Reply
Thread Tools View Mode
Old 25th Aug 2012, 22:02   #1
JitsuSparty
Multimodder
JitsuSparty's Avatar
JitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run Crysis
So Say We All - BitFenix Prodigy, UPDATED 11-1-13
Ok so Project Log, right here goes...
Introduction:
Basically I have all my media on a NAS drive and one day I got fed up of having to move my main PC every time I wanted to watch media on my TV. So I started looking around the net to see what was out there, cutting a long story short I came across the BitFenix Prodigy and it seemed ideal for what I wanted to do.
So I ordered one online without thinking about modding it - then I came across a few mods online (watercooling, powdercoating etc) and thought to myself - hey I could do that First case arrived damaged but was replaced very quickly so but this gave me time to think about a theme for the case Mod.
The Grand Design
I started thinking how could I design the mod around my LAN/Uni Nick - but all the ideas were basically a bit s**te. Then I had a bit of inspiration (possibly after a drink or two or more) - a Battlestar Galactica (BSG) themed mod.
For those of you who dont know what BSG is it's a sci fi show that was remade recently (I watched the original growing up) - and my mod is basically themed around this bit of imagery
http://hbowatch.com/wp-content/uploa...a_logo-HBO.jpg
any way I made a few sketches (I will look to post a few perhaps - Im not a great artist)... so heres my progress so far (word of warning my weekend shall be the time when I can work on this so expect weekly updates)
Project Log
25/8/12
So the case arrived - first thing I did was to take it apart slowly - but not slowly enough, managed to snap one of the plastic tabs clean off (job for araldite later in the project). I then drilled out all the rivets on the case (some with the application of hammer and screwdriver).
The case mod revolves around creating a window in one side and a motif cut/etched into the other side. This involved swapping the sides over, as I removed the pcb board with the power supply rest button etc.
As I am sure you know sqaures don't exsist in BSG - everything remotly rectangular seems to have the corners cut off - so I started by sketching up the area to be cut out to make the window. I also printed out a stencil to get an idea of fonts to use later on, the initial idea was to put the acrylic on the inside of the case - so I could just glue it on and not worry about it having to look too neat.
Anyway the acryllic arrived and I realised that the clearance inside the case between the side panel and internals isn't enough to put the window on the inside so I had the idea - why not put it on the outside and 'carefully' rivet it on.
So as you can see from above I have cut out a very rough template for the window... all I can say is safety specs are a must, acrylic seems to like breaking, and my Dremel wannabe (from Maplins) kept throwing little pieces of acrylic into my face.
anyway plan for tomorrow is to try and start cutting out the metal for the window. As well as try to get my sketch pics onto here.
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!"
So Say We All - BitFenix Prodigy casemod
JitsuSparty is offline   Reply With Quote
Old 25th Aug 2012, 22:03   #2
JitsuSparty
Multimodder
Reserved for update
__________________
Old 25th Aug 2012, 22:03   #3
JitsuSparty
Multimodder
reserved for another update
__________________
Old 29th Aug 2012, 18:26   #4
JitsuSparty
Multimodder
Update 29/8/12
So this is my initial concept design - the aim is to focus on the two side panels, firstly putting in a side window (mentioned above) and then secondly getting the phoenix from this cut into the side
Seeing as I work at an engineering company I had a chat with the guys and had my expectations scaled back a bit - as the clearance between the lines is too tight to laser cut or get made. So back to the drawing board there.
anyway I plan to make some more progress over the weekend.
__________________
Old 29th Aug 2012, 18:32   #5
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.Tangster is the Cheesecake. Relix smiles down upon them.
Originally Posted by JitsuSparty View Post
Update 29/8/12
Instead of getting it cut straight out of the side panel, what about getting the pieces cut separately then mounting it to a clear plexi window?
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M
Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 29th Aug 2012, 18:34   #6
JitsuSparty
Multimodder
Now you just thought of the solution I did, currently in the middle of sketching it out on some paper
__________________
Old 29th Aug 2012, 18:49   #7
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Just on the second season of BSG now! have to say it's awesome and your mod looks to be the same
Good luck
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 29th Aug 2012, 18:50   #8
JitsuSparty
Multimodder
Good luck
Thanks - and I do plan this mod to be spolier free.
__________________
Old 29th Aug 2012, 19:03   #9
aramil
Duct Tape Saves......
aramil's Avatar
aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!aramil - it's over 9000!!!!!!!!1!1!1!!!
Especially the episode when.......
In case you have not seen this :Colonial Warbook, it has lots of artwork etc might inspire something.
