Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Aug 2012, 10:30   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Ergo reinvents the netbook with the GoNote GNT10
Question is: did it need reinventing?
http://www.bit-tech.net/news/hardwar.../ergo-gonote/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 22nd Aug 2012, 10:46   #2
TheDodoKiller
Supermodder
TheDodoKiller's Avatar
TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.TheDodoKiller is definitely a rep cheat.
What a ridiculous idea. it's a step backwards- I didn't think you could make a netbook worse but these clowns seem to have managed it.
__________________
- AMD 1090T OC'd at 3.6 Ghz - Asus Crosshair IV Formula - Reference Asus 6950/70 - Silverstone FT02 B-W - Kingston HyperX 3K 128GB SSD - Samsung F3 1TB - Kingston HyperX 1600 Ram 4GB - Coolermaster V8 -
TheDodoKiller is offline   Reply With Quote
Old 22nd Aug 2012, 11:35   #3
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
Erm... Okay...
For starters, not having Google Play restricts you to side-loading apps or third-party app stores, which aren't always going to have the same selection of apps available.
Mobile office suites will never be as capable as their desktop counterparts; I doubt they'd even compare to the functionality in OpenOffice or Libre Office.
I'd expect to be able to use Flash on my laptop/netbook - the usual issues of it not being designed for touch-screen use do not apply when you have a trackpad - and Android is no longer supported by Adobe.
A tablet OS will simply not work in a device with a keyboard and mouse. Have you ever tried Android x86? It's... awkward, to say the least... It might work in an embedded form factor, such as a set-top box, or in a touch-centric device, but it isn't really designed for use with a keyboard & mouse.
Why not just stick Linux on the damn thing and have an OS/interface which was designed to be used with a keyboard and mouse, and has a massive suite of applications available for the ARMv7 instruction set?
Finally, it's a netbook. You'd be better off spending that 149 on a well-built second-hand laptop - I certainly was.
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 22nd Aug 2012, 12:18   #4
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
utterly pointless and hardly an original idea, more like a failed attempt at a cheap knock off of the Asus tablets.
__________________
R7 1800X, ASRock X370 Taichi, 2x8GB Corsair Vengeance 3000 DDR4, ASUS Strix 1080TI OC, 512GB Samsung 950 Pro, 4TB WD Black, EVGA T2 1KW, Lian Li PC-O9WX, EK Supremacy Evo, EK-XRES 140 DDC 3.2, EK-CoolStream PE 360, Ducky Shine 6 (Brown Switches), Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 22nd Aug 2012, 12:49   #5
Fruitloaf
Tinkerer
Fruitloaf's Avatar
Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!Fruitloaf - it's over 9000!!!!!!!!1!1!1!!!
Why oh why design it so badly? Does it take much imagination to make the screen fold back all the way round and disable the keyboard at the same time plus add a capacitive screen? Ok it might add 20 to the price but its a lot more functional. It wouldn't be a tablet for one handed use but it would be a lot better.
Fruitloaf is offline   Reply With Quote
Old 22nd Aug 2012, 13:36   #6
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Resistive 'Multi-touch (2 finger!) screen? 1024x600 resolution screen? Terrible battery life? Crippled OS? Chunky-monkey form factor? Crazy high price for the spec?
Nice! This machine has everything we could never want!
Guinevere is offline   Reply With Quote
Old 25th Aug 2012, 03:02   #7
Lazarus Dark
Supermodder
Lazarus Dark's Avatar
Lazarus Dark has yet to learn the way of the Dremel
It they had just made a tablet +kb/dock, that would have made sense. Asus has had good success with that. But having an Android tab you can't actually use as a tab?
__________________
My gun kata is greater than your kung fu.
Lazarus Dark is offline   Reply With Quote
Reply
Tags
android, arm, ergo, ergo electronics, gnt10, gonote, netbook, rockchip
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
