Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Aug 2012, 10:25   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Nvidia warns of continued 28nm shortages
Nvidia's Jen-Hsun Huang has warned that supply of its 28nm parts will be constrained until at least the fourth quarter.
http://www.bit-tech.net/news/hardwar...nm-shortages/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 13th Aug 2012, 11:38   #2
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
Hmmm... Is it me or is it always nVidia complaining about its process tech? And trying to shift the blame to TSMC. Very odd.
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 13th Aug 2012, 13:59   #3
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
Shame, guess we'd better leave prices sky high then ?
Hmmm....
__________________
Gigabyte Z87x OC-Force - i7-4790k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer Orange/Blue DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 13th Aug 2012, 15:34   #4
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Aye, long gone are the days when a high end gfx card would set you back a mighty £210 (9800GTX on release, only four years ago). High end atm is £399's worth of GTX680. Barmy.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 13th Aug 2012, 17:23   #5
ssj12
Hypermodder
ssj12 has yet to learn the way of the Dremel
Many other companies have complained about TSMC being slow. Nvidia is far from the only one.
ssj12 is offline   Reply With Quote
Old 13th Aug 2012, 17:30   #6
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
TSMC has been the limiting factor on many projects for over half a decade now.
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 13th Aug 2012, 17:36   #7
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
Problem is though, UMC arn`t on the bleeding edge and GloFo are also having issues.
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is online now   Reply With Quote
Old 13th Aug 2012, 19:29   #8
ssj12
Hypermodder
Can anyone tell me why TSMC hasnt built a new facility or two by now?
Old 13th Aug 2012, 19:34   #9
Harlequin
Harlequin's Avatar
they dont need one? its the yields from the fab process thats the issue not the size of the factory
__________________
Old 13th Aug 2012, 22:45   #10
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
Well you have to remember that outside of shrinking the die of the mighty 8800GTX/Ultra, there really weren't many fundamentally large differences between G80 and G92. It was cheaper because AMD at the time managed to at least recapture some market share with their Die shrunk RV670 (HD3870) but they were still lagging behind and the GTX280 was still in the works.
Of course the moment the released the GT200 we saw that it really did transcend G80/G92, but before that the reason for the high end being momentarily cheap was that there was no real high end at the time except for the Dual GPU 9800GX2.
Cost efficiency. It really isnt' efficient to invest in so many tools, optics and litography if the process which is still flawed is going to be replaced soon by a smaller node. Plus those tools are extremely expensive anyhow.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 13th Aug 2012, 23:29   #11
play_boy_2000
It was funny when I was 12
play_boy_2000's Avatar
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
could have something to do with the value of your currency going down the $h|tter...
http://www.xe.com/currencycharts/?fr...to=USD&view=5Y
http://www.xe.com/currencycharts/?fr...to=TWD&view=5Y
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Old 13th Aug 2012, 23:46   #12
Elton
Elton's Avatar
Or how about the fact that those times were anomalous? All other times the high end usually ranged at a higher 399 quid for the high end. Look at G70/RV5xx era. The NV40/RV4xx era. Look at all other instances in history and we see that the low has nothing to do with currency but rather a difference in the markets.
__________________
Old 14th Aug 2012, 02:10   #13
AndyBradley_0255
What's a Dremel?
AndyBradley_0255 has yet to learn the way of the Dremel
Yeah I remember getting two HD3870's as soon as they were released to replace a pair of X1900's for £160-ish each, and the HD4870/4850's were not much more than that either. High end/Top end GFX cards were loads cheaper back then.
AndyBradley_0255 is offline   Reply With Quote
Old 14th Aug 2012, 02:38   #14
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
They have. It's a $5Bn+ investment though. It seems from 40 and below, yield is just not high - especially for multi-billion transistor parts. They aren't ARM chips.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 14th Aug 2012, 07:55   #15
Harlequin
Harlequin's Avatar
http://www.reuters.com/article/2012/...8HB4HO20120611
they`ve only just got approval to build the 450nm factory
@play_boy_2000
in 2008 the pound was over valued against world currencies and had to stabilise lower
http://www.xe.com/currencycharts/?fr...to=EUR&view=5Y
same trend against the euro
__________________
Old 14th Aug 2012, 09:15   #16
Tynecider
Since ZX81
Tynecider's Avatar
Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.Tynecider is the Cheesecake. Relix smiles down upon them.
Hmm
Them: PROBLEM >>>
Us: REACTION >>>
Them: SOLUTION.
Translates to.....
Them: "Were short on material's" >>>
Us: "Oh no, We had better spend, spend, spend" >>>
Them: "Why don't you buy some of these".
But really means....
Them: "We're not making enough profit to keep the stock holder's happy" >>>
Them: "Let's advertise a scarcity of materials" >>>
Them: "And make sure we get rid of this magical stock of material's at full profit".
Or they genuinely could be telling the truth
Tynecider is offline   Reply With Quote
Reply
Tags
28nm, jen-hsun huang, nvidia, tsmc
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
