Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Aug 2012, 10:49   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Rootbeer brings GPGPU integration to Java
A new compiler, Rootbeer, allows direct GPGPU access from within Java - for some significant performance gains.
http://www.bit-tech.net/news/bits/20...otbeer-gpgpu/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 13th Aug 2012, 11:24   #2
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
Maybe Minecraft will finally run ok now!
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 13th Aug 2012, 19:12   #3
Crunch77
Modder
Crunch77 has yet to learn the way of the Dremel
Nice.
One of the more interesting bit of news lately.
Crunch77 is offline   Reply With Quote
Old 14th Aug 2012, 09:18   #4
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
can someone explain to a normal guy what does this mean :-)? now can games look better lol ? (less code, faster rendering)
Griffter is offline   Reply With Quote
Old 14th Aug 2012, 12:42   #5
OWNED66
Multimodder
OWNED66 has yet to learn the way of the Dremel
u can use opengl on monecraft
OWNED66 is offline   Reply With Quote
Old 14th Aug 2012, 12:42   #6
OWNED66
Multimodder
java will stop hogging cpu cycles
Old 14th Aug 2012, 12:51   #7
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
It means that Java applications can use those CUDA Cores/Stream processors to do some math on the graphics card instead of CPU. And because graphics card are a little bit (ok, a lot) quicker at some math, it is a good thing to have if you do lots of math in your application.
For you as a normal guy ? Absolutely nothing.
faugusztin is online now   Reply With Quote
Old 14th Aug 2012, 14:49   #8
lurker2b
What's a Dremel?
lurker2b has yet to learn the way of the Dremel
unless you bruteforce hashed passwords in java
lurker2b is offline   Reply With Quote
Reply
Tags
compiler, gpgpu, gpu, hpc, java, rootbear, syracuse university
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
