#61 |
Multimodder
Update 10/9/12
So this evening I carried on with the cutting of parts, managed to tidy up the side panel some... might possibly need some acrylic polish, but will have to see when I finally take the protective coating off it. tomorrow I plan to finish cutting the edges and then start to sand the sides down feel free to subscribe (though I probably should of said that 4 pages ago)
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!" So Say We All - BitFenix Prodigy casemod Last edited by JitsuSparty; 10th Sep 2012 at 21:31. Reason: because I can |
#62 |
Multimodder
Update 12/9/12
So original idea was to get the case powder coated after I had done all the cutting, I wanted to do this so it would look sleek and be hard wearing. I went to my local powder coating shop, took part of the case - they tested it and said "we can coat that no problem", I then said "how much would it cost?" he replied "your looking at £100 if we have the colour in stock otherwise over a grand" ![]() So Plan B I now plan to paint the case using, wait for it, car paint First stage is to sand the paint off the case as it is - so I can start from base coating the bare metal for an even finish I have borrowed a mouse sander from a mate and should be able to get sanding tomorrow anyway as an update that is all Thanks for listening :P
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!" So Say We All - BitFenix Prodigy casemod |
#63 |
Multimodder
Well i love the bitfenix, so good luck with the project.
__________________
Cm Storm Enforcer|Intel i5-2500k|Asus p8p67 pro|8gb DDR3 Corsair Vengeance LP Blue1600mhz|EVGA GTX 460 1gb| Arctic Cooling Freezer 13 Pro|Corsair Force 3 60gb SSD|Hitachi 1tb Hard Drive| Windows 7 Professional|
#64 |
Multimodder
Update 15/9/12
Ok so this is a little big update. Firstly thanks to a mate at work I got a workbench now As mentioned before another mate leant me a mouse sander, so I thought I would crack on with the window side of the case.(BBQ is from last weekend )The acrylic panel was rough cut, so I put it in the bench and started working on it. I started off trying to sand it by hand with a piece of coarse sandpaper - this gave an uneven and 'scratchy' finish. So I started 'scrapping' it with a knife blade: this worked well - and gave a good finish, however I decided I would use the sander to 'polish' the edges. As I used the sander I made sure I wasn't applying pressure downwards so it was just lightly sanding it and not eating away material. Also you might notice in the picture there is a piece of wood between the jaws and the acrylic - this was to provide a straight edge to scrape/sand against I'm quite happy with the result: There's a slight scratch in the window though - don't think you can see it in the picture, but if anyone can give any tips on 'buffing' it out I'm all ears. Secondly I have to say I have some great mates, remember I started cutting the side panel a few weeks ago? Well the mate I was doing it with said he would finish it off for me - I owe him a few beers. Anyway here's the result: It's going well so far and I am not going to jinx it by saying how far I want to get this weekend
__________________
#65 |
What's a Dremel?
Looking good so far i have never seen a BSG mod before so im subbed
#66 | |
Multimodder
__________________
#67 |
Multimodder
keep up the work watching this, fan of small cases
#68 |
Multimodder
Update 20/9/12
Sorry all for the lack of progress with this - currently being held up by resource availability (£) and waiting for side panel to come back from laser cutters. Just in case anyone was thinking this had died - It's alllllliiiveeeeeee
__________________
#69 |
Multimodder
Apologies to anyone reading this - case mod has stalled
due to weather, de niro, and slow lazy laser cutter.so while I am waiting to carry on with stuff here is my wishlist of things to put into it:
__________________
"Hello, my name is Inigo Montoya... You killed my father prepare to die!" So Say We All - BitFenix Prodigy casemod Last edited by JitsuSparty; 25th Sep 2012 at 17:43. Reason: I can't spell |
#70 |
Multimodder
Update 29/9/2012
Thought it was about time I did an update (thought Im feeling like you dont love me :P) I've found I have hit a proverbial brick wall, seems modding isnt all action and plain sailing - am currently getting frustrated with the lack of progress due to several factors: Firstly I cant move on without getting both side panels back - as this will be the point I can make final measurements and (hopefully) get the case painted. secondly sh**e weather here - I am modding in my house so my work area is my lounge and garden... I have a load of sanding to do and am finding it easier/cleaner to do it outside. (updated update) - I have one side panel back - and am working on sanding and filing it to size - I will put up a pic tomorrow I promise anyway the plan is to put a watercooling loop into this and as such this is my idea for the loop and fans
__________________
#71 |
Multimodder
UPDATE 4-11-12
At last I have laser cut side panel !!!!!!! All the guy charged me to do it was some beer - I think he was expecting a bottle and was shocked when I gave him 4 cans of London Pride Anyway this means I can start moving on with my mod I started cutting out the piece of acrylic to go in the 'hole'... then found that with the rubber mounting I bought the hole in the middle is too small... so will have to see what I can find that is thinner anyway - I hope to get a fair bit more done over the weekend Yay !!!
__________________
#72 |
Multimodder
This ISN'T dead!!!!!!!!!
sorry updates will be slower as I am waiting to get it powdercoated and am in germany this weekend for first holiday of the year in a vain attempt to get interest going please feel free to comment with ideas on what I could put in it when it is done
__________________
#73 |
Multimodder
Ok - sorry to anyone who thinks this died, basically been off the radar for a while (mainly due to work/£ issues)
this should start moving forward again soon so please get re interested
__________________
#74 |
BF3 Username - D0rmarth
dont worry we are still here, im currently doing a BitFenix Survivor mod so im very interested in what you are doing here.
I finding things the same as you waiting for the panel to be done, lack of money this modding life is a hard one !!
__________________
BF3 Username - D0rmarth |
#75 |
P.s with your top rad i would go with a push pull config
__________________
#76 |
Multimodder
thanks, to be honest I nearly wrote this off... but a few mates pushed me on (and theres a £5 bet at stake)I wont be doing anything for a couple of weeks - but I aim to get the modding of the case done by christmas, powder coating in new year... and then look at putting stuff in it
__________________
#77 |
There are some great guides on painting I would have a quick search around the forums but im sure another member can point you in the right direction.
__________________
#78 |
Supermodder
What the frack is going on?! A new BSG themed case!
__________________
Current projects: Graphite 5 | Tydirium is on the way! Previous mods:|Sandcrawler Mod| |Illuminated Mind| Follow me on Facebook |
#79 |
Multimodder
hope you like it - I will have it done in the future... might have to watch BSG again though in the mean time
__________________
#80 |
Multimodder
Necro time,
![]() So I have had a few set backs in the past few months - I won't be watercooling the rig now and I am not sure what colour it will end up being powder coated... During Dec had a few issues that meant my funds and will to continue kinda tailed off - Sorry guys.However, I have started purchasing pieces to go into it to motivate me currently I have:A silverstone strider fully modular 650W PSU Gigabyte Z77N-WiFi mobo i5 3750K ivybridge processor (in the mail) Basically I am now looking for a cooler, I have been looking at the all in 1 hydro coolers from corsair and want to know if anyone has one and whats it like. Or I am looking for an aircooler - but not sure due to clearances on the mobo - again suggestions appreciated. Anyway again sorry if it looked like this had died, I am planning on getting it finished by Feb
__________________
| Tags |
| bitfenix prodigy, case mod, window |
| Thread Tools | |
| View Mode | |
