#101 |
What's a Dremel?
It's just an USB hub that has its own separate power supply. So they provide their own power to the hub ports instead of drawing all power from the port on your computer. They are useful when you need to attach multiple power hungry devices to a single USB port.
#102 |
Squid
Thanks crudbreeder!
#103 | |
Supermodder
as the other guy said, a normal hub with a net adapter.. if you have 3 usbports they might all be on the same power =/
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#104 |
Squid
Back after holidays with NEW hardware. This arcade beast deserves something better than tip founds. I'll have better airflow in there from now on.
The Gigabyte GA-H55N-USB3 Mini-ITX, 8 gb RAM and an i3 ![]() A 60GB SSD from Intel and pain-in-the-*ss-to-mount cooler Scythe Shuriken ![]() Also got my ebay "unbranded" controllers. Good simple PCBs inside for easy soldering and no driver issues, but the range!!! Aprox 2 meters(!?) Soooooo cheap So I had to throw them away. Going to give those xbox controllers one more chance.![]() Anyway, installed OS on the new HW ![]() Laterz! Last edited by quizz_kid; 12th Jan 2013 at 01:48. |
#105 |
Squid
I´ll really have to finish this one soon........
#106 |
Retro Fan
Nice hardware. Gotta love those ITX boards. Is it an Ivybridge I3? An arcade rig like this does deserve some great hardware. Can't wait to see this finished.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
#107 | |
Fenrir The Wolf
@quizz_kid: Too bad for those controlers. But I believe there is a way to exted the range with better antennas.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#108 | ||
Squid
Tiny update: Decided to go back to the xbox-PCBs. After a lot of precision soldering I managed to get it all working. Here´s the guts of the detachable joystick pads. A lot of wires in there ![]() ![]() But I´t looks much better when I cover them with these egg white inner protective plates. ![]() Here´s a close up of the 4-8-way switching of the joystick. Pretty simple, but elegant I think. ![]() And here´s when the outer plates are attached. Hope you´ll like it!
#109 |
Supermodder
wow
__________________
#110 |
Squid
#111 |
Squid
Finally finished!!
No text today, I´m just gonna let the pictures speak for themselves. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And here´s a video I made, if interested in how it actually works: Thanks for watching / Quizz
#112 |
Fenrir The Wolf
That looks awesome Quizz.
About that antennas, you should check what antennas are build in controler and usb receiver. There is probablay something like extended pcb or flat cable with "extra" conduit on it in maze or spiral shape. That is how cheap antennas are made. You can enhace range simply with soldering something like paper stample on it. And may I say again-awesome project. And one question-the wood you used for the build is walnut,right? Is it good type of wood for laser cutting?
__________________
#113 |
Scratchbuilder
Shut up and take my money!
__________________
Scratch builds | Cold Winter | CURV3D | The Red One | Casemods | BarPC | Check out my facebook-page where I post everything about my mods. Like/share if you want to.
#114 | |
Squid
I´ll gladly do that =) Thanks friend! |
#116 |
Never stuck with stock@Hotmods.net
Drooooooooooooooool
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#117 |
What's a Dremel?
Great job ... Amazing work of art
#118 | |
Squid
![]() Nutty nutty boy... Thanks! Thanks AbKaRy! Appreciated. Took some photos of the mashine running the beamer today, hope you´ll like it! ![]() ![]() ![]() ![]() ![]() ![]()
#119 |
So wonderfully geeky.
__________________
#120 |
What's a Dremel?
It's simply amazing
| Thread Tools | |
| View Mode | |
