Reply
Thread Tools View Mode
Old 14th Oct 2012, 23:08   #21
metalglasses
Minimodder
metalglasses has yet to learn the way of the Dremelmetalglasses has yet to learn the way of the Dremelmetalglasses has yet to learn the way of the Dremel
The reason why it got one probably because of a sloppy introduction.
metalglasses is offline   Reply With Quote
Old 7th Nov 2012, 06:47   #22
metalglasses
Minimodder
It has been a while since I made a post, I have been busy lately, so here is a update from my log
(10-17-12)
I just did the legs, they turned out pretty good. I also made up a new side (where I messed up on fan port positions) for the box.
I made the angle at 103 degrees, the leg may seem short. V.1 is about 22 1/4 off the floor, with this project, the height will be 23 1/4. In addtion, my knee won’t touch the radiator. With that aspect, it will be nice during the winter months.
(10-19-12)
I thought that I should throw this up. I cut out the holes of the sides for the fan ports. Flush route them, I’ll have to sand them at the wood shop.
Getting the Jigsaw set up.
After finishing routing the holes flush.
I also took the time to make the hole for the motherboard tray.
I actually want to make some coasters out of these.
Also, I took some time to trim up my “almost” done assembly bench (30″X60″) I only have 3/4″ plyboard right now, I am working on another 3/4″ of ash (same wood for this project). It won’t be too hard on the tools, it is a good, strong, cheap wood that is really underrated in my opinion. For those who don’t know, it is the wood that is used for baseball bats.
Anyways, that’s the update of the day.
10-25-12
I just found out that I am 1/4″ short on a piece of stock! more like it is a 1/4″ thin. The piece I am as of this post, will call it the back hood as it refers to the rad. HD’s, PSU. Anyways, look at the back piece of the isometric view and that piece should of been 8″ instead. The solution to this problem is to make up a short piece about 1/4″ wide, glue that on, plus to help cover it up even further, I’ll put up some veneer Beside it would probably work better than what I was originally intending (leave it alone).
That’s it for tonight as far as actual progress.
On the side note, I took some pics while I was test fitting the box of the desk.
This will look really GOOD! once I get the spar poly-urethane.
11-5-12
I just finished gluing up the top section of the desk. I have been a bit slow because of life.
I didn’t take as much progress photos as I liked. So here is what I have taken.
This is me drilling a hole for the wires to come out from the back.
After I glued up the “upper section”. For some reason I hope I glued the inside peice right. I usually check my work after everything is settled, but I didn’t tonight. I’ll have to wait and see tomorrow (I kind of have to move it before somebody decides it’ll be a fun idea to break other people’s stuff). (update) it is fine.
Anyways, I am tired from trolling on facebook about our dumb ass election. I'll go read a book or play TF2.
Old 4th Dec 2012, 04:16   #23
metalglasses
Minimodder
Construction is pretty much done
12-3-12
As of tonight, I finally bring home the desk. It has been a month since the last update because of an another project, paper, and prepping a deck in the garage.
So here is what happened… not much really.
First, I made some floating tenons (beefy biscuits) for the jointing of the legs and feet.
This is one tenon that is prepped.
There’s the mortise’s
Then I finally get to bring it home after gluing the legs over the weekend.
Anyways, it doesn't look like I'll get to applying the finish after finals, so yeah that's progress thus far.
Old 5th Jan 2013, 04:15   #24
metalglasses
Minimodder
It's almost done!
...and it's taking forever for me to put the last peices together.
To recap since the last post, I put about three coats of poly-eurathane, it looks awesome. I took advantage to show off the imperfections of the wood.
I had a problem with the motherboard... actually I had it since I transfered it to the first desk from a tower. It would either shut down on me or lose display. that was a year ago, the problem fixed itself? I really don't know what happened, all I know is I drained the power, didn't do anything till the next day and suddenly it worked? should of rma it but didn't. Anyways I wanted to upgrade anyways because of the placement of the x4 pci-e. Anyways got myself a new GD-80 990FX and it looks great.
As far as the liquid cooling parts go, I am going with a basic loop, rad-cpu-gpu-res-pump, nothing too special.
I got psu wire extensions for function and appearance as well. I did a lot of brass coating on the parts for accents. I was a bit worried about the color scheme: Brass, Blue, Black, and the glowing goldish wood. I will also add blue uv dye in the water. I had installed blue led strip about 2m long, wrapped about 3/4 of the perimeter. A cold cathrone that I had laying around will be placed on the back side of the support beam under the desk only for appearence.
I also had some foam laying around, used it for filter materail for two fans (intake) and I'll go to the hardware store and buy some mesh and rattlecan it matte black. For the old fan contorler, I am prepping some scrap wood to make a casing for it, I'll probably put two coats of poly.