__________________
System: Intel i5 3570K delidded CLU @ 4.6Ghz | Asus Stabertooth Z77 (1708) | Asus GTX560-TI Direct cuII | OCZ Agility 3 120Gb | Samsung 1Tb F2 | WD 500Gb | Corsair 750TX v2 | 8Gb (2x4) Corsair Vengence | XSPC-Raystorm-750-RS2400 (2 X Akasa viper) | Casecom 5288 | Samsung LS24B300HL / LE32R74 / LE46C750 | Windows 8 Pro 64bit | Audio: Linn Classik & Keilidh Speakers
aramil is online now   Reply With Quote
Old 29th Aug 2012, 20:02   #10
Editor22
E22.BIZ
Editor22's Avatar
Glad to hear it I can come back now lol
__________________
Store: E22
Old 29th Aug 2012, 20:24   #11
Carrie
Weren't me guv
Carrie's Avatar
Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.
Update 29/8/12
There's a guy Teelzebub knows who does very detailed work on case panels etc. which he has some pic examples of. He's very good, does exhibition work etc. Why not contact Tel to see if you can realise what you actually want.
__________________
MountainMods H2GO - the little case, i7-860, ROG Maximus III Forumla, 2 x 2gb GSkill Trident F3-1600 @ 2k, Coolermaster RS700-80GAD3-UK Silent Pro Gold 700W, Noctua NH-C14 dual fan, Gigabyte GeForce GTX 460 OC 1GB, 1 x 500GB Seagate 7200, Samsung 830 SSD, 500Gb WD, Samsung 12x B/ray, AeroCool F/C, E'max Apollish/Cluster fans.
Now building a scratch build HTPC
Carrie is offline   Reply With Quote
Old 29th Aug 2012, 20:28   #12
JitsuSparty
Multimodder
Originally Posted by Carrie View Post
There's a guy Teelzebub knows who does very detailed work which he has some pic examples of. He's very good. Why not have a word with Tel to see if you can realise what you actually want.
To be honest - right now I am not sure what I actually want, Unlike the ubiquitous cylons I don't really have a plan and am winging it a bit.
One thing I do know is I want to get my hands dirty as much as I can - so will be borrowing my mates mill and power tools in the near future.
__________________
Old 29th Aug 2012, 21:43   #13
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
Just seen this, Yea the guy I know could do that in his sleep, tbh he's pretty busy doing big projects really.
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 29th Aug 2012, 21:46   #14
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
BSG mods need rep, have some mate.
Think I just gave you 4 lights
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is offline   Reply With Quote
Old 29th Aug 2012, 21:50   #15
Teelzebub
Teelzebub's Avatar
Yea it was only 4 Dan I would have expected better of you
__________________
Old 29th Aug 2012, 21:58   #16
JitsuSparty
Multimodder
Thanks for the rep
anyway a quick update preview before I hit the sack.
Update 29/8/12 part B
So having done a few sketches this evening and looked at the case I decided I need to get a bit more color into the project, so the plan is to cut a ~ 10 cm diameter hole in the side of the case. I plan to put a circular piece of acryllic in the hole (possibly colored) with a decal/symbol on it that will be back lit from within the case.
as for the main window - I am torn between a centurion etch for the window or Gaius Baltar (My favorite BSG character - mainly from series 1 tho)
__________________
Old 29th Aug 2012, 22:00   #17
jamesriley94
Minimodder
jamesriley94 has yet to learn the way of the Dremeljamesriley94 has yet to learn the way of the Dremeljamesriley94 has yet to learn the way of the Dremeljamesriley94 has yet to learn the way of the Dremeljamesriley94 has yet to learn the way of the Dremeljamesriley94 has yet to learn the way of the Dremel
One of the first proper prodigy mods I've seen - Interested to see where this heads
jamesriley94 is offline   Reply With Quote
Old 30th Aug 2012, 13:53   #18
jon
Multimodder
jon has yet to learn the way of the Dremel
You had me at "So say we all ...."
__________________
DargonZine: The longest running fantasy magazine on the net. Period.
jon is offline   Reply With Quote
Old 30th Aug 2012, 13:58   #19
whatsthatnoise
Modder
whatsthatnoise has yet to learn the way of the Dremel
Woaah, I hate that egocentric maniac! I'd go with the Centurion, ofc.
Love the series though, should make an awesome theme for a mod.
whatsthatnoise is offline   Reply With Quote
Old 30th Aug 2012, 14:56   #20
jon
Multimodder
ah, but ... where goes Gaius Baltar, so goes Caprica Six ...
__________________
Reply
Tags
bitfenix prodigy, case mod, window
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
