Reply
Thread Tools View Mode
Old 1st Oct 2012, 16:58   #81
Baguette
Modder
Baguette has yet to learn the way of the Dremel
Fantastically high standard! Man, I'm getting so jealous XD
Baguette is offline   Reply With Quote
Old 1st Oct 2012, 17:04   #82
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
This is simply amazing! Wonderful work!
Also, does that Lion Park happen to be in either Joburg or Durban? Asking because I believe I went to the exact place last time I visited my dad in Joburg!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 2nd Oct 2012, 10:52   #83
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
That sleeve and that plaint job looks perfect.
Amazing project so far.
cumps,
ziza
__________________
Per me si va nella cittą dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 2nd Oct 2012, 18:52   #84
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
That's the best guide I've seen for heat shrink less sleeving.
Nice pile of progress.
Waynio is offline   Reply With Quote
Old 3rd Oct 2012, 14:23   #85
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Originally Posted by Marcos_Viegas View Post
WOW man
Congratulations!
Awesome job!
Haha cheers bud.
Originally Posted by Sarakon View Post
The leather on the door is definitely the perfect choice and the sleeving does look much better now...
Looking forward to the next update!!
Thanks!
Originally Posted by k.3nny View Post
woow verry nice update !
Thanks man!
Thanks!
Thanks! It is just outside of Joburgh.
cumps,
ziza
Thanks!
Well thanks Waynio! Maybe you can do it in your build?
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 3rd Oct 2012, 14:40   #86
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
such an amazing case. this is just a magnificent case!
dreps is offline   Reply With Quote
Old 5th Oct 2012, 09:00   #87
Waynio
Waynio's Avatar
If I can get the money together for sleeving I will, nice & neat that, I'll be sure to use a cheap soldering iron though.
Old 8th Oct 2012, 20:20   #88
Fuganater
Supermodder
Fuganater's Avatar
Happy to say that EK is sponsoring my build!!
Gregor was able to send me a few things. EK-Multioption 250 Basic Res, 8x 90 Degree rotary fittings and a T-Shirt.
Now for the update. It is kinda big because I have not had time to write it up so here goes.
I had to figure out a way to get the water from the res into the dual pump top. A direct run would not work so here is what I had to fashion out of fittings I had laying around. Kinda ugly but it works and its out of sight.
Got out my Curcial M4 128GB SSD and installed it on the Silverstone bay.
Found a 320GB HDD so I'll put that on there for now. I'm trying to get a 512GB SSD for games.
Now to figure out how to wire them all and make it look good...
I also cut the Slim ODD cable so only the power cable is left. I have to use a longer SATA cable than what came with it.
The 3-cable and 4-cable clips came in.
Added a bunch of them to the PCI-E cables and they look pretty good.
I finally got all the holes cut in the midplate so I put the leather on it.
Then I used a furniture marker to color the edges since its fabric and the back of the leather is white.
I like it.
Now for a fun mod. Old GTX 560Ti backplates.
Traced
Cutting and drilling is boring so I skipped that part... and now we have... leather backplates!
And gold brackets
I also covered the SLI bridge with some leather.
Looking good IMO...
I put the res in and added some random fitting to see how it will all work.
I had to make some brackets for the midplate to keep it level. The 24-pin cable pulls it down a bit in the back. Pics later of how they are mounted. (Ya I forgot to take them...)
But here is how it looks from the front.
Top panel before...
And after!
Paint the mesh gold and it looks great!
Painted all the thumb screws gold.
And installed.
Random shot...
Vacuum tubes!!
Playing around with how they will be sitting. (Not sure of final setup yet)
Cut the leds off the bottom so they sit flat on the midplate. I'll drill a hole under them for the LED.
I cut some small pieces of acrylic to hold the LEDs under the mid plate.
PROBLEM! I bought Yellow single LEDs instead of Amber so they don't match!!
I put in a order yesterday for some Amber ones and resistors.
I think we need some lighting.
Using a fan bus to power the LEDs
I bought 2 of these new ones since I only have 1 of the above one. (They have to be the same since I'm OCD like that)
I'm not set on only having Amber lights so lets add some switches so I can have white too!
Start making cables.
