Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Sep 2012, 10:03   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Carbon Fibre - A Modders Guide
http://www.bit-tech.net/modding/guid...odders-guide/1
brumgrunt is offline   Reply With Quote
Old 10th Sep 2012, 11:50   #2
HandMadeAndroid
That's handy.
HandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the DremelHandMadeAndroid has yet to learn the way of the Dremel
Never really understood using carbon fiber for a computer case, it's a computer, not a racing car/fast hatch-back
__________________
i7 3770k, Asus P8Z77-I , 16gb Patriot 1866 ddr3,EVGA 670FTW, Bitfenix Prodigy,crucial M4 128ssd,western digital black 2tb storage, wacom intuos/ i7 sandy bridge kobalt 17" laptop,120ssd, 8gb crucial ram, 500gb7200 WD storage drive, nvidia 555m 3gb/64gb iPad 2
HandMadeAndroid is offline   Reply With Quote
Old 10th Sep 2012, 11:54   #3
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
It's another interesting material to use - why use stainless or turned Alu when just bent sheets will do? Why carve a case from wood when you could use plexi?
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 10th Sep 2012, 12:24   #4
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
It's a wonderful material to use, but is very difficult to work with also. The amount of precision required to mould carbon properly is really quite a task (used it myself for some similar tasks). Although I also believe that good design is also paramount for carbon. Carbon has the ability to form beautiful, flowing forms that seem to defy what the material should be capable of. But it also looks very messy when not done right. Personally, I've been following SSR-X since pretty much day one, and I really don't like the design. Given he went through all the trouble of moulding the stuff, I was surprised he went for such and angular, ungainly look? Obviously beauty is in the eye of the beholder, I just think the material's innate appearance wasn't really exploited at all in the build. This sentiment is why I would only use carbon if I knew I could get it 100% right, a real task, but worth it in the end.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 10th Sep 2012, 12:56   #5
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Trouble is that SSR-2 is meant to ape the design of the F-117A (and other stealth aircraft), so the angular, sharp shape is pretty much inevitable.
Carbon always seems like an exciting material to work with, although very tricky to get right!
__________________
Old 10th Sep 2012, 15:42   #6
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
I made a petrol tank with my mate for his custom motorcycle out of carbon fibre and can tell you its a bugger to get right and get a good finish on the finished articles
PingCrosby is offline   Reply With Quote
Old 10th Sep 2012, 15:59   #7
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming Saiyan
Congratz Dave Front page interview. I followed the build for what seemed like forever and I respect the fact that he took a chance and use a material that was not common to computer modding. He took a big chance in regards to expense when picking that material and I think it turned out great. Like the case looks or not you have to admit that he did an excellent job on it and the thought/creativity and precision that went in the build was 2nd to none. Great Job.
__________________
Deders - What if you touch yourself with kittens?
.//TuNdRa - Short of standing on a street corner (I'd make an ugly hooker, anyhow.)
i7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, MSI 660TI 3GB, BFG 260 GTX Core 216 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 10th Sep 2012, 16:18   #8
oliverr97
Multimodder
oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.oliverr97 is a hoopy frood who really knows where their towel is.
I don't understand why people would use carbon fiber, it seems to be a pain to use and is expensive and it doesn't even look to nice. But, i suppose for the one off mod, its seems interesting.
__________________
Cm Storm Enforcer|Intel i5-2500k|Asus p8p67 pro|8gb DDR3 Corsair Vengeance LP Blue1600mhz|EVGA GTX 460 1gb| Arctic Cooling Freezer 13 Pro|Corsair Force 3 60gb SSD|Hitachi 1tb Hard Drive| Windows 7 Professional|
oliverr97 is offline   Reply With Quote
Old 10th Sep 2012, 23:33   #9
Andy Mc
I *am* a Dremel
Andy Mc's Avatar
Andy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming SaiyanAndy Mc is a Super Spamming Saiyan
From reading up on multirotor stuff lately I have read that CF is also electrically conductive, is this right?
__________________
Andy Mc is offline   Reply With Quote
Old 11th Sep 2012, 02:00   #10
Cleveland216
Carbon Fiber King
Cleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the Dremel
@Andy From what I can tell, carbon fiber is not electrically conductive. It maybe on some real low voltage level, but, I haven't encountered anything of the sort.
@Mech Thanks for the support!
Cleveland216 is offline   Reply With Quote
Old 11th Sep 2012, 02:01   #11
Cleveland216
Carbon Fiber King
@krikkit Good Point!
@Ping Glad to hear you have worked with CF! Now time to start modding with CF!
Old 11th Sep 2012, 21:49   #12
Maki role
Maki role's Avatar
And this is where the design elements I mentioned really come into play. A shape like say a B2 Spirit or an SR-71 Blackbird (both very renowned stealth based aircraft too) would have probably been more sympathetic to the carbon. It is indeed a tricky one, as you may just be handicapped by the subject matter rather than your own ability.
__________________
Old 12th Sep 2012, 19:30   #13
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Might lack the showroom shiny shine finish most are used to with CF but it has the important strength & light weight properties which is more important than shiny shine, he done an awesome job on it, to get everything done perfectly is asking too much for an individual first timer on a large complex geometry build like this.
I look forward to the article on the project it'll be a gooden, think that should have come first before this light but nice intro to CF.
Congrats on the article Dave & I can stop calling you Cleveland now.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 13th Sep 2012, 13:16   #14
Cleveland216
Carbon Fiber King
@Waynio. Thanks for comments and support. I didn't coat the mold with clear coat before I put the Carbon Fiber in. That what most manufactures of carbon fiber parts do, like Ferrari. It adds weight, though, the real concern is air bubbles. Ggggrrr. From what I understand AutoClaving produces the best part possible.
Over at Composite's Central Forum, forum members would think you are crazy doing such a build complex carbon fiber like I did for my first time. I didn't care, it's either sink or swim, its what comes with the passion and dedication to break into new realms and fields, not only personally, but also on a community side.
We've seen multi-million dollar machine shop's produce custom computer cases on this site, though, never anything so intricate on a carbon fiber scale. Awareness is one of my main mission's! To inspire other modders to break into using composites. Time will tell.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
