Reply
Thread Tools View Mode
Old 13th Jan 2013, 21:05   #41
Moddingboy
Multimodder
Moddingboy's Avatar
Moddingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the DremelModdingboy has yet to learn the way of the Dremel
Your comments are very appreciated thank you guys
Recently I've had another great sponsor and this week their support package has arrived.
Big thanks to Lamptron!
Beneathy some important little accesories I've got a stylish and clean fancontroller.
There are no potmeters because it is have touch sensitive frontpanel.
So I could install it without any problems to my case - it have front door - the CM Silencio 550.
__________________
Gymkhana Mod - MOTM 2011 September Winner
Moddingboy Mods on Fb
Moddingboy is offline   Reply With Quote
Old 14th Jan 2013, 22:33   #42
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Nice!
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 16th Jan 2013, 22:22   #43
Moddingboy
Multimodder
Moddingboy's Avatar
-WORKFLOW-
Day 17: 2013.01.16. / Task: Work on the front
There is a plastic part in the front door dedicated to hold the hinges and the screws.
As I do on the other parts on the door I do the same with this plastic part. Vent hole cutted then I replaced the original sponge - removed it, cut-to-shape, then went back. Perfect fit.
I used 3mm thick well-airflow "spongy filter" to fit to the grille section. Adhesive tape will hold this to its position.
I moved the factory default control panel of the Silencio 550. It was originnaly on the top of the front but I removed them then replace the original zone (over the 5.25" slots) with the switches supported by Lamptron.
I try to make a cleaner exterior with this 'little' modification.
(sadly the camera batteries were exhausted so I owe you some photos - Update soon.)
+1
__________________
Old 20th Jan 2013, 16:30   #44
Nutman
Nutman's Avatar
Love this progress. Look at that perfectly cut foam? Loovely!
One suggestion though: How about finding another way to secure the foam, so you will be able to remove it later for washing it? I assume it acts like a dust filter - that's why I ask...
__________________
Old 23rd Jan 2013, 21:09   #45
Moddingboy
Multimodder
Moddingboy's Avatar
Thanks Nutman!
It can be cleared well with compressed air but if washing needed you just click out the inner frame then remove the dustfilter.
There are few tiny things to do (update soon) but if everything will be okay I do the paintjob next week. I can't wait!
__________________
Old 28th Jan 2013, 03:41   #46
Luciel
Multimodder
Luciel's Avatar
Luciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the Dremel
It´s looking great Moddingboy, glad the Lamptron products arrived more or less ok (that fctouch box looks a bit banged about, but the contents look ok, was worried there for a second!)
Luciel is offline   Reply With Quote
Old 31st Jan 2013, 08:12   #47
Moddingboy
Multimodder
Moddingboy's Avatar
Luciel - Thanks Magically JUST the box has damaged but the contents wasn't.
Probably the Beast inside tried to unbox itself
__________________
Old 31st Jan 2013, 08:14   #48
Moddingboy
Multimodder
Moddingboy's Avatar
Day 18: 2013.01.26. / Task: "cover plate" for the fan
The work on the interior is almost done but something is wrong.
Under the ODD where the 2 fans are - there is something not okay.
I decided to do these area a little more clean and I think it was success.
Day 19: 2013.01.27. / Task: Framing on the side panel
I do a try-assembly in the week but I was curious about the distance between the CPU cooler's top and the sidpanel.
Whoops.
Its about 4mm so if I install the plexiglass to the sidepanel it will be bot okay. So the plexiglass will be mounted on the outside like tha frame too.
I modified the edge of the plexiglass to match the framing.
And assembly!
The distance is nice and the CPU cooler isn't hit the plexiglass now.
__________________
Old 31st Jan 2013, 12:59   #49
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
oooh love the window nice work on the edge
dreps is offline   Reply With Quote
Old 31st Jan 2013, 13:16   #50
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
That front panel fan mount looks pretty damn slick
Mankz is offline   Reply With Quote
Old 31st Jan 2013, 20:52   #51
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
Looking a little more involved than you last Ken inspired creation.
Subbed.
__________________
Intel i5 2500k @ 4.5Ghz / Dark Rock Adv. MSI Z68A-GD55
Asus Radeon HD6850 Direct CU @902Mhz 8gb (4x2) Corsair Vengance LP 1600Mhz
OCZ Vertex 4 128gb Seagate 320gb & Samsung 1tb
Coolermaster 600w Silent Pro Modded Lian Li PC-0700
jeckulz is offline   Reply With Quote
Old 3rd Feb 2013, 22:37   #52
Moddingboy
Multimodder
Moddingboy's Avatar
Very thanks guys!
jeckulz - I'm glad you think that. I try to get above the previous project and I hope I can do it.
__________________
Old 3rd Feb 2013, 22:46   #53
Moddingboy
Multimodder
Moddingboy's Avatar
Day 20: 2013.01.31. / Task: Painting
And at last the best stage of the work - the paintjob. This is matters. It gives the whole theme to the case.
Before the case I thought I'll do the little parts as a begin. I have the time to apply 2-3 base layers to the pieces.
The ODD coverplate has got the matteblack and the graphic will be applied tomorrow.
Day 21: 2013.02.01. / Task: ODD coverplate painting
I shot photos of all the steps so they could show you the entire process. If you have questions I'll answer it.
Day 22: 2013.02.02. / Task: SSD mounting frame painting
Today I did the SSD framings paintjob. The backplate has got a cool Hoonigan text to it.
__________________
Old 4th Feb 2013, 10:46   #54
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run CrysisZsolt Guriga can run Crysis
Woooow man this is really perfect,I love the way you work,good job
Zsolt Guriga is offline   Reply With Quote
Old 4th Feb 2013, 10:59   #55
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
looking good !
k.3nny is offline   Reply With Quote
Old 4th Feb 2013, 11:00   #56
Azariel
Multimodder
Azariel's Avatar
Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!Azariel - it's over 9000!!!!!!!!1!1!1!!!
Looks great!
Is that a sticker that you apply or do you glue it on yourself? Also, at what point do you peel the sticker of again as you seem to get very nice and clear edges!
Azariel is offline   Reply With Quote
Old 4th Feb 2013, 12:29   #57
Moddingboy
Multimodder
Moddingboy's Avatar
Thanks guys!
Azariel - The design has been drawn in with vectorgraphic program then with Norbert's (aka enormous) help it was cutted with a vinyl cutter from a dedicated masking vinyl.
This is a good vinyl for painting because it has a weaker adhesive surface.
The solvent of the paint what is sprayed to its top don't have effect on the adhesive 'glue'. No sticky parts remains after peel off.
__________________
Old 4th Feb 2013, 12:42   #58
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Grerat work as usual!
__________________
Current projects: Tydirium is on the way!
Previous mods: | [/url]|Sandcrawler Mod| |Illuminated Mind|
[url="http://forums.bit-tech.net/showthread.php?t=246505""]Graphite 5
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 5th Feb 2013, 15:05   #59
Luciel
Multimodder
Luciel's Avatar
Looking brilliant : )
Old 7th Feb 2013, 19:08   #60
Moddingboy
Multimodder
Moddingboy's Avatar
nagyizom - Thank you my friend!
Luciel - I'm very glad you like it!
__________________
Reply
Tags
gymkhana mod ii, silencio 550
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
