Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Aug 2012, 10:23   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Microsoft simplifies EULA language, ditches grace period
Software giant giveth with one hand, taketh away with the other:
http://www.bit-tech.net/news/bits/20...crosoft-eula/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 21st Aug 2012, 11:03   #2
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
I can totally understand why they are doing that: 30 days to try the OS.... or 30 days to download, install and run the crack or keygen program or spoof the license check
Can't install or run a keygen during the installation process...
ChaosDefinesOrder is offline   Reply With Quote
Old 21st Aug 2012, 11:54   #3
Zinfandel
I Mod, Therefore I Own
Zinfandel's Avatar
Zinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpit
Who's going to track and crack Windows 8? It'd be like breaking into a house when you know all that's inside is someone with a machete.
__________________
I request you to interact on this forum in a streetwise style without going against the Data Protection Act.
Zinfandel is offline   Reply With Quote
Old 21st Aug 2012, 12:11   #4
DXR_13KE
BananaModder
DXR_13KE's Avatar
DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.DXR_13KE is definitely a rep cheat.
No need, just turn of the internet, input the code, crack. As usual.
__________________
Renegade X - Release Date Unveiled
Check it out!!
DXR_13KE is offline   Reply With Quote
Old 21st Aug 2012, 12:21   #5
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Yep, this won't affect piracy one bit. Although the ease and benefits of using a pirated OS are somewhat limited these days anyway. Better to just stump up - it's not that expensive anyway.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 21st Aug 2012, 12:50   #6
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Or breaking in to find the toilet has flooded the whole house.
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 21st Aug 2012, 13:09   #7
SighMoan
Modder
SighMoan has yet to learn the way of the Dremel
Sooo negative in here. I think it's a good move that they are sorting out their EULA. I hope this leads others to do the same.
SighMoan is offline   Reply With Quote
Old 21st Aug 2012, 13:13   #8
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
All this will mean for me is that I'll have to put in a pirate key off the internet, then await the release on MSDN AA before I put my legit key in.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 21st Aug 2012, 13:53   #9
Silent_Raider
Multimodder
Silent_Raider's Avatar
Silent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run CrysisSilent_Raider can run Crysis
Aside from pirating, I think this is going to disable the trick of buying an upgrade version of Windows and doing a full install on a clean drive
__________________
Intel Core i7-2600k @ 4.4GHz | Corsair H100 | ASUS Sabertooth Z77 | G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1866 | 2x Crucial C300 256GB SSD| 2x MSI GTX 680 Twin Frozr III 4GB | Rosewill BLACKHAWK-ULTRA | Kingwin Lazer 1000W | LG 10x Blu-Ray Burner | Creative Sound Blaster Recon3D THX | Logitech G500 | Razer BlackWidow Ultimate (Dragon Age III Edition) | 3 x Dell UltraSharp U2412M 24" 3600x1920 | Logitech Z-5300e 5.1 | Win 7 x64 Ultimate
Silent_Raider is offline   Reply With Quote
Old 21st Aug 2012, 15:45   #10
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
What are you talking about? I've used pirated windows 7 basically since it came out and haven't yet needed to reinstall. To me, piracy is more of a principal. Linux in most ways seems to be better than Windows (for my purposes) in nearly every way imagineable, with the exception of playing games (which I don't do often), equivalent GPU support (which doesn't matter if I don't play games), and setting up surround sound with just ALSA. To me, its stupid to pay for an OS that I find worse than a free one, especially when I use it much less often than linux. I wouldn't mind paying for linux, but the only variants you pay for don't interest me because they're geared more toward businesses than home users.
I do the same thing with games - I'd rather pay $120 for a bunch of indie games than $60 for another COD, even if I would find the COD game enjoyable. COD today is made strictly for profit and nothing else; there is almost no ambition or creativity in the production of those games and I actually feel like buying it is the wrong thing to do since it's games like that which are destroying the gaming market.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 21st Aug 2012, 15:51   #11
Gareth Halfacree
WIIGII!
bit-tech Staff
Congratulations - you've just made a strong argument for using Linux. What you *haven't* made is any kind of argument in favour of piracy.
I prefer Burger King burgers to McDonald's burgers. That doesn't give me the right to walk into McDonald's and demand a free burger, nor does the fact that Burger King has a 50%-off sale give me the right to demand a McDonald's burger at the same price.
If you don't want to pay for Windows, don't use it. If you want to use Windows, pay for it. It's really that simple.
