Reply
Thread Tools View Mode
Old 26th Nov 2012, 19:14   #21
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
I rather use the darkened plexi than the clear version.
__________________
Current projects: Tydirium is on the way!
Previous mods: | [/url]|Sandcrawler Mod| |Illuminated Mind|
[url="http://forums.bit-tech.net/showthread.php?t=246505""]Graphite 5
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 28th Nov 2012, 11:28   #22
jones-965
Modding & tuning
jones-965's Avatar
jones-965 has yet to learn the way of the Dremeljones-965 has yet to learn the way of the Dremel
Congratulations my friend! Your work is fantastic!
__________________
Forever modding
my work: TJ-07 project
http://pc-style.hu/
jones-965 is offline   Reply With Quote
Old 30th Nov 2012, 12:18   #23
Moddingboy
Multimodder
Moddingboy's Avatar
Moddingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the Dremel
Thank you my friends!
I upload the photos to Imageshack. If you have problems with loading them please watch the photo gallery here: Picasa
__________________
Gymkhana Mod - MOTM 2011 September Winner
Moddingboy Mods on Fb
Moddingboy is offline   Reply With Quote
Old 1st Dec 2012, 05:33   #24
Matt's_Mods
What's a Dremel?
Matt's_Mods's Avatar
Matt's_Mods has yet to learn the way of the Dremel
That looks great mate how long did i t take you to cut out your grille ?
Matt's_Mods is offline   Reply With Quote
Old 1st Dec 2012, 10:03   #25
nagyizom
Supermodder
nagyizom's Avatar
What's the problem? Why don't you make direct link to these pictures like you did before?
__________________
Old 8th Dec 2012, 16:18   #26
Moddingboy
Multimodder
Moddingboy's Avatar
Matt's_Mods - It takes about 25 hours - with the smallest filer I have - to do the best work at detais.
Here are some little updates;
This week I get the support package from Kingston Technology. 2x90Gb HyperX 3K SSDs and 2x4Gb HyperX Beast memory modules.
Next week I'll continue the building of the SSD holder ( I started to work on) and will do thing about the coverplate in top of the PSU section.
When everything goes right they will be finished next week.
Yesterday I was very happy because my stuff arrived from MDPC-X. So there will be some sleeving soon.
__________________
Old 9th Dec 2012, 11:28   #27
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run Crysis
incredible how good looks your work,well done my friend
Zsolt Guriga is offline   Reply With Quote
Old 9th Dec 2012, 11:34   #28
omgdec
Multimodder
omgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for presidentomgdec should be considered for president
The mouse looks fantastic, going by that.. this gonna be good!
omgdec is offline   Reply With Quote
Old 23rd Dec 2012, 23:40   #29
Moddingboy
Multimodder
Moddingboy's Avatar
Zsolt Guriga, omgdec - Thanks guys!
-WORKFLOW-
Day 8: 2012.11.27. / Task: To do removing default fan grills
I removed all the case fan's safety grilles to improve airflow. The same will happen to the PSU. There will be only the dust filter in the way of fresh air.
Day 9: 2012.11.28. / Task: SSD mounting frame
The Kingston Technology supports my project with two 90Gb HyperX 3K SSDs and my task is to make a mounting frame to these SSDs.
I used 1,5mm thick aluminum sheets. After some precise cuts I folded them to perfectly match from the mainboard-tray to the front of the case.
I didn't make the finished item yet but here are some photos of the process;
Day 10: 2012.12.10. / Task: SSD mounting frame pt.2
After a little break I have free time to do a little modding. So I continued the SSD frame.
Day 11: 2012.12.13. / Task: SSD holder frame #3
This day was for the SSD frame too. It will be 3 pieces together. Previously I did the first part then I made the second and third pieces today. The smallest part will be in the center of the frame and It will be the real holder of the SSDs. I attach plexiglass rods to this part. These plexiglass bars created with multitool (as you can see in the pictures). These little plexis and the metal parts will be glued together with epoxy.
In the end I drilled holes to install the SSDs. Finished photos of the frame soon.
Day 12: 2012.12.14. / Task: PSU coverplate
I made the cover for the PSU and the hider of the sleevings. It is a 1.5mm thick aluminum sheet cutted then folded to exactly fit on the plexirod frameing. These plexi pieces were cutted with laser after precise calculations and designing to fit tightly and be a tough skeleton to the coverplate.
