Reply
Thread Tools View Mode
Old 11th Nov 2012, 12:43   #41
FannBlade
Minimodder
FannBlade's Avatar
FannBlade has yet to learn the way of the Dremel
Very ingenious layout! That's a lot of hardware you got stuffed in there.
Great looking build.
FannBlade is offline   Reply With Quote
Old 20th Nov 2012, 15:23   #42
Wissel
Minimodder
Wissel has yet to learn the way of the Dremel
Thanks.
Small Update - Lighting
I was originally going to make the LED's from scratch and plug them into a Mod Smart board but I decided to just buy the Mod Smart LED's as well.
The Mod Smart board is a cracking little thing that can take up to 20 LED's and powers from a single molex. It also has a 2 pin switch connector if needed.
Before instating the lights I did a quick check to make sure they all work
Then installed them and added a Bitfenix LED strip to the bottom of the case to up-light the board
Not the greatest pic I know but I'll take some better ones once the sides are fitted.
Also, the studio/office is taking shape now, here's a couple of pics
I've also sent the side panels of to Pulse Modding today
and here is how they should look once they return
I'll update again once the panels are here.
Wissel is offline   Reply With Quote
Old 20th Nov 2012, 19:27   #43
Telefonskaft
Minimodder
Telefonskaft has yet to learn the way of the Dremel
Damn that looks really good!
__________________
Lurking
Telefonskaft is online now   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
