Reply
Thread Tools View Mode
Old 2nd Nov 2012, 16:59   #41
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
AWESOME build mate, I soooo need to get building my sim and I like the mods you done to your G25, my gearstick is getting slack so I need to strip it down and sort it
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - EVGA GTX 980Ti | Alienware 13 Laptop, i7, Dual M.2 SSD's, 16GB and Graphics Amp
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 3rd Nov 2012, 14:37   #42
Fifas
Minimodder
Fifas's Avatar
Fifas has yet to learn the way of the DremelFifas has yet to learn the way of the Dremel
Thanks mate!
One more update
Today I'm working on this:
But It isn't working as I planned
The serial communication isn't working that well, so the program in the video it's only a simulation.
Also, the 7-segment display needs to be changed. I bought a Common Cathode one and the store send me a Common Anode. Only noticed when turn the board and the display went on holidays
Fifas is offline   Reply With Quote
Old 3rd Nov 2012, 20:03   #43
XNine
Modder
XNine's Avatar
XNine has yet to learn the way of the Dremel
Good lordy! Keep it up, this is fantastic!
XNine is online now   Reply With Quote
Old 3rd Nov 2012, 21:08   #44
Fifas
Minimodder
Fifas's Avatar
Thanks mate!
Old 5th Nov 2012, 23:34   #45
Fifas
Minimodder
Fifas's Avatar
One more update!
Changed the 7 segment to the correct one, a little programming, and the board is working!
Did a quick video with my phone:
More news soon
What do you think?
Old 6th Nov 2012, 15:10   #46
that_du^de
give your head a wobble
that_du^de's Avatar
that_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpit
fifas the keys to start the car m8! so i can take it for a good thrash
__________________
mozart tx case(11x120mm fans),intel i7 920@4ghz(20x200)1.28v,asus rampage extreme 2,6gig corsair ram(3x2gig),2xati hd5870 crossfire,titan fenrir hsf,enermax revolution 1250w psu,1x120gig ssd 4x1tb hdd,x-fi elite pro soundcard,dell 2405fpw 24"lcd,zboard merc k/board,cyborg rat 7 mouse,win7 64bit
that_du^de is offline   Reply With Quote
Old 6th Nov 2012, 15:13   #47
Fifas
Minimodder
Fifas's Avatar
Oh...I think i get it now
Old 12th Nov 2012, 10:54   #48
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Nice addition.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 12th Nov 2012, 15:14   #49
Fifas
Minimodder
Fifas's Avatar
Thanks mate!
I'm designing a little case for the board now, and started the handbrake project :P pictures soon
Old 12th Nov 2012, 16:05   #50
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
very nice build...
i want to make one for my man cave...
as for the mdf.. yea mdf + water kinda sux... there is sealed mdf that will soak up less liquid... for your future builds.
kinghong1970 is offline   Reply With Quote
Old 12th Nov 2012, 16:07   #51
Fifas
Minimodder
Fifas's Avatar
Thanks man
the new "base" was made using a "water resistant" MDF, that I really don't know the name But I really hope I don't need to test if it really is water resistant
Old 18th Nov 2012, 00:36   #52
Fifas
Minimodder
Fifas's Avatar
Hey guys!
So, yesterday i did some progress in the "extras"
Found this little box, and that gave me an idea ...So started drilling
And a little more dremmel work
Glued a switch in the inside with some PVC (This is only a prototype, so I didn't work in small details)
The found this cable management tube...Perfect
Cutted and drilled, and started assembling
And finally...
..put some tape in it, just for the bling and boom. my new handbrake
It's connected to an old gamepad board. I will make a nice PCB for it, and remove that cable coming from the inside
What do you guys think?
Old 18th Nov 2012, 13:24   #53
Sissilisko
Multimodder
Sissilisko has yet to learn the way of the Dremel
it's still a bit rough looking but i believe in you that it will look great! :P
one thing is bothering me, will it be strong enough if like you're friend or somebody will use force when using it like in real car?
Sissilisko is offline   Reply With Quote
Old 19th Nov 2012, 01:14   #54
Fifas
Minimodder
Fifas's Avatar
Yes, this is not that good looking, but it's a "prototype"...
It can take some force, but I will make it even stronger in a new version.
Just one thing, this will be a "Rally Style" handbrake, next to the gearbox, not on the side of the seat
Old 4th Dec 2012, 23:39   #55
Fifas
Minimodder
Fifas's Avatar
Sorry for the lack of updates guys. Just a quick update.
I painted my "Handbrake Prototype"
And placed it
Tomorrow will likely post some final pics of the build. I want to make some new stuff, and update the hardware, but that will take some time, so I'm finishing here the project. Maybe later, when I get a job I'll make some updates.
Thank you all for all the support! Thank you all for the MOTM nomination. I would not have done it without your support!
Old 7th Dec 2012, 16:56   #56
Fifas
Minimodder
Fifas's Avatar
Here are some final shots of the complete build. Hope you like it!
Only noticed the plexi off it's place in the photos :P Sorry
One more time, thank you all for your support! Really appreciate it!
Old 10th Dec 2012, 14:16   #57
Fifas
Minimodder
Fifas's Avatar
Hello again guys!
My project is on Cooler Master Competition. Can you show your support?
http://www.coolermaster.com/scratch2012 ("Simodd Project by Rui Leite (Fifas) from Portugal")
Thanks
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