Finished. (More pics of this later)
Finally the rainy season is here! (It rains every... single... day...)
That's it for now! I have some more stuff coming this week so next weekend I will be busy.
Cheers till then,
Fuga
__________________
-Fugatech-mods-
-Facebook-
Old 8th Oct 2012, 21:17   #89
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
WTF? I didn't sub yet? Here's correcting that...
I love the colours, so using white LEDs would in my opinion suit the build much, much better than coloured ones.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 9th Oct 2012, 07:11   #90
dreps
Multimodder
simply amazing . keep up the wonderfull work
Old 9th Oct 2012, 07:57   #91
Sarakon
The German
Sarakon's Avatar
Sarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run Crysis
You are on a roll!! Awesome update...Loving the leather touches. Definitely the right leather choice
[EDIT] By the way, i think your before and after pics are exactly the same....
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M
World Of Tanks: Sarakon | BF3: SarakonGT
Sarakon is offline   Reply With Quote
Old 9th Oct 2012, 09:53   #92
Baguette
Modder
You just never know when to stop the awesome do you... One of the finest, most attentive and detailed mods I've seen in a long time! Absolutely impatient to see the end result :O
Old 9th Oct 2012, 10:27   #93
ziza
Multimodder
ziza's Avatar
WOW the case illumination is simply perfect
Amazing build so far.
__________________
Old 10th Oct 2012, 08:57   #94
dreps
Multimodder
little question: will the leather not lose it's color because of heat (and maybe leds light)?
Old 10th Oct 2012, 09:39   #95
Fuganater
Supermodder
Fuganater's Avatar
Thanks for the sub! I'll be adding white or off white SMD LED strips which is why I added the switches.
Thanks!
Thanks! Good catch... I'll fix that.
Thanks!
Thanks!
__________________
-Fugatech-mods-
-Facebook-
Old 10th Oct 2012, 10:23   #96
knightyc
CPC refugee
knightyc's Avatar
knightyc has yet to learn the way of the Dremel
Fuga
Here in England thats called everyday lol
Looking good dude I wish my pc was as good looking as yours
__________________
Intel Core i5 3350P - MSI B75IA-E3 - 16gb Corsair XMS3 1600mhz DDR3 - MSI Nvidia Gforce GTX660 oc 2gb - Cooler Master Elite 120 - OCZ Vertex Plus R2 60gb SSD Windows 7 Ultimate
knightyc is offline   Reply With Quote
Old 10th Oct 2012, 20:51   #97
Fuganater
Supermodder
Fuganater's Avatar
haha thanks!
__________________
-Fugatech-mods-
-Facebook-
Old 11th Oct 2012, 12:24   #98
KrunchR
Supermodder
KrunchR's Avatar
KrunchR has yet to learn the way of the Dremel
looking like good quality modding! love the tubes.
KrunchR is online now   Reply With Quote
Old 11th Oct 2012, 13:33   #99
Fuganater
Supermodder
Fuganater's Avatar
Thanks
Here is a teaser of what I'm currently working on. Modding the EK-Multioption Basic 250 res.
__________________
-Fugatech-mods-
-Facebook-
Old 12th Oct 2012, 23:09   #100
Fuganater
Supermodder
Fuganater's Avatar
Not a big update but an exciting one.
I wanted something to put behind the 2nd PSU bracket that looked cool so I made a stand.
Drilled a hole and covered it with leather.
And added a vacuum tube. I drilled out the bottom so I can put several LEDs in it to make it super bright.
Next up was to mod the EK-Multioption Basic 250 Res. I actually got some of this idea from B Negative.
Cut some leather.
And tested how it looked. Hmm needs something
Got a piece of aluminium.
Cut it and filed the edges
Painted it gold and cut a slot in the leather.
Taped off the res
Pained the end caps gold too
Put it all together and what do you get??
Not to toot my own horn but it looks freaking awesome. There will be 2 LED stop fittings in the top to illuminate the water inside.
Minor thing but I need move the top clamp up...
Thanks it! I changed up some things in an old build to get some more fittings for this one. I'll hopefully have some pipe next week so I can get the water going. Also my laser cut parts should be here the end of next week!
Cheers till next time,
Fuga
__________________
-Fugatech-mods-
-Facebook-
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
