Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Aug 2012, 07:50   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Samsung Series 9 monitor review
http://www.bit-tech.net/hardware/mon...msungseries9/1
brumgrunt is offline   Reply With Quote
Old 22nd Aug 2012, 08:06   #2
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.Pookeyhead is definitely a rep cheat.
Shiny screen = fail. Nice looking screen though.
Why only give a report on out of the box performance. You had a colorimeter, why not calibrate it and see how good it can actually be? It's not a big job, and takes no longer than measuring it's out of the box performance.
You mention sRGB mode, which makes me assume this is a wide gamut screen, but the review doesn't actually specify this. What's it's percentage of Adobe RGB1998? How does PLS fair with IPS with black levels off axis? There's so much missing here, and so much fail in this review.
I still don't see why when your CPU, GPU and other hardware reviews are so technically detailed you insist on doing these consumer style monitor reviews. I thought this was a serious hardware and modding site?
Sorry Bit, but your monitor reviews are terrible.
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ H105 ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ EVGA GTX980 Super-Clocked¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS9260-8i ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 22nd Aug 2012, 08:14   #3
srgtherasta
Supermodder
srgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for presidentsrgtherasta should be considered for president
The usb ports are on the back of the bottom of the stand? yea that's handy Not
srgtherasta is offline   Reply With Quote
Old 22nd Aug 2012, 08:15   #4
ajfsound
Multimodder
ajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpit
It would be nice to see calibrated results - I agree. Also it would be great to include monitor recommendations in the Buyer's Guide. Oh and the moon on a stick
ajfsound is offline   Reply With Quote
Old 22nd Aug 2012, 08:26   #5
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
Seems it's high time to get a Samsung SyncMaster S27A850T (or Samsung SyncMaster S24A850DW for 24") if you want a monitor with a _matte_ PLS panel and which doesn't look you into a certain stand.
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 22nd Aug 2012, 08:38   #6
johnnyboy700
I *am* a Dremel
johnnyboy700's Avatar
johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.
I know this is a bit nit-picky but I don't like the idea of having a stand that holds all of your connections.
Supposing you had enough money to burn and you wanted to mount six together on one of those multi monitor mounts, with your connections built into the stand you are going to have a real problem. Wall mounting might also be an issue, so I suppose you would simply look elsewhere.
johnnyboy700 is offline   Reply With Quote
Old 22nd Aug 2012, 08:48   #7
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
I thought you used to do input lag measurements with your monitor reviews? I agree with Pookeyhead, bad review is bad.
Da_Rude_Baboon is offline   Reply With Quote
Old 22nd Aug 2012, 09:24   #8
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Very pretty looking but, for £800, I'd want the option to wall mount it if I felt the need.
I'd only give it a feature score that high if the stand was removable, it had a vesa mount and a second set of inputs. Me no likely the need for a power brick either.
My wallet can rest easy, as there's little danger of me wanting one, never mind buying one.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 22nd Aug 2012, 09:54   #9
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
For that much money, I'd prefer it focus less on stand aesthetics and more on pragmatism.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 22nd Aug 2012, 10:01   #10
azrael-
I'm special...
azrael-'s Avatar
Well, considering that the S27B970 and the S27A850T use identical panels (except perhaps for a minor revision) why would you ever choose the former over the latter, when the latter is a lot cheaper (about 500 GBP) and doesn't lock you in with a specific stand that holds most of the electronic components. Oh, and the latter has a matte panel to boot.
__________________
Old 22nd Aug 2012, 10:05   #11
Elton
Elton's Avatar
Because it's shiny. This is why we can't have nice things. Being all sensible!
__________________
Old 22nd Aug 2012, 10:19   #12
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!
The USB ports look like they're on the side of the base.
looking at it, I don't think it has Vesa mounts so you wouldn't be able to use it on a mounting bracket anyway.
__________________
刃mrk
My X-Box Live gamertag, PSN, Steam & Nintendo ID is BladeMrk
Blademrk is offline   Reply With Quote
Old 22nd Aug 2012, 10:28   #13
Prowler_88
Minimodder
Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.Prowler_88 is a hoopy frood who really knows where their towel is.
I can understand why monitors for photo editing etc command a high price, but with lag on modern TVs usually being extremely low, how can you justify spending that much on a monitor for anything else. Resolutions above 1080p only make a difference if you sit with your face stuck to the screen, particularly with AA enabled, and colour reproduction, black levels etc. are usually better handled by decent quality TVs.
I'd rather stick with my 42" Panasonic G20 for PC, PS3 and films rather than spend £800 on a 27" monitor!
Prowler_88 is offline   Reply With Quote
Old 22nd Aug 2012, 10:30   #14
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
I'd rather buy a Dell 2711 for quite a lot less than that, and have far more flexibility in the process.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 22nd Aug 2012, 10:35   #15
Elton
Elton's Avatar
If the PLS monitor shows to be better than IPS then the matte version might have a chance.
On the other hand, regular HDTVs actually have some pretty bad input lag.
__________________
Old 22nd Aug 2012, 10:59   #16
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
£275 over the competing dell is just INSANE no one who is looking at this will say its value for money.
you can buy a very nice tv set that will do a better job if all you care for is games and films for the same £800 made by samsung none the less.
rollo is offline   Reply With Quote
Old 22nd Aug 2012, 11:12   #17
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Bleh.
The comparison to Apple's Thunderbolt display is an interesting one - the Samsung is cheaper, but the Apple is made of solid aluminium (so no wobble) and also includes things like a gigabit ethernet port, HD webcam, FireWire... Basically, I think Samsung should have made this even cheaper, competing with the U2711's price rather than Apple.
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 22nd Aug 2012, 11:13   #18
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Pookey speaketh the truth.
Doesn't go into anywhere near enough detail to let me know whether this monitor is worth buying over an Apple or Dell. It's an opinion piece, and by the sound of it, written by someone who's new to 27" monitors (Hence the comments about getting used to smaller icon sizes)
Also...
Samsung is hoping that design and a few extra features such as MHL and personalised calibration will be enough to justify spending an extra £275
The Dell 2711 is individually calibrated and comes with a printed report (As do the pro 24")
Guinevere is offline   Reply With Quote
Old 22nd Aug 2012, 12:48   #19
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
I think it looks nice, but I honestly don't like glass covered lcds
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 22nd Aug 2012, 13:56   #20
Ciber
Multimodder
Ciber's Avatar
Ciber has yet to learn the way of the Dremel
No point going on about apple thunderbolt display as I don't think that will connect to most PCs.
__________________
BF3 - Maxson
BFBC2 - CiberWulf
Ciber is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