Right now, I am waiting on some more parts to get the machine running, I overlooked about ordering connectors for the pump. So I'll have to wait till the 9th. Kind of sucks, but if all should work out, it'll be on that following night.
Here are some pics of the project right now
Old 5th Jan 2013, 04:15   #25
metalglasses
Minimodder
It's almost done!
Old 28th Jan 2013, 06:04   #26
metalglasses
Minimodder
The project is finally working! only about 97% done. Apparently, my old MB, CPU, and discovered that my 6870 is out for the count. Got a Asus 990FX Sabertooth v.2, AMD 6200 Hexicore, and popped in my old 4870 just to at least warm up the seat for the replacement 6870 or 550ish nvidia card. I will hear soon from xfx about rma'ing the card and nag on the rma for the old 890 (I actually found the SN) and the 990 gd-80 as well (I couldn't find anybody with a compatible system and frustration) so maybe use it for a build to replace my parents dying dell.
I'll post pics when the project is finally done for your critique (other than it took too dam long towards the end, mostly my fault because of time management and rest is finals and the deck project, which also finally finished it as well).
Old 28th Jan 2013, 17:54   #27
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
You say 'too long'- I say 'room to expand.' May be you can sneak a 2nd rig in there someday. Spares come in handy, 'specially when they start breaking down on you.
Cheapskate is offline   Reply With Quote
Old 24th Mar 2013, 03:51   #28
metalglasses
Minimodder
Scratch Build Integrated PC desk V.2 (...since 1-25)
I absolutely forgot to throw up some of the finished pictures. I was busy during completion of the project. So here they are, it is running since 1-25.
Gotta love the flaws in the wood, so glad I grabbed the stock.
That should be it until I decide to do something with it.
Old 24th Mar 2013, 06:23   #29
postmangav
Multimodder
postmangav's Avatar
postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.postmangav is a hoopy frood who really knows where their towel is.
That looks absolutely beautiful. I wish I had your talent.
postmangav is offline   Reply With Quote
Old 25th Mar 2013, 15:31   #30
SavellM
Modder
SavellM's Avatar
SavellM has yet to learn the way of the DremelSavellM has yet to learn the way of the Dremel
Hey man.
Nice desk
Quick question, dont you find sitting there its a bit too deep?
SavellM is offline   Reply With Quote
Old 26th Mar 2013, 02:23   #31
metalglasses
Minimodder
@SaveIIM no actually, I sit right up to the desk nicely.
However I do find myself moving the keyboard back and fourth. It's right up to the edge for gaming and the rest of the time it is back a little bit. During the drafting process I had drawings to have the entire front end beveled because of this concern. I ended up scraping that design detail because I though it wouldn't look consistent with the whole design.
The first desk was about 6 3/4" deep, I wouldn't have the problem if it weren't the metal frame that I used for it. This new desk, I raised it to 2" and it doesn't feel though I have to lower my seat and the desk is about 1 1/4" thicker.
So I hope that answers you question.
Old 26th Mar 2013, 02:51   #32
moose67
Multimodder
moose67's Avatar
moose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysismoose67 can run Crysis
Awesome build....looks great in the dark.
__________________
---Asus Sabertooth X58---i7 950--Frio---6GB OCZ Blades---WD Caviars 250GB x 3---GTX 260 Sli---Creative XFi Extreme---CM 1000 watt Modular---Coolermaster Stacker---
moose67 is online now   Reply With Quote
Old 1st Apr 2013, 18:27   #33
iWatercool
What's a Dremel?
iWatercool has yet to learn the way of the Dremel
@metalglasses - could you tell me what type of hardwood you used? Thanks.
iWatercool is offline   Reply With Quote
Old 4th Apr 2013, 19:10   #34
metalglasses
Minimodder
@iWatercool, the hardwood I used is ash, a nice under-rated wood (I hope it stays that way, about $3 per board feet).
Old 4th Apr 2013, 19:13   #35
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
+1 on Ash being under-rated. I almost used it for a workbench build, but it ended up being more expensive than Red Oak, given the resources I had (and I found a cheap slab of Red Oak to eliminate laminating the bench top).
I missed the latest round of photos on this one. It looks great. The wood doesn't have flaws, it has character, and I love it. Great work
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 4th Apr 2013, 19:51   #36
Piotrek_PL
Minimodder
Piotrek_PL's Avatar
Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.
Looks awesome dude!
Only things I'd change is the placement of the reservoir and the loop in general nonetheless it's beautiful build.
Piotrek_PL is offline   Reply With Quote
Old 11th May 2013, 04:21   #37
iWatercool
What's a Dremel?
Thanks for the response. Ash is a good wood. Great work!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