__________________
Old 21st Aug 2012, 15:54   #12
Shirty
Moderator
Shirty's Avatar
What am I talking about? I'm talking (like an adult) about the fact that Microsoft take a much more proactive stance on piracy these days.
I won't get into a debate that's already been done to death on these and other forums, but generally my motto is that if you want to use something that someone else has made, you pay them for it. No discussion.
Whatever your misguided sense of entitlement may tell you otherwise, I promise that you won't win any friends on here by boasting about how you pirate Windows 7 because you think it's **** but it's also a necessary evil for playing games.
Or what Gareth said
__________________
Old 21st Aug 2012, 15:59   #13
schmidtbag
Ultramodder
I understand your point but that tends to be less relevant when you start comparing:
* The product's usefulness or need of the product
* Something you have that needs the product
* Price proportions
If the difference is $5, who honestly cares? For argument's sake, lets say that linux is worth $40. Why would I pay more than double that for something that is worse in terms of price- performance-features?
Also, stealing physical items is VERY different from stealing something digital. If I just demanded a free burger, that's 1 less burger they have and need to pay for. If I'm copying Windows from a torrent, you can argue that the developers are getting 1 less sale, but its 1 sale they probably wouldn't have got in the first place - at least they didn't specifically lose anything. I think I remember reading a study showing that most pirates wouldn't pay for the product they steal in the first place.
@shirty
MS takes a more proactive stance on piracy these days? What a joke. They had that same stance when it came to Windows 7 and they were all proud of their horrible, proven-ineffective method of antipiracy when the OS was successfully cracked BEFORE IT WAS ON THE SHELVES.
If a company sincerely cares about making something un-pirateable, they ought to actually do something about it.
Based on your motto, I'm sure you're one of those people who are completely blinded by thoughts like "you get what you pay for", which in the software world is obscenely false on so many levels. If you don't feel that way, well, then you'd understand my motive for pirating windows when I'm not a piracy activist. Also, if this has been debated before on these forums, then your idea of "winning friends" is wrong - the only difference is I don't pirate stuff just because I want it for free, I actually put thought into my decision. If I can't afford something, I don't buy it. If a shitty game like COD comes out that I don't think deserves my money, I don't even waste my time pirating it. Windows is pretty much the 1 and only thing I pirate, and I don't pirate it to use it. Whenever I'm in windows I might only be spending 2 minutes in the actual OS, otherwise I'm in a game. I'm not paying $100+ for a slow GUI to get into another one.
Old 21st Aug 2012, 16:07   #14
Gareth Halfacree
WIIGII!
bit-tech Staff
Because that's how much it costs. I could buy a car for 8,000 or I could buy a Bugatti Veyron for 500,000 (or whatever ridiculous price a Bugatti Veyron costs these days - I can't be bothered to look it up.) The Bugatti Veyron, for my needs, would be *worse* than the Vauxhall Astra or whatever: far higher running costs, much smaller luggage space, ridiculous insurance costs. I'd also use it a lot less, because of the fuel costs and the desire not to have it get nicked.
By your logic - a more expensive yet demonstrably less suitable product I will use less than a cheaper, more suitable product - I should be able to have a free Bugatti Veyron, right - or at least buy one for 8,000?
Forget the strawman of physical versus virtual and answer the question: are you enjoying the benefits of a product which has a monetary value attached without paying that value? Are you enjoying the benefits of the work a company has put - time, money and effort - into its product without giving that company anything back?
Then you, sir, are a thief. You can dress it up how you like - "it's just zeros and ones" - but you're a thief, plain and simple. This is not something to be proud of, but something of which you should feel a deep-seated shame. If I were to benefit from your hard work without compensation - let's say you wrote a program and sold it for 5, a program which was demonstrably less suitable for a given task than a free program, but had some feature I desired so I used your program anyway - would you be happy if I copied it for free? I mean, I could have used a free program, so no harm no foul right?
What if my friends do the same? My friends' friends? Their friends? What if there are now over a million copies of your program doing the rounds, and so far you've received no compensation whatsoever. Still happy?
__________________
Old 21st Aug 2012, 16:21   #15
schmidtbag
Ultramodder
Right but the difference is you don't have a compelling reason to ever use it aside from showing off. And again, the perspective changes when it comes to real physical objects.
