#1 |
What's a Dremel?
Project: Mirage 3000 (completed)
Hello everyone ! My goal is to make a jet-fighter themed mod based on a Cooler Master Elite RC-342.
![]() The unmodified case and the current state of the mod (updated regularly). ![]() Two inspiration pictures of the french jet-fighter "Mirage 2000". The main body will be two shades of gray. With black and yellow stripes for the fans grills and several markings (warnings, cockade of the French Air Force, ...). The front faceplate will get multiple switches to remind a jet-figter dashboard. ![]() The Cooler Master case and the Akasa fan controller. Faceplate will feature, among few other things, an Akasa fan controller with a green on black VFD display, a red "Military Fighter Pilot" toggle switch for power (linked to a key switch) and an anti-vandal resistant switch with cover for reset. Summary (1) - Front faceplate (plexy and power switch) (2) - Front faceplate (switches and leds) (3) - Front faceplate (first layer of paint) (4) - DVD player, fan controller and front fan grill (5) - Painting case & fan controller (6) - Painting side panels (7) - Assembling time
#2 |
What's a Dremel?
![]() Stripping the faceplate. ![]() Cutting out the part with usb/line-out/mic holes, power and reset buttons. I'm keeping the usb/line-out/mic part for later use. Cutting a plexy part to fill the void and fixing it with hex socket screws. ![]() Power switch will be this "Military Fighter Pilot" switch. Last edited by grandbruntenebreux; 5th Sep 2012 at 07:52. |
#3 |
What's a Dremel?
![]() More holes for more buttons (power, reset, key to allow power switch, three leds for power, two leds for hdd, two switches to turn on/off the leds). ![]() Plexy faceplate mounted. |
#4 |
What's a Dremel?
![]() First layer of paint on the front faceplate. |
#5 |
Multimodder
Well this looks like an interesting build, so i'll keep my eyes on this one
__________________
Cm Storm Enforcer|Intel i5-2500k|Asus p8p67 pro|8gb DDR3 Corsair Vengeance LP Blue1600mhz|EVGA GTX 460 1gb| Arctic Cooling Freezer 13 Pro|Corsair Force 3 60gb SSD|Hitachi 1tb Hard Drive| Windows 7 Professional|
#6 |
There is no rep for awesomeness.
Moderator
You've got the military look down pretty well.
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#7 |
Multimodder
Nice idea mate, but please add bigger shots!
#8 |
What's a Dremel?
I'm a sucker for those pilot switches. Will be following this one!
#9 |
Just starting out
Nice idea. shall be watching O_O
#10 |
What's a Dremel?
#11 |
What's a Dremel?
![]() Stripping the faceplates of DVD player and fan controller. ![]() Painting with duct tape for stripes. ![]() Fan controller, front fan grill and DVD player mounted. |
#12 |
Gentel-Mod'R
Update le PariGo!!!!
__________________
CanardWC, The Gentle-Mod'R with A Stupid N@m3 ![]() CM 690 http://forums.bit-tech.net/showthread.php?t=217260 RasPi http://forums.bit-tech.net/showthread.php?t=248805 OldNavY http://forums.bit-tech.net/showthread.php?t=217563 |
#13 |
Modder
It looks great right now but what are your plans for the guts of this thing?
#14 |
What's a Dremel?
#15 |
What's a Dremel?
![]() Inspiration pictures. ![]() Painting large darker areas for jet-fighter camo style. ![]() Preparation for painting. ![]() Not quite pleased with the result : "special curve" tape don't like heavy curve and many drips, will have to touch up with a brush. ![]() With blue-white-red paint and new buttons, fan controller is finished. |
#16 |
What's a Dremel?
![]() Painting french cockades on both sides of the case. |
#17 |
What's a Dremel?
Assembling time
![]() Redo of the curves with better tape masking. ![]() Time to assemble all the pieces ! Adding round headed screws next to fans to match the colors of fan controller buttons. Found a "Dassault Aviation" keychain "Remove before flight". 99% done pictures : ![]()
#18 |
What's a Dremel?
You can vote for it on the Cooler Master Contest
https://www.facebook.com/coolermaste...19693664758569
| Tags |
| airforce, airplane, cooler master case mod, jet-fighter |
| Thread Tools | |
| View Mode | |
