Go Back   bit-tech.net Forums > Technology > bit-tech Folding Team
Reply
Thread Tools
Old 26th Aug 2012, 21:21   #21
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
About 45DegC ..... I'd much rather the temps went up and the noise went down, but in discussions with the SuperMicro engineers, it seems there's a limit to what else I can do settings-wise with the BIOS
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 27th Aug 2012, 07:13   #22
One_Box
Folder of the month April 2012
One_Box has yet to learn the way of the DremelOne_Box has yet to learn the way of the Dremel
My Xigmatek with 2 additional 140mm case fans in the roof is giving an average processor temp. of 37 DegC (chomping a 8101) at an ambient of 18.4 DegC. Luckily it's also very quiet so will be deployed in the house during the winter to aid heating.
__________________
Folding stats
Folding stats
One_Box is offline   Reply With Quote
Old 27th Aug 2012, 07:52   #23
DocJonz
DocJonz's Avatar
That doesn't seem too much different deltaT-wise, as my ambient is 25DegC - I would have expected that with your HE processors and all the fans that things would have been cooler, but I guess you have the added benefit of silence!
I don't want to butcher my system just yet(!), so I might look at making some fan brackets for the HSF's to see what effect additional direct cooling has ..... I've determined that I only need the fans to reduce by a further 10% for the noise to be much more acceptable.
__________________
Folding stats
Last edited by DocJonz; 27th Aug 2012 at 08:27. Reason: 10% reduction comment added
Old 28th Aug 2012, 06:30   #24
One_Box
Good luck with the brackets Doc, well worth a try I would have thought.
__________________
Folding stats
Folding stats
Old 28th Aug 2012, 10:07   #25
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
Niiiiiiiiiiiiiiiiiiiiiiiiiiice some great hardware there, look forward to build pics and PPD
For my next high-power build I can't decide whether to go for a 4P set up or an SR-X rig with dual 8-core/16 thread xeon CPU's making 32 threads total with a nice overclock or an AMD Opteron rig like this with 48 cores but at a lower speed.... hmmmmm
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - EVGA GTX 980Ti | Alienware 13 Laptop, i7, Dual M.2 SSD's, 16GB and Graphics Amp
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 28th Aug 2012, 13:00   #26
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Finally got an update.
City Link tried to deliver yesterday instead of last Saturday as paid for.
Unfortunately wont be able to pick it up until Friday / Saturday as work is in the way.
Oh well.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 28th Aug 2012, 13:25   #27
Slowlemon
Multimodder
Slowlemon has yet to learn the way of the Dremel
2P Xeons
Hi Coolamasta
The E5 Xeons can not be overclocked at all in the way 1366 Xeons can. The multipliers are locked and higher CPU straps don`t work. You can increase bclk but the highest stable value I have heard of is 105MHz. The most promising avenue is Turbo Boost. The E5 2650 has a base clock of 2.00GHz but without any changes it will turbo up to 2.4GHz on all cores or 2.8GHz on 2 cores.
Scorpion49 says you can trick the CPU into thinking it has a 130W TDP and then it will run at 2.8GHz on all cores. Xeon thread This may work on a 95W low bin part but how do you trick a top bin part into thinking it has a higher TDP.
The locked down nature of the E5 Xeons makes the EVGA SR-X irrelevant as an overclockers board. Check out the SR-X review on OC3D-TV, and the Asus Z9PE-D8 WS. Asus also make a Z9PE-D16 server board, Supermicro and Tyan have LGA2011 boards.
__________________
Fold till it hertz.
Folding stats
Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7.
Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04.
Slowlemon is offline   Reply With Quote
Old 28th Aug 2012, 14:34   #28
coolamasta
coolamasta's Avatar
Ahhhhhhh thanks for the info Slowlemon, I've not done any research yet into the E5 Xeons so didn't know that but it would make perfect sense, why would Intel unlock the multiplier on a Server processor as they would never intend for them to be overclocked...
Thats changed my thinking all together and maybe I will look into the 4P Opteron route then, hmmmm will have to have a think about it and do some research, will watch those reviews you mention cheers
__________________
Old 2nd Sep 2012, 02:04   #29
Ben Lamb
Modder
Ben Lamb has yet to learn the way of the Dremel
Hello fellow folders just wanted to add a little food for thought when considering the 4p opteron vs sandy xeon routes. What happens when an avx accelerated folding client is released ? Only the sandy xeons and interlagos amd chips have avx functionality, is this worthy of consideration or not ?
