Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 18th Aug 2012, 11:21   #1
Archtronics
Mod Master
Archtronics's Avatar
Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.Archtronics is the Cheesecake. Relix smiles down upon them.
Ft03 mini mod Now with pics
Hey
So ever since the silverstone ft03 I always wished they had a smaller ITX version, my prayers where answered in the form of the silverstone ft03 mini.
The case itself arrived this morning so now is the time to start planning.
Plan of action so far:
Reconfigure the internals to fit a full size psu and two water cooling loops.
The exterior will essentially stay the same as the panels are really good quality as they are. I will be adding a window, new power buttons and some etching.
The main part I will be changing is the plastic top which is rather tacky compared to the rest of the case, I'm hoping to use solid piece of aluminium carved into a steampunk themed design to create a bespoke top with some sought of watch inspired mechanics.
Design themes will be minimalist, mechanical and power.
That's it for now I will be updating the thread with ideas and images soon.
Archtronics is offline   Reply With Quote
Old 20th Aug 2012, 17:19   #2
Archtronics
Mod Master
Right picture:
Not sure why there is so much room for cables and I want to fit a 240 rad in there so cut and filed the inner frame.
Reassembled and testing the position of the PSU, Fits perfectly will need the corner cutting off psu possibly.
Now to reattach the top part so put some paint on the screws to see where to drill.
Coming up next: Drill and attach top, extend front struts, create panel to enclose PSU area.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
