#1 |
WIIGII!
bit-tech Staff
Adobe releases patches for critical Flash, AIR vulnerabilities
Time to start patching - or uninstalling.
http://www.bit-tech.net/news/bits/20...sh-air-vulns/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
I Mod, Therefore I Own
the winner for the most patched program on earth
Adobe Flash |
#3 | |
Hypermodder
__________________
The Angel Delights? |
#4 |
PAM says no...
Can we just leave Flash to die and move on to HTML5? Youtube has converted, but most other sites - like Flash game sites - still only use Flash. Adobe themselves are practically forcing people to stop using Flash themselves - dropping Linux support, removing the Flash app for Android etc. It seems that even Adobe want to get rid of this aging technology!
__________________
The Linux Schools Project |
#5 |
Supermodder
'four memory corruption vulnerabilities, an integer overflow vulnerability, and a cross-domain information leakage issue'..... I only went to the GP for a check-up and this is exactly what he diagnosed me with as well
#6 | |
Supermodder
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
#7 | |
How many wifi's does it have?
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#8 |
You are always where you want to be
Just finished imaging 600 odd windows 7 machines over 3 sites. 3rd year in a row Adobe have waited until we have just about finished with the yearly image before deciding its massively broken : (
#9 |
Multimodder
Anyone else notice that Win8 refuses to update Flash for IE? The Adobe Flash download webpage tells me to enable compatibility view lists in IE (which already are enabled) but Windows Update doesn't install a new Flash like it is supposed to. If you manually download the Active X version of Flash it won't install in Win8. I wish I could say it was a software glitch only on my one PC but this happens in my desktop's virtual machines as well as on my laptop. So right now there is no way to manually update IE's Flash on Win8...
#10 |
Minimodder
This is a good thing, as it will only accelerate the development and acceptance of HTML5. I love developing in Flex/Air/Flash, but it's time to move on.
#11 |
Theorist
That is a horrific list of vulnerabilities...
__________________
i5 3570k (stock) + Titan Fenrir Asrock Z77 Extreme4 PNY HD4890 (stock) OCZ ModXStream Pro 700w Silverstone FT02-WRI <-- sexy |
#12 |
Supermodder
3rd paragraph - "vulnerabilities that could case a crash", should it not be "cause a crash" :-)
| Tags |
| adobe air, adobe flash, flash player, patch, security, vulnerability |
| Thread Tools | |