Day 13: 2012.12.20. / Task: ODD coverplate
Sadly the previously showed plexiglas framing was happened to be weak because it cracked. So it get a bit modificated - need some reinforcements on the weak points. While waiting for the new version the coverplate will be waiting to be finished.
But the work must go on and I had to do something today too.
I wanted to do a little work on the ODD frame's outer side. I removed it from the case then I cutted off the tiny 'bumps' i'didnt need to use anymore - to get a smooth surface. As you can see there is a line shaped embosslike something on the side of the frame I didn't removed instead of I use some XPS-like material to make the surface smooth. On top of these there will be an aluminum sheet to get a real smooth surface. This aluminum sheet will be custom painted - soon.
Updates soon...
__________________
Old 23rd Dec 2012, 23:48   #30
Moddingboy
Multimodder
Moddingboy's Avatar
Some support packages arrived last week. Thanks to my Sponsors!
MSI
Sapphire Technology
Cooler Master
PC Gear
I wish you all a Merry Christmas!
__________________
Old 24th Dec 2012, 21:58   #31
nagyizom
Supermodder
nagyizom's Avatar
Great news, my friend! Congrats for the sponsors and the goodies! Merry XMas!
__________________
Old 25th Dec 2012, 00:21   #32
Stem83
Addicted to modding.
Stem83's Avatar
Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.Stem83 is a hoopy frood who really knows where their towel is.
Yeah lots of prezzies there to work with, gonna be fun. Your previous work looks so good, cant wait to see more of this.
Stem83 is offline   Reply With Quote
Old 25th Dec 2012, 01:05   #33
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
the motherboard is just excellent.. thinking about buying the same one for myself.. (thanks Santa)
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
exexs is offline   Reply With Quote
Old 28th Dec 2012, 21:47   #34
Moddingboy
Multimodder
Moddingboy's Avatar
Thank you for your comments
Here's a little teaser:
The plans are done for the paintjob and the masks (stencils) are already done too. Last I wrote about the ODD coverplate so I show you the plan for its' painting.
__________________
Old 29th Dec 2012, 02:37   #35
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
Looking really Good! and hoping to see a lot more : )
__________________
Finished:
-Mini-PC http://forums.bit-tech.net/showthread.php?t=248203
unfinished:
none!
Sissilisko is offline   Reply With Quote
Old 30th Dec 2012, 00:15   #36
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Followed your first Gymkhana mod and really liked it. You were actually the one who introduced me to the wonderful DC Shoes videos of Ken Block - and now I'm also going to get a pair of DC Shoes Ken Block "Gatsby 2" in Black/Green Limestone colour. All thanks to you, hehe.
I love the front grill - was worth the 25 hours, I think. And nice routing/sinking of the sidepanel window - I thought about getting one of those Dremel stands, but I guess a good router bit in my drill press will be able to do the same job.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 7th Jan 2013, 17:59   #37
Moddingboy
Multimodder
Moddingboy's Avatar
Sissilisko - Thank You!
Nutman - Thanks Nutman! In fact its not a dedicated router stand but it worked well so your drillstand will be okay too I think but you need a proper router-bit.
__________________
Old 7th Jan 2013, 18:03   #38
Moddingboy
Multimodder
Moddingboy's Avatar
-WORKFLOW-
Day 15: 2013.01.05. / Task: PSU sleeving
Them plexiglas framing is done but before finishing the PSU coverplate I decided to do some cable sleevings in the weekend.
Before disassembling the connectors I marked the pins for an easier assembling when the sleevings are finished.
As you can see I used staples from a stapler for removing the pins - its funny but the work with them were easier than the work with the dedicated pin removing toolkit.
There was luck because the holes on the connectors are big enough to connect the shrinked and sleeved cables (they get little boldy) through them. I have to remove the U-channel from the edge of the hole but the hole wasn't so sharp that I didn't need to file/sand them.
Day 16: 2013.01.06. / Task: PSU sleeving #2
Today I have some sleeving on the CPU-Power cables and some fine tuning like removing the sticker from the top of the PSU. The finished power supply get wicked and I hope you like it.
__________________
Old 7th Jan 2013, 19:04   #39
OcSurfe
Uber Noob
OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.OcSurfe is a hoopy frood who really knows where their towel is.
This is brilliant, cant believe its taken me this long to come across these mods,
keep it up buddy, i look forward to seeing more!
OcSurfe is offline   Reply With Quote
Old 8th Jan 2013, 00:01   #40
Nutman
Nutman's Avatar
Soooo nice!
__________________
Reply
Tags
gymkhana mod ii, silencio 550
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