No, because the more expensive product offers NO benefit of any kind that you would actually use or care about. You could argue the seats in the Veyron are better, but with the money you save of not getting that car, you could just buy better ones for the Astra. If you do find it to be more useful and worth its value, great, I'm not saying everyone should follow my opinion. I'm not saying Windows should be given out for free either. Even if I were more successful than all of MS, I wouldn't go up to them and say "you should really make windows free".
Generally speaking, no. But it'd be pretty ignorant of me to not give them credit for some of their work. HOWEVER, such things that I think they did a good job on, are also well-done on pretty much any other modern OS including Mac. The only difference is MS will make it proprietary.
I didn't say it wasn't stealing, that's why its called piracy.... I also didn't say I was proud of this, but it isn't shameful either. Do you consider it a proud thing when you buy something that doesn't do a good job at anything it is supposed to do? No, many people would actually return the product.
If I were to benefit from your hard work without compensation - let's say you wrote a a program and sold it for 5, a program which was demonstrably less suitable for a given task than a free program, but had some feature I desired so I used your program anyway - would you be happy if I copied it for free? I mean, I could have used a free program, so no harm no foul right?
At a price value that low, I'd probably pay for it. But, I have yet to see that situation come up.
Well, lets say that we're comparing CD burning programs since those seem to fall under this category a lot. If I made a CD burning program that offered 1 nice feature the others didn't have, I'm still being an ass of a developer for asking money for something that has been done a bajillion times. It'd be a lot better if I were to be employed by a company that already made a CD burning program and I made my contribution. I understand people need to make money, but you don't DESERVE money for doing crappy/unoriginal work.
Putting a fee to a new product that is just like another one is, IMO, just as bad as pirating.
Old 21st Aug 2012, 16:25   #16
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.
@schmidtbag, saying that you are using an illegal software, let a lone Microsoft software, in a public forum, where everyone can see, including search engine isn't wise at all.
Also, I, and I hope and encourage everyone here to do the same, to not help in any way people using pirated copy. It waste everyone times as most issues they have are due to hacks and cracks they or the hacker put, let alone possibly rootkits, and can't be solved. And a thief should not get any help. You don't help a thief moving your own goods in your home out to his truck, nor your neighbors, and and sure ain't going to answer his phone calls asking you to help to hook up the stolen stuff.
schmidtbag you made it into my black list.
Microsoft software are sure expensive, but engineers costs a lot of money.. and I mean A LOT of money. Why? Because they are few, and among those few, only few of these are actually really good, getting a degree in the field is very difficult (if you go to University in these programs, you can really see the funnel effect, where at first you are in huge classes, and at the end of your 3-4 year program, you are less than the number of student that what you were in high school).
The average wage (varies depending on where you are of course) is about 60-70k per year. A non junior is about 100k per year. Doing something like a graphic card or Windows, cost a BILLIONS! I do know for fact that Nvidia easily has 1500 to 2000 engineers working on a new graphic card, depending if it s a new architecture and what the company can afford. Multiply that by 100k (let's say it's the average), multiply by 3 years, and you have a nice number. Now add administration, HR, testing, drivers development, software development (dev tools, and such), support team for dev and manufacturers, website, building maintenance, resource maintenance (powerful servers to run simulations and such which constantly needs upgrading), oh and lets' not forget marketing. No wonder an Nvidia graphic card while costs maybe 50-70$ to produce, cost 300-500$, and not make much of a profit at the end. Microsoft is A LOT bigger than Nvidia, and more people are working on Windows than Nvidia. And I think these people need food on a table.
Most people working on Linux, are working at these big software/hardware companies. They are doing this for fun, because their job is fun. It's you playing games. But instead of playing games, they work on open source software. Mostly as a big favor. If you don't buy Windows, or wtv software and start stealing hardware, then you have no more software developers/engineers. So you have no more Linux, and no more open source.
Plus Microsoft does SO MUCH, that no other company can even dream about doing in helping making Windows more affordable.
-> Upgrade edition (and now only 40$)
-> Upgrade edition works all the way back from XP.
-> Student special
-> Pre-order special
-> MSDNAA
And you are still too cheap to get it. You have 0 excuse! None!
You are a thief, plain and simple. While you don't steal a physical good, you do prevent people getting food on a table, and they are the people that make everything that uses electricity (in this case) to make anything (robots, machines, appliances, entertainment, etc.)
__________________
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 21st Aug 2012, 16:27   #17
Gareth Halfacree
WIIGII!
bit-tech Staff
<snip self-justification>
Wow. Just... wow.
