Reply
Thread Tools View Mode
Old 13th Nov 2012, 10:08   #121
krebs
What's a Dremel?
krebs has yet to learn the way of the Dremel
Hello L3P,
Your projects are amazing!! Congratulations!!
I'm trying to do a WC project inspired in yours monsters desk. I'm looking the rubber grommets to close the holes where the wires go, but can not find models like yours, that are very optimized. Until I found a Chinese site, but did not respond (I guess they did not understand my English). Could you help me with some information on where I can find rubber grommets at least similar to what you used?
thank you
krebs is offline   Reply With Quote
Old 13th Nov 2012, 15:46   #122
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Welcome and thanks krebs!
We had them manufactured ourselves and it's pretty expensive a first time :/
However, the place where I did found them:
http://www.corsair.com/us/parts/case...ries-800d.html
http://www.corsair.com/us/parts/case...ries-600t.html
Goodluck on your build!
__________________
Preparing: Raz3r D3sk
Running : L3p Parvum
Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 19th Nov 2012, 21:12   #123
l3p
www.^.nl
l3p's Avatar
Played around with some acrylic remnants this weekend.
Not going to order large amounts of acrylic for these prototype legs/build (hint :P )
Once you're busy I got the tendency to keep improving it.
Really love this cutter.
Would love to do the small ring too.
I had 3 small pieces of black mat, transparent and glossy acrylic, think the glossy looks best.
Testing it on the 'UV bench'
Drilling the holes.
Maybe I will add a ledstrip in the future. (would need to saw in the legs)
Next leg .. next weekend
Didn't have much time to play with the hardware yet.
However, on request, here some temperatures of the CPU/GPU with a bench of the SSD's on the left system.
And some temperatures of the CPU/GPU with a bench of the SSD's on the right system.
__________________
Old 19th Nov 2012, 21:28   #124
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Loving the logo man, looks very good when its glowing.
Bladesingerz is online now   Reply With Quote
Old 20th Nov 2012, 10:36   #125
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Thanks for the test very nice read speed. But write speed is kind of slow ?? In what raid config u r using ??
dream1 is offline   Reply With Quote
Old 20th Nov 2012, 13:55   #126
dream1
Multimodder
dream1's Avatar
Oh and one more thin. For stabilty use the best test for your CPU is IntelBurn test 2.6.
If you cpu can stand this then its ok. For an exampel Prime95 is same as pointless it dose not strees cpu @ all. Even rendering in 3d stress more cpu.
Old 20th Nov 2012, 22:07   #127
l3p
www.^.nl
l3p's Avatar
Thanks Bladesingerz!
In both, raid0 and 5 I get the same slow write speeds. Still have to figure that out :/
Wasn't able to find 2.6 so did it with 2.54 on the 'very high' setting.
Got a little warmer now.
__________________
Old 21st Nov 2012, 16:30   #128
dream1
Multimodder
dream1's Avatar
Yeah the IntelBurn test shows the maximum what CPU might go. And if it does not survive that then u have the problem. But your stats are still good form cooling. And for the raid card maybe to use better raid card like LSI SAS 9207-8I PCIE 3.0 realy good one. Or mobo wich one has a good raid chip on it like AsRock x79 extreme 11 or AsRock z77extreme 11 both good mobos.
Old 22nd Nov 2012, 09:43   #129
Raikkok
Multimodder
Raikkok's Avatar
Raikkok has yet to learn the way of the Dremel
Hi l3p.
I asked you on facebook the next thing, but i didn´t find reply about it..
In that desk, are there any frontal fans or behind fans to enter/out the air or no?
thanks.
__________________
"Raikkenstein Mod" http://forums.bit-tech.net/showthread.php?t=215645
MOTM January 2012 Winner
Raikkok is offline   Reply With Quote
Old 22nd Nov 2012, 15:36   #130
l3p
www.^.nl
l3p's Avatar
Hi Raikkok
Sorry, guess I missed that one.
Here you can see my current caseflow.
The front is separated from the back with airflow.
Front compartment has 3x 120mm in and 3x 120mm out
Backside has 4x120mm in and 4x 120mm out
For this build I used all the possible radiator space.
