Thread Tools | View Mode |
#41 |
Multimodder
looking good keep up the good work
#42 | |
Professional Sleever & Modder
![]() It will soon be finished ![]() Thank you mate ! Last edited by KoSoVaR^; 14th Sep 2012 at 20:30. |
#43 |
Hello Guys!
Sorry for an late update, but better late than never....right ? I started to take the case appart more, this time the case feet and handles. They had to be gone becaose of the rivets who are placed behind them and need to be removed so that i can take the bottom piece appart. ![]() After the drill it looket like this ![]() Here you can take a look at the simple modification that i did, that piece touched the endtank and didnt let me to allign the rad with the holes, it also didnt let the rad to stay flush with the front. Could you think that a 2mm piece of plate could do such difference? ![]() White rivets fromMDPC-X, a lot of them ! ![]() Then it was time to rivet everything together, i also did the motherboard tray, went like a charm! ![]() ![]() Something i am doing meanwhile! ![]() ![]() That was the update for tonight everyone !
#44 | |
What's a Dremel?
Thank you for the update! Last edited by danjw1; 16th Sep 2012 at 20:10. Reason: Fixing the quote to add an opening tag :-) |
#45 |
Keep calm & mod on. =)
This
I like your mods KoSoVaR, tidy, nicely coordinated & super nice sleeving. ![]() I just go through phases of modding my rear off, vegetating, crazy long times on design tweaks & then having a good browse through the projects I might have missed, this being 1 of a heck of a lot, I often rely on MOTM to open my eyes to new projects I miss also.
#46 |
Never stuck with stock@Hotmods.net
Weeee! Subbed.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#47 | ||
The front will be my outtake and there will be enough of flow for that reason ![]() Quote:
![]() I will do some more and continue with my clean modding very soon! Thanks dude, more candy coming soon
#48 |
What's a Dremel?
i am expecting a great result from this! subscribed!!
#49 |
Im glad to hear that
#50 |
Modder
Stubbed.
Excellent progress so far and lot of great attention to detail! I was thinking of getting a Prodigy case when I update my rig next, so I'm following this with interest. |
#51 | |
Thank you ![]() More to come
#52 |
What's a Dremel?
awesome build!
I know it is wrong to put pressure on an artist at work but i need a update on this build soon haha
![]() Great job mate!
#53 | |
![]() Thank you so much
#54 |
What's a Dremel?
#55 | |
#56 |
I just had another look at your radiator pics - with the rads sitting that close to each other, you will have problems fitting fans on one of them, or not?
__________________
#57 | |
Multimodder
Bitspower + Prodigy = Amazingness
That acrylic is for the PSU?
__________________
#58 |
Hypermodder
Looked at my Prodigy case and looking at where the rads are going to be positioned it looks like there could be issues yes, how are you going to get round this Kos?
__________________
Project in progress: Bitfenix Prodigy Stacker
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker Modding is addictive!! |
#59 |
Mod is my life!
will be a beautiful work!
__________________
SORRY FOR MY BAD ENGLISH!
#60 | ||
![]() Yes and Yes !Quote:
Thank you ! |
| Tags |
| bitfenix, kosovar, kosovarmods, monobits, project |
| Thread Tools | |
| View Mode | |
