Reply
Thread Tools View Mode
Old 9th Sep 2012, 17:12   #21
Yaka
Supermodder
Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.Yaka is a hoopy frood who really knows where their towel is.
wouldnt try it mate, unless you have the proper equipment,
the coolance blocks look good in your case as they are
Yaka is offline   Reply With Quote
Old 10th Sep 2012, 16:13   #22
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
I think the copper block would stand out but it does not really go with the color scheme so far so not sure if I would change it out. Looking good so far. Keep it up and were waiting on MOAR updates!
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is online now   Reply With Quote
Old 11th Sep 2012, 17:44   #23
Wissel
Minimodder
Wissel has yet to learn the way of the Dremel
Decided to keep the blocks as they are at the moment
I'm going to keep the block as it is for the time being, would still like the copper Raystorm though, just spent way to much already for now
Small Update
I've spent the last few days cutting, filing and sanding all the panels ready for painting, took loads of pictures and didn't realise I hadn't put a memory card in the camera
...so sadly not much to show.
The new panels have had their first coat of primer now, here's a little taster:
Tomorrow I'll be doing a final sand of all the panels then more primer.
Wissel is offline   Reply With Quote
Old 11th Sep 2012, 18:50   #24
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
it looks very good
KoSoVaR^ is offline   Reply With Quote
Old 13th Sep 2012, 16:56   #25
Wissel
Minimodder
Originally Posted by KoSoVaR^ View Post
it looks very good
Thank You
A Little Update
All the panels are now painted so I can start assembling tomorrow. I'll set up proper lighting then and take some decent pictures but I'm really pleased with how this bit turned out so couldn't resist posting a quick pic:
The paint has come out great, just needs polishing now.
Old 13th Sep 2012, 17:47   #26
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Awesome drizzled in win sauce.
Subbed
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 22nd Sep 2012, 20:54   #27
Wissel
Minimodder
Subbed
Thanks
Very quick update[/b]
Had a hell of a day putting bits of this together today, one of those ones where if it can go wrong it will
Anyway, overcome most problems and will post more pics probably tomorrow once I have lighting again (both white light bulbs blew today).
The motherboard is all plumbed in now, with a bit of luck tomorrow the loop will be finished and I can test it.
If that goes well I can start fitting fans/switches/front DVD connection/wiring/etc/etc..........
(will be finished one day)
Old 23rd Sep 2012, 18:26   #28
Razbit
Minimodder
Razbit's Avatar
Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!Razbit - it's over 9000!!!!!!!!1!1!1!!!
Looks good so far
In case you hadn't noticed, I am actually making a mod based on R4, which goes on nearly the same name (Redefine R4). I didn't copy it from you though..
Keep up the good work mate, subbed.
PS. Love the zen of your mods outlook
Razbit is offline   Reply With Quote
Old 20th Oct 2012, 15:09   #29
Wissel
Minimodder
Originally Posted by Razbit View Post
Looks good so far
Thanks very much and good luck with your build.
Sorry for the lack of updates, I've had a small delay due to a change in living arrangements. We now have much more space but the house needed modding
Most rooms are now finished apart from my new office/video studio for which the parts will be here for later this week. This PC is being built for this purpose (need it for work).
I also have a new DSLR arriving this week (went for a Canon 600d due to its great video capability's) so should be able to get some good shots once the studio is finished as it has permanent photo lighting set up.
With a bit of luck I should be updating this thread in around 10 days. I'll probably try the new video studio out at the same time and post a video update although it will be unedited as the editing will be done on this build.
Old 20th Oct 2012, 16:24   #30
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
In the future it would notable to remember you dont need to run the RPM wire (yellow) on all of the fans. Since youre using a fan controller its no biggie, but if you were to run those off a mobo header the signal would get confused and the reading would be useless.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Old 20th Oct 2012, 17:32   #31
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
Wow nice mods there, I really like how you manage the fan controller, the PSU, and the reservoir.
Also the dark colors look nice in the overall project.
__________________
Per me si va nella città dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 30th Oct 2012, 20:06   #32
Wissel
Minimodder
Cheers.
