#1 |
Supermodder
I gone and done it
Just ordered the following, which might get delivered this Saturday.
![]() ![]() ![]() SuperMicro CSE-748TQ R1400B chassis dual redundant 1400w PSUs, Black Motherboard: SuperMicro H8QGi-F motherboard RAM. 4GB ECC reg. 1333MHz Samsung original x 16 AMD Opteron 6234 12 core CPUs 2.4GHz x 4 Supermicro Heat Sinks SNK-P0043P x 4
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. |
#2 |
CHMOD bit-tech 777
WOAHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI | | Silverstone 1200W | Corsair 650D | LG IPS225V X 2 | |
#3 |
Fap fap fap
WOAH, PICS?
#4 |
Another CPC refugee .....
Does the misses know
![]() (I'm guessing there's not much change from £5k) |
#5 |
Cheesecake Nom Nom
48 cores
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, GTX680 OC'd |
#6 |
Multimodder
Hi Scorpuk
Wow, that is some very serious hardware .Keep us posted.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. |
#7 |
Supermodder
Well, er um they came back with an offer of £80 extra each for 6274's and I said yes. So that's 64 cores.
![]() There's over £1k change. that's all I'll say. ![]() I think I'll be working 7 days a week next month. ![]() Oh and my plan for putting it out in the garage may get escalated. Apparently on start up it will sound like a harrier jump jet and needs 2 power leads. Or some sound proofing pedestal.
__________________
#8 |
Folding in memory of my father
Planning to overclock?
__________________
#9 |
Supermodder
I dont think I will.
__________________
#10 |
Cheesecake Nom Nom
OMG cant wait for pics!!
__________________
#11 |
Thinking about which mod to do 1st.
Seriously impressive piece of kit. I eagerly await your build log....
__________________
#12 |
Is the daddy!
PICS!!!!!!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#13 | |
Folder of the month April 2012
![]() Looking forward to the pics and what PPD you get.
__________________
#14 |
There is no rep for awesomeness.
Moderator
That's a gratuitous waste of a lot of money on expensive, frivolous computer hardware...
Son, I is approve.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#16 |
Supermodder
It didnt arrive today.
![]() Will have to wait.
__________________
#17 |
My understanding is the passive heatsinks you've purchased are designed for the 1P chassis.
You may well need additional cooling to fold 24/7 with your set up as your chassis is designed for active CPU cooling. I just fitted 92mm case fans to my P0043s with blutak and cable ties which proved effective. I shall be most interested to see what temps you achieve to compare to my Xigmatech case. Good luck
__________________
#18 |
Supermodder
Yeah I think I might.
But the case has 2 sets of 3 fans and an airshroud over them to ensure the air only goes over the cpu's. Will see what I get next week when I get it.
__________________
#19 |
I can assure you that you won't need additional cooling - you will have hurricane force cooling with this SuperMicro case setup. The downside is the noise, so for this reason alone you might want to make some tweaks with the cooling ....
#20 |
@ Doc,
What CPU temps do you get with your 4P setup when folding ?
__________________
| Thread Tools | |
