#1 |
I unsuccessfully then tried again
GTX660
Looks interesting...!
Mini review later
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 |
#2 |
pew pew pew
Especially as interest as these were supposed to be OEM cards only?
__________________
i7 3770 | Asus RoG Maximus V Gene Z77 | 8GB 1600Mhz Vengeance | Crucial M4 256 & 128GB | Corsair H80 + Gentle Typhoons | Corsair AX750 | EVGA GTX 780 SC 3GB | Xonar DX | Silverstone FT03 |
#3 | |
There looks to be two versions, the GTX660 OEM is a GK104 chip, whereas the retail version runs on the GK106 chip, albeit with less shaders (perhaps the GK106 is efficient enough to not feel the cut in the amount of shaders? Not sure).
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 Last edited by kenco_uk; 7th Sep 2012 at 12:34. |
#4 |
GTX660 mini review
Mini review.
Wow, the 660 is a tiny card, in comparison to previous generations. As you can see from the pics below, against a 560Ti448 it's significantly shorter. One PCI-E power socket, two cooling fans, a single sli connector (no 3 way sli with this card folks). One thing to note, I had 301.42 WHQL drivers installed which I thought would carry across okay. They don't. I even tried the newer 306.02 WHQL drivers and they wouldn't recognise the card either. I had to use the included cd which had version 305.27 drivers. On with the benches! I picked a few that I had readily available, namely the CPC Benchmark 2007, just to see if the change made any impact on the system. Then I ran 3dmark2011. Once that had finished, I ran the Unigine 2.1 benchmark and lastly I ran the benchmark in Dirt Showdown. I'll tell you know, it's not all that impressive. I suppose it makes for a leaner, greener rig. I'm itching to see how this card overclocks though ![]() Here's a copy of the benchmark results in full: Custom PC Benchmarks Suite GTX560Ti448 Image editing: 1882 points. Video encoding: 3384 points. Multitasking testing: 1754 points. Overall score: 2340 points. GTX660 Image editing: 1897 points. Video encoding: 3233 points. Multitasking testing: 1703 points. Overall score: 2278 points. 3DMark2011 SCORE P6093 3DMarks with NVIDIA GeForce GTX 560 Ti 448(1x) and Intel Core i5-2500K Processor Version: 1.0.3.0 SystemInfo Version: 4.11 07/09/12 21:15:42 Id: 4329098 Graphics Card NVIDIA GeForce GTX 560 Ti 448 Vendor Unknown # of cards 1 SLI / CrossFire Off Memory 1280 MB Core clock 800 MHz Memory clock 2200 MHz Driver name Driver version 8.17.13.142 Driver status FM Approved Graphics Card Intel HD Graphics 3000 (i5) Vendor Unknown # of cards 1 SLI / CrossFire Off Memory 0 MB Core clock 850 MHz Memory clock 0 MHz Driver name Driver version 8.15.10.2761 Operating system 64-bit Windows 7 (6.1.7601) Motherboard MSI Z77A-GD65 (MS-7751) Memory 8192 MB Module 1 4096 MB Crucial Technology 9 @ 667 MHz Module 2 4096 MB Crucial Technology 9 @ 667 MHz Hard drive model 128GB M4-CT128M4SSD2 3DMark Score P6093 Graphics Score 5786 Physics Score 8038 Combined Score 6324 Graphics Test 1 25.15 FPS Graphics Test 2 26.3 FPS Graphics Test 3 37.18 FPS Graphics Test 4 18.41 FPS Physics Test 25.52 FPS Combined Test 29.42 FPS Default settings used Yes Edition Basic Screen Width 1280 Screen Height 720 Msaa Sample Count 1 Texture Filtering Mode Trilinear Max Af Anisotropy 1 Tessellation Detail 5 Max Tessellation Factor 10 ShadowMapSize 5 Shadow Cascade Count 4 Surface Shadow Sample Count 16 Volumetric Illumination Quality 5 Ambient Occlusion Quality 5 Depth Of Field Quality 5 Enable Window Mode Off Enable Vertical Sync Off Enable Triple Buffering Off Enable Wireframe Off Color Saturation 100% SCORE P6485 3DMarks with Generic VGA(1x) and Intel Core i5-2500K Processor Version: 1.0.3.0 SystemInfo Version: 4.11 07/09/12 22:38:59 Id: 4329632 Graphics Card Generic VGA Vendor NVidia Corporation # of cards 1 SLI / CrossFire Off Memory 2048 MB Core clock 549 MHz Memory clock 3004 MHz Driver name Driver version 9.18.13.527 Driver status Not FM Approved 3DMark Score P6485 Graphics Score 6397 Physics Score 8077 Combined Score 5444 Graphics Test 1 29.5 FPS Graphics Test 2 29.54 FPS Graphics Test 3 40.15 FPS Graphics Test 4 19.55 FPS Physics Test 25.64 FPS Combined Test 25.33 FPS Unigine Heaven Benchmark v2.1 GTX560Ti FPS: 59.0 Scores: 1487 Min FPS: 5.2 Max FPS: 131.6 GTX660 FPS: 61.0 Scores: 1537 Min FPS: 24.8 Max FPS: 130.9 Hardware Binary: Windows 32bit Visual C++ 1500 Release May 21 2010 Operating system: Windows 7 (build 7601, Service Pack 1) 64bit CPU model: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz CPU flags: 3300MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT GPU model: Intel(R) HD Graphics 3000 8.15.10.2761 2108Mb Settings Render: direct3d11 Mode: 1920x1080 fullscreen Shaders: high Textures: high Filter: trilinear Anisotropy: 4x Occlusion: enabled Refraction: enabled Volumetric: enabled Replication: disabled Tessellation: normal Dirt Showdown GTX560Ti448 Total Frames 2561 Average FPS 46.88 Minimum FPS 31.40 1920x1080, 16xQCSAA GTX660 Total Frames 2092 Average FPS 39.66 Minimum FPS 30.23 Basically, each one was run at default settings, no driver tweaking, no gpu overclocks. Pics showing comparison to 560Ti448. Nowhere near conclusive results. I'd presume some games would take better advantage of the newer silicon. Perhaps it's down to drivers. Also, by jiminy it runs quiet! The fans of the 560 were certainly discernable. I couldn't hear the 660 fans revving up at all while benching. That's quite a major achievement in my book as for too long now I've had cards that have been quite loud at times.
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 Last edited by kenco_uk; 7th Sep 2012 at 23:52. |
#5 |
Was that a warranty I just broke?
I would think a fairer comparison would be a 660 to a 560. The Ti 448 is relatively high-end compared to a vanilla 560. That would show better what a generation jump does
![]() Not bad results though even if not as good as you had hoped. |
#6 |
Ultramodder
Oh Ya. I 560 448 is basically a 570 yes? Which is two steps up from the 560.
But on the plus point, it is quite near the performance of a card that was 2 jumps in performance away from its predecessor. Which ain't to be sniffed at. This is in the public domain now then this card?
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | 7950w/boost WC | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | Cheap LG IPS
#7 |
The 560Ti448 isn't quite a 570 - it's not far off though and tbh with a little overclocking it does match a 570.
Unfortunately, it's the only card I've got available ![]() Tweaktown have had a review up for a few days. Looking at the results though, the 660 is either a little slower, matches and sometimes bests a GTX580! Unfortunately, they haven't posted their test rig as the 3dmark score is quite a bit higher than mine. edit: oc results so far.. 3dm11 SCORE P6832 3DMarks GRAPHICS SCORE 6746 PHYSICS SCORE 8069 COMBINED SCORE 6029 Using MSI Afterburner settings of Power % 105 Core +110 Memory +535 GPU-Z reports GPU Clock 1080 Mhz (up from 980 Mhz) Memory 1770 (up from 1502 Mhz) Boost 1133 Mhz (up from 1033 Mhz) Bandwidth has gone up from 144 GB/s to 170GB/s. Heaven 2.1 FPS 65.5 Scores 1651 Min 25.6 Max 142.1 Dirt Showdown Benchmark Total Frames 2448 Average FPS 45.95 Min FPS 33.48
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB dazzypops:Win8Prox64, i5-2500k@4.3, MSI Z77A-GD65, 8GB, 4TB, Samsung 840 Pro 256GB, 2 x MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1 Last edited by kenco_uk; 8th Sep 2012 at 22:48. |
#8 |
isnt really an ultramodder...
Kenco, do you know when this card will hit the shelves and how much for? Is it looking like the replacement for the 560 Ti? My friend is going to be building a new PC very soon but his budget can only stretch to a 560 Ti rather than the 660 Ti and I'm wondering if its worth him holding off till this card gets launched.
__________________
AMD Phenom II X4 955 @ 3.8GHz | Asus Crosshair II Formula | 8GB Corsair XMS2 DDR2 | EVGA GTX 570 SC & PNY GT 440 | Corsair Force 3 120GB | 1TB Seagate Barracuda | Enermax Infiniti 650w PSU | CM Storm Trooper | Creative Soundblaster X-Fi Platinum Fatal1ty Champion Series | Windows 7 x64 | Dell U2312HM primary (570), Samsung SM940BW secondary (GT 440) & Sony 32S3000 occasionally (570) |
#9 |
Multimodder
This card does look very interesting, i might get one if the price is right
#10 |
It was £197 something pence. There were only 10 available at the time. I'd seen the tweaktown review and thought it looked alright. I can't seem to match their results though, even overclocked so I wonder if they reviewed the OEM version that has the extra sharers. Bit fishy methinks.
__________________
#11 |
I Mod, Therefore I Own
does gpu-z recognise it?
__________________
i have a 3dfx voodoo5 6000 |
#12 |
Latest version does, aye.
__________________
| Thread Tools | |
