#61 |
www.^.nl
Thanks Bladesingerz
![]() Indeed ... wasted so much time when building d3sk cause of those missing plates. About the counter that was on the website .. check this out ![]() Mounting blocks ... love it! First the mainboard. And the cards on it for a picture.. Added some extensions. Glad I took time to test the hardware in front ![]() Ordered an EK-Bridge for the GPU's Never used them before. I like it. Cut out the grommets. And put them backwards in the 'firewall' Seems the BP fillports stay in place perfectly now. In the new design the holes and grommets have been changed. First fittings in place. The mess. Might be an idea for a drainpoint in the bottom later. Another funny thing ..... Glad this will be solved with the rubbertape under the glasspanel. ![]() First cables and extensions. Flipped all fans from rear radiators. (again 64 bolts...) Did this so the airflow from the fans work with the PSU flow. 3M Velcro for the RGB controller Found her spot ![]() Feeds for the fancontroller and pump on their spots Powersocket for 2 PSU's, screens and speakerset. Adjusted the cable length. RGP plug brought to other side of desk too. Preview with 'PSU-cover' A solution for the missing HDD-bay covers .. and a nice spot for the ssd's since I'll be using the other side of the desk for another pc now. Simple .. But effective ![]()
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com Last edited by l3p; 2nd Oct 2012 at 21:15. |
#62 |
www.^.nl
And another update with quite some photos
![]() Unpacked the reservoirs and put them on their spot. Also some more changes in the prototype .. more grommets for itx and m-atx. Starts to look like something. Also cut the heatfins again. I personally like it. Also an idea for the speakers. I know speakers should be positioned in front but tested it and I don't notice it Coincidence the finish of the sub is exactly the same as the desk powdercoating. First some extra holes for the fan/pump controller. Next prototype will have some mainboard grommets there. Glad those trays are aluminum ![]() Building in the speakers. There won't be any cable visible from the speakerset when I hide the sub + all cables in the legs. Measuring. Adjusting the speakers for long M4's And finishing it. Too bad the cone is blue, anyone any idea if cones are paintable? A solution so the fancontroller and RGB controller are ALWAYS on, no matter if there's one or two pc's running Works perfectly ![]() Extra power/reset buttons. Next proto there will probably be a bracket here. Also finished the holes for pump/fan cables. For this build I will seal the unused 5.25" slots. Next proto this will be different. The glue will be transparent when dried. Cut away some in the grommets, looks better. And some further again. Still in love with the bottom mainboard covers ![]() Time to move on with all sata cables. Also found out I didn't have sata extension cables yet for the right system. So ordered them too. For the SSD rack I will use cheap Velcro, I would damage the SSD's with 3M velcro when removing them ![]() Works perfect. Because we didn't have PCI-covers yet I ordered these. Because I chose real thick radiators because I thought I was going to do a single pc build I'm having small problems finding a spot for the second PSU. Sleeving the yellow sata extension cables Lets first use some black isolation tape. Even if you only see 3cm .. .yellow .. no way ![]() Also used the rubbers for the second PSU. Lovely music while modding ![]() Securing the pumps. Tube ready to go, first fittings find their spot. Had to remove mem again, quite narrow to get the fittings in properly And a little further again. Ok ... and then 11 days ago Asus requested if they could show 'Cross' on the Dutch Firstlook 2012 Event... not as a desk but built in their stand. Off course, I was so honored! This only happens once a year! And ... if I could built in the Maximus V Formula.... I did agree off course, been some real busy days the last week. So at this moment I'm a bit behind on the log, so some photos could show up but will make this up this week! For who does have pictures .. please hide them for a while ![]() (I did ask them to step away )
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#63 |
*learning english*
darn! $2k for table and still need to make HW modifications???
*head to ikea for $20 table and $20 jigsaw*
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#64 |
Retro Fan
This looks so amazing. Putting those speakers in the desk itself is pure genius.
I simply have to make a pc desk now. I've seen so many and gone "wow, I need to make of those" that i really need to now.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
#65 |
Hypermodder
Think you are kinda missing the point! These desks are WORTH the 2k anyday!!
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker Modding is addictive!! |
#66 |
01110001 01110101 01100001 01100011
Keep in mind the Peter's desk is a prototype and as such the changes he is making will be reflected in the final production version.