This is actually a very interesting topic for me, for the following reason: my current books are published using DRM and only on platforms where DRM is available - Google Play, iBooks and Amazon Kindle. The reason the publisher gives for this is to help reduce - not prevent, because prevention is impossible - piracy.
My next book is going to be published on as many platforms as possible, all without DRM. My reasoning for this is that DRM is bloody awkward and often prevents legitimate customers from doing perfectly reasonable things - you can't easily read a DRM'd ePub on Linux, for example.
I decided to do this because I figured that the majority of people are, at heart, decent, and that when faced with a reasonable price for a reasonable product they wouldn't hesitate to pay. Your response has convinced me that this isn't the case - that there are people who will come up with *any* reason to justify their theft. "There are other books available." "It's more than I want to pay, but I still want it." "I won't give you any money, but hey - kudos on your other books, they're great."
I'll most likely still publish sans-DRM, because that's the right thing to do - but I'll be doing so now with a grimace on my face.
Now, back on topic: how about those plain-English EULAs, hey?
__________________
Old 21st Aug 2012, 16:41   #18
steveo_mcg
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
If the self deluding justification above was a revelation to you then frankly I'm shocked.
Folk like schmidtbag are not your customer and never will be, you'll never sell a product to them if it or anything broadly similar can be had free. There isn't much point in giving his ilk a second thought, inconveniencing real customers with cash money to spend is a sure-fire way to lose sales on the other hand. I'll buy (very few) DRM products with a grimace but I'll be much happier buying with out. Normal people (Muggles) will buy stuff however its packaged but if they fall foul of the DRM they'll tell every one they meet how appalling your product is.
Not just you obviously but publishers in general.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 21st Aug 2012, 16:42   #19
schmidtbag
Ultramodder
@forums
*sigh* It appears that many people here are as arrogant as they think I am. I'm not endoring piracy. I don't help others pirate. I don't suggest piracy. I don't really pirate anything but Windows. I'm not some random asshole who just pirates something because I can. You'll find that I have a lot less pirated content than probably half of you on these forums, whether that be software, music, or movies.
If you really feel like blacklisting me because you generalize me under the same category as other pirates, then fine, that becomes 1 less person for me to explain myself to.
@Gareth
It is unfortunate that many things like books, music, and movies are so easy to pirate. They are something that is unrealistically difficult to prevent, or even reduce. I think many DRMs like Steam do a very good job at stopping piracy and I support their efforts.
You seem to fall under the same problem as goodbytes - both of you hear what you want to hear and interpret what I say as automatically being bad just because there's 1 evil in it. Your comment about "There are other books available. It's more than I want to pay, but I still want it." is being nitpickity, generalized, and misses my point. However, there are actually a LOT of people out there who really do think that way and do steal something, just because they can, and I don't approve of those people. The way you're interpeting my decision is just as bad as Catholics who hate gays with a firey passion just because the gay lifestyle doesn't produce offspring. Again, I don't endorse piracy - I am against it, especially for independent creators. I just see nothing about Windows I find worth the value it is priced at.
Old 21st Aug 2012, 16:45   #20
Shirty
Moderator
Shirty's Avatar
Windows is actually remarkably excellent value when you consider the billions of man hours that have gone into the intricacies of the programming, evolved over decades. It is a remarkable product. Just take your hand out of your pocket and pay the damn 100 quid or so it costs. Assuming you upgrade every 4 years, you're paying 2 a month for the ability to do everything that Windows allows you to do.
I'm not holier than thou - I may well have had a few pirated copies of Windows 98 when I was a teenager because I couldn't afford to buy an OS at the time , but as an adult I consider copyright theft to be akin to taking food out of someone's mouth, fuel out of someone's car or beer money out of someone's pocket. It's just not cricket. If there was a 100% chance of a six moth jail sentence for every owner of a cracked copy of a Microsoft product, then I'd wager there'd be a lot of people in prison for a short time, and not a lot of pirated copies in circulation thereafter.
I don't particularly like bars of chocolate, but it's not really fair on the shopkeeper if I keep taking them off his shelf to try all the different flavours without paying for them. Caught once I might get away with a slap on the wrist, but repeated offences (every time you use your PC in your case) are just a step too far.
Oh, and Gareth - I still won't read the EULA
__________________
Reply
Tags
drm, eula, licence, microsoft, windows 8
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