Update 30/10/2012 - Water Loop Finished
I've had a little time the past few days to get on with this build and at last the water loop is complete. The thing is there are so many joins in this loop I thought I'd better take some photos and get this update posted before I fill it with water
This is the view in the top bay with the front off:
The T piece coming from the top of the rad is a bleed port to make filling and draining easier. This sits nicely on the top next to the fill port:
coming down from the T is the return pipe back to the res:
The res is an Alphacool and below is a Lamptron FC6 fan controller. Below the FC6 and barely visible in this pic are the backs of the two LCD temperature displays, one showing the air temp and the other the water.
The pipe on the left leads down to the pump in the bottom of the case:
The pump is hardly visible in the pic, the two fittings in the middle are the inlet and outlet though. From the pump the loop attaches to the bottom rad then out the top and into another T fitting. The right side of this fitting houses the water temperature sensor, the other outlet to the bottom of the motherboard. There is also a drain port at the bottom.
The loop starts in the bottom right of the picture going to the first motherboard block, then to the CPU, then the second M/B block and finally the GPU's. I originally had the GPU's in serial but swapped it over to parallel to make the loop a little less restrictive. Actually I just preferred the look of it this way.
The loop then leaves the GPU's and travels into the top chamber and back to the rad.
That's it for now - time to fill it up
Old 1st Nov 2012, 15:01   #33
Wissel
Minimodder
Quick Update - First Boot
After filling the loop two nights ago and testing it for a day I decided to wire it up to see if it actually works. Thankfully it does and I'm really pleased with it.
Its only running at stock speeds at the moment but these are the temps so far:
The rig has been on for a few hours and I've run Prime95 for an hour where the CPU temperature peaked at 45 degrees (as you can see in the pic) so pretty happy with the temps so far. This was with the rad fans on as low as they will run and completely silent.
For ease I wired it up using the stock corsair cables but I like the way they look with this build so may keep it this way. I'm waiting for some LED's to arrive for the lighting, once these are here and fitted I'll fit the case fans and shrouds.
Then its just ordering the side panels and a few finishing touches. I held of ordering the sides until it was all together to make sure my measurements from drawings were exact.
I'll update again once the LED's and fans are fitted - hopefully within a week
Old 9th Nov 2012, 06:41   #34
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Nice project
Congrats for the nomination on mod of the month
Waynio is offline   Reply With Quote
Old 9th Nov 2012, 08:27   #35
Wissel
Minimodder
Originally Posted by Waynio View Post
Nice project
Thanks Waynio, thought you were joking when I saw this post
Really surprised to get nominated (and pleased )
Old 9th Nov 2012, 09:26   #36
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
great work - I like the clean lines and organized look of the build.
Karrek is offline   Reply With Quote
Old 9th Nov 2012, 09:57   #37
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Brilliant job!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 9th Nov 2012, 10:27   #38
Ripitup121
MMMMMMm watercooling....
Ripitup121's Avatar
Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.
Wow Lovely Mod, do you not think the SLi bridge needs some black film on it too though. (might be my OCD kicking in). Great Job though.
Rip
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!!
Ripitup121 is offline   Reply With Quote
Old 11th Nov 2012, 11:39   #39
Shuttlemodder
Ultramodder
Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!
Wissel,
That is mighty impressive fora first go at sleeving!
More so the whole project has come together nicely!!
Has given me a couple of ideas for my next project
Mod on dude!!
Shuttlemodder is offline   Reply With Quote
Old 11th Nov 2012, 12:02   #40
Wissel
Minimodder
Cheers Karrek that's the look I like - hoping it will look much cleaner once the sides are ready
Originally Posted by Editor22 View Post
Brilliant job!
Thanks
Rip
Def not OCD (although I think most modders are a little OCD) the SLi will have a black aluminium cover to match.
Originally Posted by Shuttlemodder View Post
Wissel,
Mod on dude!!
Thanks, sleeving was much easier than I thought it would be. Glad it gave a few ideas
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