P.S. have stated folding for the team again and will contribute when I have spare cash for the lecky meter !
Ben Lamb is offline   Reply With Quote
Old 2nd Sep 2012, 15:15   #30
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Welcome back to the team.
As usual with Stanford, there is no information about an AVX enabled client. It will happen when it happens. But it is unlikely to break the current clients, so we can continue with our current machines, in the knowledge that someone, somewhere will be building an AVX machine and will be able to report on the performance. Until then, all is speculation.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 3rd Sep 2012, 08:25   #31
Scorpuk
Hypermodder
Hi DocJonz,
What did you do and did it make any difference?
I have to agree its bloomin noisy.
If I could get it even a tad quieter I could possibly leave the room door open to aid in cooling. For now I need to keep it closed. lol
__________________
Old 3rd Sep 2012, 13:39   #32
Scorpuk
Hypermodder
I think it was a mistake to close the bedroom door this morning to keep the noise in.
Room temp must be high as one chip is seeing 51.4 Deg C.
__________________
Old 3rd Sep 2012, 18:07   #33
DocJonz
DocJonz's Avatar
The thermal limit of the CPU's is about 70DegC, so at 51, you're still laughing.
I set the profile in the BIOS to 'ES' - that's as good as it gets. Without the shroud (yep it's cheap and flimsy!), the volume is even worse - I tried it!!
I think I've got the basis for a simple, cheap-to-manufacture design of bracket to mount a 92mm fan directly above the heat sink, without having to do anything at all to/with the heat sink that's in-situ. I'll get one knocked up and give it a go .....
__________________
Folding stats
Old 3rd Sep 2012, 18:33   #34
Scorpuk
Hypermodder
Ahhh thats good to know.
If it works out let me know. I need to get rid of that hurricane.
I even ended up doing a search on G34 water blocks.
__________________
Old 3rd Sep 2012, 21:27   #35
DocJonz
DocJonz's Avatar
Originally Posted by Scorpuk View Post
.....I even ended up doing a search on G34 water blocks.
Me too
__________________
Folding stats
Old 4th Sep 2012, 11:14   #36
Scorpuk
Hypermodder
How about this as a way out there idea:
Situ the server in the eaves of the house and connect the discharge to a conduit that leads to a vent in the roof tiles.
__________________
Old 4th Sep 2012, 11:36   #37
big-bert
Multimodder
big-bert has yet to learn the way of the Dremel
All this talk about 4p and 2p folding really makes me want to sell all my hardware and get one. I think i might have made a mistake on the 3930k + Rampage V Extreme, should have gone with a 2p xeon - E5-2620.
__________________
3930K @ 4.2 (24/7), H100, Rampage IV Extreme, G. Skill 16GB 2133
2700K @ 4.5 (24/7), NH-D14, Maximus V Gene, Vengence 8GB 1600
2600K @ 4.5 (24/7), NH-D14, P8Z77-m pro, Team 4GB 1333
GTX 560 Ti x 2 (24/7) on a 775 platform
Folding stats
big-bert is offline   Reply With Quote
Old 4th Sep 2012, 19:09   #38
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.
Why waste the heat! Pipe it in for winter!
TaRkA DaHl is offline   Reply With Quote
Old 5th Sep 2012, 13:13   #39
Scorpuk
Hypermodder
Hehe yeah will be needing the heat soon enough.
Looking at the same idea of adding fans to the heat sinks, but I will have to drop out one of the case fans as there are only 9 fan headers and 6 of those are taken up by the hurricane fans.
Was also thinking along the lines of replacing the case fans with these, but not sure how they connect up. Would also need some padding for the 25mm width to 38mm width in the case.
Noctua NF-R8 80mm Quiet Case Fan
Noctua NF-B9 Vortex-Control 92mm Quiet Case Fan
Also probably not a good idea to switch to these unless I have fans on the heat sinks.
Inner fans 155 CFM
Exhaust fans 85.5 CFM
Quite a reduction in CFM.
Doc,
Have you ever tried it with the inner fans disconnected?
__________________
Old 5th Sep 2012, 18:33   #40
DocJonz
DocJonz's Avatar
Doc,
Do you mean the three intakes? In which case no, I don't think that would be a good idea without some other cooling present.
In regard to the fan header situation, just get some splitter cables - that's what I'm planning (still need to get a quote on my HSF bracket manufacture ....)
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