__________________
Mod of the Month Nominee February 2010: A380 Mod Sponsors: www.mnpctech.com, FedTech In Progress: The Anti-Mac Sponsors: www.mnpctech.com, BOXX NVIDIA ION Contest Spider PC Engineer at RedHarbinger:http://www.facebook.com/redharbingerinc |
#67 |
bit-tech sponsor
Oh man, this is gonna be nice...
the hardware alone is worth more than my car, ...actually, both of my cars!
__________________
Shop Our Case Mod Store We Ship International Orders! Client Builds / FIREFLY PC / DISTRICT-9 PC / Official STAR TREK PC / WOLFENSTEIN PC / LANBOY APOCALYPSE PC / CodeMasters DiRT Showdown PC |
#68 |
www.^.nl
I don't even have a car, my wife has a Deawoo Matiz
__________________
#69 |
Professional Sleever & Modder
awsome dude
#71 |
www.^.nl
That's exactly why I call it my wife's car, I only drive a Vito from work ever since she got those on
__________________
#72 |
www.^.nl
This week 2-3 updates
![]() Because the desk had to be running and presentable I still needed some things quickly. Because of the 4 reservoirs and 2 systems I needed more tube and stopfittings. Thanks again for the nice discount Freddy! And from Mayhems. And something I had here already a while to flush my other desk, that'll have to wait ![]() Love experimenting. Gotcha! ![]() Thanks for all the support Michael! Also needed for the second pc, again Bitfenix extensions. And something new I got from EK. My first CSQ design block. Again thanks a lot Eddy en Gregor! The package I got 3 days before the event. Very nice and complete package. Ready to swap. I do like it. Rogier .. TOP! Tomorrow another update with tubing and filling.
__________________
#73 |
Modder
Looks sweet, keep up the good job
#74 |
www.^.nl
Quite a puzzle with what I wanted with the in and outlets of the multi reservoirs and both loops mirrored.
It became a multireservoir extreme ![]() Measuring the reservoir brackets. Going to have the tubes to the pump of the left loop in the bottom. Again happy this part is aluminum. Done! And the first tubes. Also quite a puzzle again with all the small distances. Pump for the left loop. Might change this later.. Mainboard done, reservoirs next. With flasher. Left loop with flasher. And just the RGB LEDs Exiting for me .. first time filling. And another adrenaline moment for me, first time enabling the pump. ![]() Also need to find another solution for this, now that i'm running 2 pc's I don't need the long sata cable lengths to the raidcard. Maybe will order other cables later. Great feeling when you don't have any leaks. The Mayhems Pastel and red dye additives. I was warned this could fail with such a big loop ![]() Here I forgot to close one stopfitting after disabling the pump... Glad is was easy to clean ![]() Adding the Aurora, it was a bit scary at the start. But got the result I wanted one minute later. Another exiting moment.... But it boots with the desired temperatures ![]() And a video of the loop, filling and mixing. Got the Maximus V Formula in. Only one day to go, so started right away on the second loop. Meanwhile testing and installing the left system. Raw fingers of all that tube ![]() Again exiting.. This time premixed before filling. Mayhems Aurora, cool stuff ![]() But also creepy. Both loops running. Because there's a team of helpers ready to get the desk one floor down.. quickly close the panels without any management. Ready to go! Later today the migration.
__________________
#75 |
MODfiend.. ~twitch~
now that is one MONSTER desk!!! just to much to comment on so im just gonna go twitch in a corner babble-ling nonsensically.. excellent work l3p.. just amazing!!
__________________
Ω Omega Desk Ω |
#76 |
CNC mad!
So nice man, love the way its coming out! - May have to steal the ram heatsink idea if you don't mind..
__________________
'You had my curiosity, now you have my attention' |
#77 |
Supermodder
Love the looks on that coolant man, what products did you exactly use? And does it react to any UV?
I was tempted to come to Utrecht and see it for myself! |
#78 |
↓ Don't trust that face!
-Totally drooling over this.
You can paint the speakers, but on such a small set it might change the performance noticeably. Avoid painting the foam edges at all costs. If you have an extra slot on the board you could use some memory sinks for PCIe covers too.
__________________
#79 |
Supermodder
****ing love it.
Im too drunk to say amny more
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb Coolermaster 600w Silent Pro Modded Lian Li PC-0700 |
#80 |
I think we can make that fit
WOW
Very nice desk, I showed it to my wife and now thats what she wants for a desk now instead of selling one kidney for a desk I'm gonna need to find another body part to sell to get a 2nd one. My wallet cried when i seen the price but I bet it would be worth every penny. Do you give a military discount? Subbed and 5 stars
__________________
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses |
| Thread Tools | |
| View Mode | |
