv after I spent all weekend tweaking it to try and get more performance. With the 4% overclock TPF on P8101 has come down to 21m, 20s for about 176K PPD, an increase of 14K. Power consumption is up 5W to 245W, efficiency has gone up to 718PPD/W .I am very pleased with the performance of this system for the money spent. It was a big risk to order ES chips from an Ebay seller on the other side of the world and It has been an eventful build, but the results are so worth it . I can`t wait to see how Coolamasta gets on with his.
__________________
#86 | |
Modder
#87 | |
Modder
#88 | |
Modder
All that longterm power limt stuff in the asus bios is useless as you only get the boost for 32 seconds as that is the max the bios allows then it throttles down from 24x to 22x. There will be a hack to sort this - google throttlestop which is an app you can use in windows to stop throttling and lock turbo multis. We need to do this in linux, the asus board is a bit of a waste of time as the only overclocking we have is 4mhz on the blck. |
#89 | |
Multimodder
Your hardware is virtually identical to mine so I think it must be a software issue or possibly firmware. I am using BIOS 0703 but I doubt that will make any difference. I posted some of the settings I am using in Coolamastas thread (post 13) everything else is on default and or auto. Did you install the 64 bit version of Ubuntu? The version I have is ubuntu-12.04-desktop-amd64. Did you install the latest version of Thekraken? 0.7-pre15. Do you have NUMA and ACPI enabled in the BIOS?
__________________
#90 | |
Modder
#91 | |
Multimodder
I`m glad you got it sorted. I am sure Thekraken is a big advantage, maybe that`s what is missing from the Linux folding image? Or is it an older version? If you can pin down the problem then it will help other team members update their systems.
__________________
#92 |
Modder
Turned out that the older image used a kernel that didn't seem to make use of turbo boost so cores were stuck at the base speed. 12.04 enables turbo so it is faster.
#93 |
Multimodder
Thanks Ben. So it looks like people running newer hardware like Intel Sandy Bridge or AMD Bulldozer based CPUs should be using Linux with an up to date kernel. This is perfectly logical but I bet lots of people are using an older kernel because they "think" it`s faster.
__________________
| Thread Tools | |
