Reply
Thread Tools View Mode
Old 25th Aug 2012, 21:28   #21
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Unexpected Results and Modding the Mobo
I'm super siked to announce that Performance-PCs.com is sponsoring me with some gear.
Now for the unexpected results. I needed to put a clear coat on the rust because it would rub off just like real rust. In doing so the color of the rust went from a orange/red/brown to more of a dark brown. I actually like this color because it looks more like leather. Let me know what you guys think.
Mid plate with clear on it and the mobo tray under it.
I liked it so I keep putting clear coat on the rest of the parts. Here is the mobo tray painted and assembled.
Still has a rust look to it.
And compared to the PSU bracket.
So while I was painting the rest of the parts I decided to start modding the "Thermal Armor" of the mobo.
Tape applied
And marked
And here are the final results. Not sure I'm going to keep the skinny piece between the MOS block and the CPU, it isn't perfectly straight and looks in like its in the way of the design. Not sure yet what I will do.
Not sure how I will paint it but here are a few things I figured out recently.
I'm going to paint all the water blocks gold!
I will paint the 2 ribbed parts of the exterior gold.
The front bezel, back side of the case and side panels will have wood grain vinyl applied.
The Thermal Armor will either be rusted, wood grain or covered in leather!
GPU back plates will be the same as the Thermal Armor.
Things I have ordered:
50mm fan for mobo
EX360 rad
EX240 rad
2x BP MCP655 mod kits
Silverstone Slim DVD Drive bay
Acrylic
Things I need to order
BP Dual D5 Pump top
more Turbine Master fans
EK Uni Brackets for RES
250 Res
Questions, Comments and Recommendations are welcome!
Cheers till next time,
Fuga
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 30th Aug 2012, 07:36   #22
rchiileea
Multimodder
rchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremelrchiileea has yet to learn the way of the Dremel
nice subbed
rchiileea is offline   Reply With Quote
Old 30th Aug 2012, 08:07   #23
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
Steampunk awesomeness!
For the wood grain I would investigate real veneer rather than vinyl if possible.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is online now   Reply With Quote
Old 30th Aug 2012, 08:30   #24
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
+1 for veneer - nothing adds more 'atmosphere' than smell of wood... and veneer is pretty easy to make look older and worn...
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is online now   Reply With Quote
Old 30th Aug 2012, 08:51   #25
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
+Another for veneer nice case, nice modding, veneer will give this an extra boost of awesomeness.
Congrats on the sponsor too Fuga I've ordered a couple of times from them too, good shop, postage whooped my rear but was worth it for the hard to get bits.
Waynio is offline   Reply With Quote
Old 31st Aug 2012, 07:11   #26
kier
Modding and coffee
kier's Avatar
kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!kier - it's over 9000!!!!!!!!1!1!1!!!
Can't wait to see more...subbed
__________________
kier is offline   Reply With Quote
Old 31st Aug 2012, 07:28   #27
RustyTool
Modder
RustyTool's Avatar
RustyTool has yet to learn the way of the Dremel
great job so far.
I think that's not a rust paint. it's real rust .first component is paint with iron particles inside and the second component is an oxidiser for iron . so it actually turns the iron into rust . am I wrong?
RustyTool is offline   Reply With Quote
Old 31st Aug 2012, 18:42   #28
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Yeah, it's real rust! You're correct, Rusty! ..Get it?
Come on, no stars for Shane? There's some for ya! Sweet work so far.
__________________
Latest Builds:
LilyPC - in progress • BIO-A10 - MotM Jul. '12 Nominee Loser! • "Movie Sign!" - in progress • CheckMate - MotM May '09 Nominee Loser! • BluBawx I - MotY '09 Nominee Loser! • Lumi่re Noire - MotM Apr. '08 Nominee Loser! • NOTalis w/ MNPCTech • "Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 31st Aug 2012, 19:12   #29
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
Looks pretty sweet. I don't think water cooling was in mind when they designed the Sabertooth, so I like it even more!
I would agree with the real wood veneer that Nexxo suggested. You can even get PSA backed to make it easier to apply if you wanted.
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 31st Aug 2012, 19:33   #30
Fuganater
Supermodder
Fuganater's Avatar
Originally Posted by rchiileea View Post
nice subbed
Thansk
I looked into that today. It is pretty much the same price as Vinyl.
I agree. not to find someone that can cut it down for me.... 4' is too wide to ship to me so I need someone to cut it down.
Thanks. International shipping can be costly sadly.
Originally Posted by RustyTool View Post
great job so far.
Correct. Saying its paint is the easiest and shortest way to talk about it but yes, you are right, it is REAL rust.
Thanks
I'm looking at the PSA kind. 4' x 8' roll is going to cost me about $150. The Vinyl would be close to that.
__________________
-Fugatech-mods-
-Facebook-
Old 31st Aug 2012, 20:15   #31
Fuganater
Supermodder
Fuganater's Avatar
Radiator, Sleeving and LEDs
I have been debating on weather or not I would paint the radiators or not for a while now. Here is what the unpainted rad looks like with the fans and painted grills.
I didn't like the look so I decided to give the rad a make over.
I'm glad the letters are still legible.
With the fan grills on. These outside ones are just for looks and to protect the fins.
Fans attached.
Black fan grills on the inside fans. I was debating on painting the fans and inside grills but it would be a waste. By not painting them I can easily replace them and not worry about having to repaint them at a later time.
