Go Back   bit-tech.net Forums > Technology > bit-tech Folding Team
Reply
Thread Tools
Old 31st Aug 2012, 18:50   #1
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyan
My 2P build- picture heavy
Hi all i thought i'd start adding pics of my build
i will let the pics do the talking
this is where im at so far
i will have it all up and running by the end of the weekend
__________________
3770k @ 4.8GHz, GTX980 OC'd, Custom loop,
kirk46 is offline   Reply With Quote
Old 1st Sep 2012, 07:13   #2
One_Box
Folder of the month April 2012
One_Box has yet to learn the way of the DremelOne_Box has yet to learn the way of the Dremel
Very nice Kirk, your kitten in pic one looks great as well
Did you purchase the mobo/cpus/memory new ?
__________________
Folding stats
Folding stats
One_Box is offline   Reply With Quote
Old 1st Sep 2012, 07:57   #3
kirk46
Cheesecake Nom Nom
kirk46's Avatar
Hi one box,
The mobo, cpu's and case were bought from bennieboy
The ram was bought new
The build has come to a halt
The radiator I have came with 6 bags of fan screws but they were 2 different sizes and I started fitting the fans to the rad with the longer screws, and now I've made a hole in the rad
Theres nothing in the box saying they are different sizes and when there all mixed together they all look the same size
__________________
Old 1st Sep 2012, 09:52   #4
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.TaRkA DaHl is the Cheesecake. Relix smiles down upon them.
Where exactly is the hole? As if it is just one of the metal fins it doesn't matter. Try leak testing it to see what happens.
TaRkA DaHl is offline   Reply With Quote
Old 1st Sep 2012, 10:24   #5
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Nice paint job.
Hope it is just one of the fins.
__________________
Folding stats
Folding Summary
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX Titan X Pascal; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 1st Sep 2012, 10:28   #6
kirk46
Cheesecake Nom Nom
kirk46's Avatar
What's happened is there's a plate under the screw holes, probably there to prevent this happening or trying too.
The screw has bent the plate into the fins and spilt one of the water channels, not sure what there called lol they carry the water thought the rad
Sent from my BlackBerry 8520 using Tapatalk
__________________
Old 6th Sep 2012, 12:42   #7
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
Good stuff Kirk, welcome to the SR2 club, I'm using the same case for my SR2 as well, I have a triple rad in the top and a dual rad in the bottom plus an EK SR2 chipset water block, runs nice and quiet but has a 24 thread 4.2ghz kick
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - EVGA GTX 980Ti | Alienware 13 Laptop, i7, Dual M.2 SSD's, 16GB and Graphics Amp
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 7th Sep 2012, 16:52   #8
kirk46
Cheesecake Nom Nom
kirk46's Avatar
cheers coola
do you have the PSU at the bottom?
i was think of to rads but wasn't sure due to the PSU taking space up
right i've received a temporary radiator off the market place today, its a 360 but only half height but it will do me for testing etc and i'l see how far i can push the cpus without them getting to hot
so she will be running this weekend
whats a safe temp for folding with E5620 xeons?
__________________
Old 8th Sep 2012, 08:16   #9
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
Intel says Tcase of 77.6 degrees, so I would set low 70's as the max.
Of course you are liquid cooling so should be able to hit less than that.
Old 8th Sep 2012, 08:53   #10
kirk46
Cheesecake Nom Nom
kirk46's Avatar
it says on core temp max 95c?
there at a low 2.7GHz atm and there ~40c when folding
im going to start a higher OC today
__________________
Old 8th Sep 2012, 21:43   #11
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
http://ark.intel.com/products/47925/...-GTs-Intel-QPI)
This is what I would trust over any third party program. But in reality temps are more down to the end user and you deciding how long you want the chip to live for. Hotter = less life.
Old 8th Sep 2012, 23:49   #12
kirk46
Cheesecake Nom Nom
kirk46's Avatar
yep thats where i was looking also....
im not going to let it get that hot... i hope
so far stress testing at 3.2GHz on stock vcore temp ~52c
__________________
Old 9th Sep 2012, 15:13   #13
kirk46
Cheesecake Nom Nom
kirk46's Avatar
im struggling to get these above 3.8GHz
__________________
Old 15th Sep 2012, 10:20   #14
kirk46
Cheesecake Nom Nom
kirk46's Avatar
just changed over to ubuntu and core 0 doesnt seem to be folding....
the other 15 cores are at 100% load hmmmm
ive install the kraken and BFS
EDIT: It seems to have sorted its self out now
__________________
Old 16th Sep 2012, 07:20   #15
One_Box
I know the recommendation for Amd multi-socket systems is to run the Kraken without BFS.
I'm not sure if this applies to Intel chips though.
__________________
Folding stats
Folding stats
Old 16th Sep 2012, 09:20   #16
kirk46
Cheesecake Nom Nom
kirk46's Avatar
on the (H) forum's ubuntu guide it says use both the kraken and BFS for multisocket intel systems
__________________
Old 17th Sep 2012, 18:49   #17
Slowlemon
Multimodder
Slowlemon has yet to learn the way of the Dremel
Hi Kirk
Looks like you just finished your first P8101 . How is the SR2 going? I like the white case. Are there any more pics?
__________________
Fold till it hertz.
Folding stats
Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7.
Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04.
Slowlemon is offline   Reply With Quote
Old 17th Sep 2012, 18:59   #18
kirk46
Cheesecake Nom Nom
kirk46's Avatar
hi mate,
yes it has
its fine... wish i had better cpu's tho lol.. i cant get them above 3.8GHz ive seen on the Evga forum that a few people have managed it.... but i just cant get her to post above 200bclkb
wish i could afford THESE
as there super cheap compared to the others on ebay
i dont have more pics atm as she isnt finished ive just got a temporary radiator in but i cant find any screws to fit the fan mount holes so there tie wrapped on and it looks awful
__________________
Old 17th Sep 2012, 19:30   #19
TaRkA DaHl
I *am* a Dremel
TaRkA DaHl's Avatar
Couple of 5620's have sold for 200 even on the bay, night not be a big expense to get them if you were lucky.
Unfortunately, more have sold for around 70.
Old 17th Sep 2012, 19:33   #20
Slowlemon
Multimodder
Hi Kirk
I am not very familiar with LGA1366 systems. To get to 3.8GHz are you running at 190 x 20? I should think that`s pretty good for E5620s, remember this is folding, it needs to be stable 24/7. The X5650s would be a good choice, save up some money and upgrade later on .
__________________
Fold till it hertz.
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
