Reply
Thread Tools View Mode
Old 30th Aug 2012, 15:15   #21
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
Originally Posted by whatsthatnoise View Post
Woaah, I hate that egocentric maniac!
He's hilarious, especially when he gets the Yorkshire accent kicking off when talking about his childhood.
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is offline   Reply With Quote
Old 30th Aug 2012, 15:20   #22
M_D_K
Kiteninja
M_D_K's Avatar
M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.M_D_K is a hoopy frood who really knows where their towel is.
Am looking at getting one of these cases for work , looking good so far.
I too work in engineering why exactly could they not cut the side panel ?
__________________
MY Flickr -- My Website
A Camera, Some lights, Bag of ideas & A white stick
M_D_K is offline   Reply With Quote
Old 30th Aug 2012, 16:14   #23
JitsuSparty
Multimodder
JitsuSparty's Avatar
JitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run CrysisJitsuSparty can run Crysis
So - basically to get it CNC milled would require the use of small diameter cutters - more expensive due to time and possible tool breakage.
looked into Laser cutting - but the width of the remaining metal was too thin.
anyway i have been talking to a mate with a mill and have a plan which I think will look better in the end
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!"
So Say We All - BitFenix Prodigy casemod
JitsuSparty is offline   Reply With Quote
Old 30th Aug 2012, 18:33   #24
whatsthatnoise
Modder
whatsthatnoise has yet to learn the way of the Dremel
Makes sense, but you could simply edit the outline of the cutout in Photoshop. It should also be able to set up the laser cutter to go along the inside of a line not the middle of it, which leaves more material left standing, too.
whatsthatnoise is offline   Reply With Quote
Old 30th Aug 2012, 20:24   #25
adidan
CPC_refugee
adidan's Avatar
Share your idea mate otherwise I won't be able to shake this image:
__________________
Old 30th Aug 2012, 20:36   #26
JitsuSparty
Multimodder
Thanks for the new avatar - as for my idea I am doing some sketches so I can show you guys tomorrow... I would rather make you wait then put a half assed update out
__________________
Old 31st Aug 2012, 14:40   #27
adidan
CPC_refugee
adidan's Avatar
You're welcome.
Sketches. I like sketches.
__________________
Old 31st Aug 2012, 15:58   #28
JitsuSparty
Multimodder
Apologies today's update is postponed until tomorrow due to being at the oval watching cricket
__________________
Old 31st Aug 2012, 17:39   #29
adidan
CPC_refugee
adidan's Avatar
That is a more than adequate reason.
__________________
Old 1st Sep 2012, 13:57   #30
JitsuSparty
Multimodder
Update 1/9/12
right so firstly an apology - I havent been able to actually physically advance the mod between the last update and this one - I should be able to make some progress next week as my mates mill will be available. However, I now have a set of designs firmed up:
so these two images show my intended mod in almost all the detail. Starting with the 1st side:
I plan to cut a O hole of ~ 9 cm diameter in the centre of the case (the dashed line), then cutting a piece of acrylic (possibly coloured) to just under this diameter. This will then be held in the centre of the hole with locking strip.
The 'phoenix' motif I plan to get made into a custom decal to go on the inside of the acrylic - which can then be back light from within the case. the ring around this I plan to cut through the case - to provide some ventilation.
the other side has the window (the hole needs to be finished cut), on which i plan to have another custom decal - this time as an etch. The wording above will be painted on top of the powder coating.
anyway I have also marked up the acrylic I have and hope to cut it tonight/tomorrow
So that's an update - sorry this mod will be slow as I can't always afford stuff right away and this mod is also unsponsored - as such may be a month or two before I can even think about putting components into it.
Anyway thanks for listening
__________________
Old 2nd Sep 2012, 09:41   #31
JitsuSparty
Multimodder
Update 2/9/12
So quick update. Tried to cut the acrylic window to size yesterday and well I'm glad I started with a test cut on a piece of scrap - as it decided to crack badly so waiting to borrow a few tools from a mate on Monday.
Anyway going to order rest of the materials I need to finish the case today
That's all for now folks
__________________
Old 2nd Sep 2012, 09:58   #32
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Can't wait to see those acrylic pieces!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 2nd Sep 2012, 11:11   #33
JitsuSparty
Multimodder
I may have taken out my frustration on the poor remaining piece of acrylic:
oh and just spent an hour resizing editing all the pics
__________________
Old 2nd Sep 2012, 11:17   #34
Angel OD
Pump Killer
Angel OD's Avatar
Yeah, that's the problem with acrylic... Lexan/polycarbonate does not explode like that, which is why I almost always use that in stead!
__________________
Old 2nd Sep 2012, 11:19   #35
JitsuSparty
Multimodder
oh it didn't explode, I may have got a bit over enthusiastic with a hack saw/dremel knock off
__________________
Old 2nd Sep 2012, 12:22   #36
whatsthatnoise
Modder
"Oh what's that? A crack? ... WHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAAAAT T F!!!! Take THIS and THIS and .... AAAAHHH...."
Ooops, looks Damaged.
There's nothing like getting a bit carried away on a shiny day.
Old 2nd Sep 2012, 15:51   #37
Angel OD
Pump Killer
Angel OD's Avatar
That was my point! Lexan/polycarbonate would not have reacted like that. Not the crack, nor the aftermath!
I do, however, believe that your comment was worth JitsuSparty's misfortune!
__________________
Old 2nd Sep 2012, 16:05   #38
adidan
CPC_refugee
adidan's Avatar
crack badly
That sucks mate but I'm glad you mention it.
I've yet to do a case mod/scratch build and most of the ones I read generally go along the lines of - had a great idea, cut this stuff out perfectly, created this beautiful piece of furniture/pc and life is groovy.
I knew it couldn't be that straight forward.
Chin up mate.
__________________
Old 2nd Sep 2012, 16:10   #39
JitsuSparty
Multimodder
Chin up mate.
Well I started out with an ok idea developed into what I think is a great idea, spent quite some time sketching/planning/dreaming. Then when I actually bought some stuff made sure I had enough then some - I bought twice as much acrylic as I needed just because I knew i hadnt used it before and breakages would happen.
one thing I will stress to anyone planning on doing anything get some safety specs and wear them.
__________________
Old 2nd Sep 2012, 16:23   #40
Angel OD
Pump Killer
Angel OD's Avatar
Have some rep on that point!
__________________
Reply
Tags
bitfenix prodigy, case mod, window
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
