Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 26th Aug 2012, 10:54   #1
biojellywobbles
Multimodder
biojellywobbles's Avatar
biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.biojellywobbles is a hoopy frood who really knows where their towel is.
My Homemade Aluminium Case
Hi everyone, I just wanted to show off my prototype aluminium case that I've made for my secondary PC. There will be a markII of this case coming soon that will be a little larger so as to fit a full size mATX board and a 240mm radiator which will be for my main build.
I made it mainly out of aluminium angle using hand tools aside from a battery drill.
This is one of the sides, I just cut out a 90* triangle from the angle and bent them in a vice.
The work area.
Two sides done!
And suddenly a finished case! (Didn't take enough pictures got too carried away working on it! )
Yes I know it's not got a shell and the 120mm fan is just standing there at the moment but it will be blessed with a thin veneered wood shell and will act as a server once I get back to uni.
Any feedback you have would be great! The next one should be a vast improvement now that I've had a trial run plus I've recently got a rotary tool so that should make drilling some of the more awkward rivet holes far easier.
__________________
Main box: FX 6300 @4.2GHz, 8GB Value RAM, Nvidia GTX 470, Corsair Force GT 90GB, Silverstone PS07, Win7
biojellywobbles is online now   Reply With Quote
Old 26th Aug 2012, 16:55   #2
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
No need for a next one. That's a perfectly good frame. You can get some more practice in putting a "skin" on this, and dressing it up/cat-proofing it.
Cheapskate is offline   Reply With Quote
Old 26th Aug 2012, 17:25   #3
Fonne
Multimodder
Fonne has yet to learn the way of the Dremel
Thats a very nice frame
Fonne is offline   Reply With Quote
Old 26th Aug 2012, 18:39   #4
Loafers
What's a Dremel?
Loafers's Avatar
Loafers has yet to learn the way of the Dremel
very simple; me gusta!
Loafers is offline   Reply With Quote
Old 27th Aug 2012, 10:02   #5
biojellywobbles
Multimodder
There's a few rough edges and the main reason for building another one is te be able to fit full size PCI cards and larger mATX motherboards so I can use it for my gaming PC. This one will be my home server case I'll add pictures once it's all covered up too.
Thanks for the compliments guys!
__________________
Old 27th Aug 2012, 16:47   #6
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
Ah, but there is no such thing as a larger mATX board ATX (and mATX) is a standard. So each and every mATX is 24*24 cm (forgot the exact number).
What kind of wood are you going to slap on that frame? and will it be totaly covered? or leave the alu slightly exposed?
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 27th Aug 2012, 18:04   #7
biojellywobbles
Multimodder
This mATX board is about 20 x 24 seems some of the lower end AMD ones tend to be that way to cut costs a bit.
Planning on covering it completely with a plywood shell with an oak veneer it will follow the curve of the alu at the front. Not sure i'll get round to doing it before I get back to uni now though so it might stay naked for a while yet.
__________________
Old 28th Aug 2012, 06:05   #8
alpaca
llama eats dremel
alpaca's Avatar
Ah, i never encountered that maybe the board is not yet fully grown? . . .
__________________
Old 28th Aug 2012, 15:34   #9
randomhero
Multimodder
randomhero has yet to learn the way of the Dremel
I think the maximum size for a mATX board is 24cm x 24 cm, any bigger and it would be considered a small ATX board.
Please correct me if I'm wrong
__________________
Mobo: ASUS P8P67 CPU: Intel Core I-7-2600K @ 4,636 GHz GPU: 2x MSI N560GTX-Ti Twin Frozr II @ 1022 Mhz RAM: 4x4GB Corsair Vengeance DDR3 1600 MHZ CL8 Storage: Seagate Barracuda XT 2TB and waiting for OCZ Vertex 3 to be released in Norway Case: Fractal Design Define R3 Black Pearl PSU: Corsair AX 850W OS: Windows 7 ultimate x64 Keyboard: Logitec Illuminated Wireless Keyboard K800 Mouse: Cyborg R.A.T 9
randomhero is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