Got my MDPC-X sleeving in. I have no idea what the combo will be yet but I have lots of time to think about it.
The Yellow LEDs finally came in along with the 47 Ohm resistors for them.
I pulled one out right away and started testing with the vacuum tubes.
I know they still look a little bit orange in the photos but they are a really nice amber yellow in person. They will look great with the other LED strips I have.
Now for a bit of sponsor news. I was talking to Bitspower several months ago and all of a sudden, they stopped replying to me. Well just a few days ago they finally wrote back and we are in talks again for parts. I hope to get all my fittings and the pump top from them.
I also finally got EK to bite. I started talking shop with them. Not sure all what they will be providing but I'm hoping for at least GPU blocks since PPCs took care of my radiators.
What's coming next?
I'm going to finish modding the "thermal armor" on the mobo this weekend. I want to get a nice clean fit.
I ordered a few sheets of aluminium to make a sturdy midplate. (There will probably be acrylic on top of it. I have not decided yet)
I need to do more research into "wood veneer". Someone suggested that instead of using vinyl to give the case a more natural look. After looking at the prices, its not much more than the vinyl so I'm thinking hard about it. Here are 2 that I am looking at.
This one is already finished.
http://www.veneersupplies.com/produc...awn-4-x-8.html
This one requires a finish.
http://wiusa.com/curvwood/Library-Fi...__flat_cut.htm
That's it for today. Hopefully I can get some more done this weekend since its a long weekend but there isn't much left to do on the inside. I need to decide/figure out the veneer situation so I can get the outside done. Oh and I'm waiting for gold paint to arrive. Once I get that I can do the water blocks and some of the case exterior.
Fuga
__________________
-Fugatech-mods-
-Facebook-
Old 5th Sep 2012, 10:30   #32
Fuganater
Supermodder
Fuganater's Avatar
Performance-PCs.com Sponsor Gear
Performance-PCs.com will go down as the fastest company to ship sponsor gear ever! I placed my order and got it not even a week later.
Here is the gear!
XSPC EX360 Multi Port and EX240 Multi Port
I like these rads because they have such a high FPI.
6 ports on each rad!
Up next is 2 Bitspower D5/655 mod kits
Installed on the stock pump tops. Temporary setup because I will be using a Bitspower Dual D5/655 pump top in the mod.
Finally the Silverstone Slim ODD and SSD/HDD bay. I really like this because I can fit my Slim ODD and up to 4 SSD/2.5" HDDs in it.
Thats all from them. More modding in the next update.
Cheers till then,
Fuga
__________________
-Fugatech-mods-
-Facebook-
Old 5th Sep 2012, 12:00   #33
Baguette
Modder
Baguette has yet to learn the way of the Dremel
Sweet! Shame those perfect finishes will be getting a coating... :P Can't wait to see the next result!
Baguette is offline   Reply With Quote
Old 5th Sep 2012, 17:07   #34
Owndapwn
Modder
Owndapwn's Avatar
Owndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run Crysis
Do you mind if I steal the vacuum tube idea? ._.
Oh, and if you know a colour changing LED I can attach to my Hue, that'd be amazing.
Owndapwn is offline   Reply With Quote
Old 6th Sep 2012, 07:55   #35
Sarakon
The German
Sarakon's Avatar
Sarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run Crysis
Ooooh pretty watercooling equipment
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M
World Of Tanks: Sarakon | BF3: SarakonGT
Sarakon is offline   Reply With Quote
Old 7th Sep 2012, 13:34   #36
Fuganater
Supermodder
Fuganater's Avatar
Next update I need input so keep an eye out for it.
Of course you can. I will probably do a little tutorial on my website for how to do it. I don't own the Hue so I can't say.
Thanks!
__________________
-Fugatech-mods-
-Facebook-
Old 7th Sep 2012, 13:40   #37
Fuganater
Supermodder
Fuganater's Avatar
Choosing the Leather
Now I need your opinion! I got 3 different types of Leather fabric and I'm not sure which one to use. I'm going to post a few pictures of each and I'd like to hear what you have to say!
Option 1:
On the door
Close up
On the mobo
Option 2:
On the door
Close up
On the mobo
Option 3:
On the door
Close up
On the mobo
Please leave your feedback! I really want to know what you guys thing. The leather will cover the door panels, the front bezel and the motherboard's "thermal armor". Hope to hear from you guys!!
Fuga
__________________
-Fugatech-mods-
-Facebook-
Old 7th Sep 2012, 13:45   #38
Baguette
Modder
I'd definitely go for option one for all exterior. It looks much cleaner, and the accents of the weathered items on the inside will pop much more! (Notice the rads on the side, I love the way their coor blends with the leather)
As for the inside, that's a tough call...keeping option 1 isn't something I'd do, since it's just too dark...I'm leaning for option 3 on mobo armor. Let's see what the other folks have to say!
Old 7th Sep 2012, 14:24   #39
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
OM NOM NOM .... steampunk, tuuuuuubes, metal, rust and leather !! Wad' a perfect combo. I vote for option 1 too .
I'll keep a good eye on this project
GuilleAcoustic is offline   Reply With Quote
Old 7th Sep 2012, 15:42   #40
Sarakon
The German
Sarakon's Avatar
Option 1 on the outside and option 3 on the mobo
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
