#41 |
↓ Don't trust that face!
There's always the option of "owner distressed." -Or "shipping distressed." The post office seems to be pretty good at it. Just pack it in scouring pads before you send it out.
__________________
#42 |
Supermodder
Great point! Since it has to go to Australia, it would have plenty of time!
__________________
Pfaffen Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases |
#43 |
Multimodder
This is a very interesting case mod, good luck to you
__________________
Cm Storm Enforcer|Intel i5-2500k|Asus p8p67 pro|8gb DDR3 Corsair Vengeance LP Blue1600mhz|EVGA GTX 460 1gb| Arctic Cooling Freezer 13 Pro|Corsair Force 3 60gb SSD|Hitachi 1tb Hard Drive| Windows 7 Professional|
#44 |
Supermodder
On to the small parts. Each is 1/8 in wide and is half lapped to fit.
__________________
Pfaffen Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases Last edited by Pfaffen; 25th Sep 2012 at 17:28. |
#45 |
Supermodder
Now that they are dry, its time to clean them up.
Clipping off the long edges on all the sides... ![]() Some sanding... ![]() and more sanding...
__________________
#46 |
Supermodder
Here are the windows sitting in the door frames
![]() Now to cut out the holes ![]() One down... 7 to go...
__________________
#47 |
The Millionaires are back!
Keep the updates coming
__________________
i7 2700K @ 4.7Ghz // Asus Gene V // 8GB Corsair Vengeance LP // Asus GTX580 DirectCUII // Samsung 830 256GB // 2x2TB Samsung F4EG // Corsair AX850W // Antec P182 // Thermalright Silver Arrow Cooler // Dell U2412M HTPC: 2500K // Asus Gene IV // 4GB Ram // OCZ 120GB // Be-Quiet! CM 580W // Silverstone GD08 // Synology DS209 4TB
#48 |
Minimodder
Excellent idea for a mod!! Very much looking forward to seeing how this turns out
Good luck! |
#49 |
Supermodder
Thanks!... Been traveling a bit, so progresss has slowed.
__________________
#50 |
Supermodder
Here are the posts and doors.
![]() Here is a shot of the doors with the sign dry fitted. ![]() Here is the inside looking out. The doors are mounted.
__________________
#51 |
I'm insane, not stupid.
Hmm, it looks bigger on the inside..
Great work dude, loving it so far
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
#52 | |
Supermodder
__________________
#53 |
Supermodder
Time for some glue-ups
![]() Make sure the computer it was designed to hold fits! ![]() Top view without the roof.
__________________
#54 |
Supermodder
First coat of primer
__________________
#55 |
Supermodder
Compared to the model.
__________________
#56 |
OOOF. It always hurts to see the primer go on.
__________________
#57 |
Supermodder
__________________
#58 |
Supermodder
Here we are in the spray booth.
![]() First can of paint down... two more to go... ![]() Well ok, 1 and a half to get here.
__________________
#59 |
Multimodder
Nice Paint Booth
your paint booth caught my eye. Is the box fan exausting air (drawing air in through the furnace filter)? Do you have it on as you are painting, or just afterwards to help the item dry? I'm intrigued - and want to build my own now.
Great paint job - I agree that it is a shame to paint the beautiful wood, but it wouldn't look right if it wasn't blue. great work so far. I'm interested to see how you fit the components... |
#60 |
Supermodder
I use it to pull air through the box. While I am painting, I have the front open and the fan pulling air. To dry, I pull down the front flap and seal it. Causing the Air go go through the filter.
__________________
| Thread Tools | |
| View Mode | |