__________________
Old 22nd Nov 2012, 16:03   #131
Raikkok
Multimodder
Raikkok's Avatar
Thanks L3p
So.. you use the same space for the radiator and the airflow desktop no?
Isn´there fans without rads no?
__________________
Old 22nd Nov 2012, 16:17   #132
l3p
www.^.nl
l3p's Avatar
Yes, however even with 2 systems stressing inside the air still doesn't warm up that much.
With a single system you could have 2x480 radiators with 8x 120mm and 6 separate 120mm fans for airflow.
You can't have it all I guess
What is it what you would have wanted to see?
__________________
Old 22nd Nov 2012, 16:56   #133
Raikkok
Multimodder
Raikkok's Avatar
perfect..
i´m planinng something "similar" but with wood as material
and probably will have two parts like yours, one as server and downloads, and the other one hardware part for gaming
__________________
Old 23rd Nov 2012, 01:42   #134
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
I wanna know when it's coming out and how much it pay's? and could i get any real spec's from it, im planning to do a mod from the table, kinda my own looking from it, while of course keeping the honor of the maker at the same time.
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 24th Dec 2012, 17:31   #135
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
Nice Job on the Logo, you may want to put it in more places as it looks awesome! Now what is the next project so I can druel and watch again as you create another master piece! I expect a PM for the next one so I can watch from the beginning.
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 3rd Feb 2013, 20:56   #136
l3p
www.^.nl
l3p's Avatar
It has been over 2 months, time for a small update.
Needed some time to finish some things up and save up money for the screens and stand.
In the mean time also finished up a small passive cooled Htpc mod 'L3p AlCu'
And busy on a watercooled Acrylic build 'L3p - Parvum'
Also gathered a small collection of 'Desk Pc' builds I walked into the last few years.
Desk pc build collection.
(Send me a pm if you want yours added )
So here the photos from the last 2 months.
First bought a second hand floorstanding monitor mount.
Decided to buy this since I like to work with the desk and hardware inside and adding another 25Kg to the existing 80Kg ..
Dell 17" mounted for the looks .. bit small
Tested some other stuff in the meantime with the desk and some hardware.
And the first one out of 3.
Was in love with the design since day one.
Few weeks later also got the second one.
Still need to find a solution for the 'missing' Vesa mount.
(Sometimes you have to sacrifice for design)
Warranty voided .. but the leg is off :P
The original Vesa mount from the RS Stand won't work on the 1.5mm plastic.
So thinking of something else.
Will be be the fixation from the original foot.
Gladly have some 15x15mm aluminum bar left.
Also glad Asus and RS work with metric
So some drilling and tapping.
And assembled.
First one hanging like a rock!
2 outside monitors will need a small different way but should be no problem.
Waiting for the third monitor
__________________
Old 25th Feb 2013, 21:53   #137
l3p
www.^.nl
l3p's Avatar
Small update again.
First the gaming package for this build from SteelSeries.
And made the two other monitor supports.
The photos will explain it all
At this moment I'm fully investigating a problem I had with the memory since the start.
The mainboard doesn't recognise the memory from slots B1 and B2. (More info here)
Seems I got scammed with a second hand cpu
No idea what to do yet...
Hopefully soon the third monitor
__________________
Old 25th Feb 2013, 22:11   #138
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Looks awesome!
Tip: If you find that RS stand you bought has gap between monitors,send it to RMA because 70 % of those units are faulty.
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Old 26th Feb 2013, 09:37   #139
thegyufi
on air
thegyufi has yet to learn the way of the Dremel
Hi l3p and good work with your monitors stand !
I have an idea for you (I didn't read all your blog, so sorry if it already posted or realized !)
Why don't you use your two lamps with RGB lights like this system:
http://www.youtube.com/watch?feature...&v=-hVcL2swTmA
I don't know if it's possible or complicated but I just see this video before seeing your blog
__________________
[project log] Apple Cube
thegyufi is offline   Reply With Quote
Old 26th Feb 2013, 15:14   #140
l3p
www.^.nl
l3p's Avatar
Originally Posted by Pranja View Post
Looks awesome!
Thanks Pranja!
Guess I'll fix it myself then since it's already second hand
Yeah been thinking about an Ambilight system, however I think it'll make you go nuts with all that light
You did see this video?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
