#21 | |
What's a Dremel?
#22 | |
Minimodder
#23 |
Minimodder
So a little update on the project.
I have installed the two SSD beside the PSU since they could not be placed in the left side. But they fitted just fine beside the PSU: Also installed the two HDD with some anti vibration rubber. And as you can see I have also sleeved and shorten most of cables. Just need to sleeve the fan, temperatur and pump and then that's done ![]() And in this weekend the two windows will be made. And hopefully the last GPU arrives monday and then I will fill it up and boot it up
#24 |
Minimodder
As promised an update first with some big pictures of the case with the new windows:
Also made a hole to get the cables from the three fans in to the case :And some more Cable sleeving now that the other GPU has been placed inside ![]() And the two GPU fitted just perfect :thup: Really love the EK block with Pexi and nikkel. Looking forward to fill it up and see it with UV light ![]() Hope you like it. The back plate will be painted white and the RAM dimms blue to make it fit the theme. And then it should be ready to be booted
#25 |
What's a Dremel?
I can't quite see, but where does the water come out from the GPUs?
![]() The GPUs chosen for the back panel and ease of water cooling is pretty damn cool. There will be no space at all in there once you're finished. ![]() What sort of temps are you expecting? |
#26 | |
Minimodder
The water is coming in and out on the other side of these pictures (The inside of the case, see other post for pics). Well, the temps depent on the speed of the fans, OC and load. I expect them to be low, but how low, I don't now yet, but I will post it when tested |
#27 |
Minimodder
So lets tease a little bit more:
Last night I booted the baby up and it all worked just fine (only in the bios). So next step was to paint the motherboard and also the GPU back plate. First of the GPU's and the now white painted back plate: Now that's close for two GPU's ![]() Here the now white back plate: And with a bit more light: And then to the motherboard. Before: And then three hours later :wackosmil: So im just missing some UV LED and then this build should be done ![]() Tomorrow I will fill it up and boot it again. And friday the LED should arrive and then you will get some cool pictures
#28 | |
What's a Dremel?
That's a lovely GPU sandwich you've got there.
#29 |
Modder
niiiice Project.
Makes me thinking of ordering a X58 Shuttle, just for the board.. |
#30 | ||
Minimodder
I my situation this seems to be the only option, unless I made the tupe go on the out side of the window and then back in. Quote:
http://www.tomshardware.co.uk/shuttl...w-31569-3.html WHY shuttle WHY!
#31 |
Minimodder
But you have to order a X79 Shuttle for this Board :P
I love this project.
#32 | |
Multimodder
WOW those GPU look amazing, and yes I agree the board layout is not that pretty.
Anyway I really like this case and the space management look fantastic.
__________________
#33 |
Modder
#34 |
Supermodder
interesting build.
__________________
***gtek-computerdesign.com*** |
#35 | |
Minimodder
Thanks ;-) I have installed the last stuff, filled it up and is currently leak testing. And I must say, it is pretty awesome with the blue water inside ![]() But I like to tease a bit, so: Tonight (12-10-2012) at 21:00 GTM 0 You will get pictures of the currently final build (updates to the HW may come later on ).So hang tight, it will blow your mind |
#36 |
Modder
#37 |
Minimodder
So as promised (little late, sorry (problem uploading pictures))
![]() So I filled it up, and did some leak testing and there was a small leak. Luckly it was from a temperature plug that just need a bit of tighten ![]() But you really just want the pictures right ![]() I will try to take som more "show" pictures tomorrow. AND around the same time as today you will get pictures of the build with UV light! Which makes it look even more awesome
#38 |
Tetrep
Very nice indeed.
![]() ![]() Shame it required buying a system to be able to do it though, but if that's the only option then nice one, awesome system, only just fits in there. ![]()
#39 |
Professional Sleever & Modder
sooo sooo pretty
#40 |
Minimodder
So here is the pictures of the build with UV light on.
It is pretty deficult to take really good a UV picture (looks better in real life), I will try some more settings, but if any of you got some please share ![]() Maybe some more light around the build next time I cant show the GPU side without the side, since that where the LED strip is placed: But then it's good I got a window right Again it looks better in real life. So if you got any setup/setting for the camara (Canon EOS 7D) please let me know ![]() I have also just gotten windows installed on the Raid 0 with the SSD's. Iwill do some bench and post result along temps. And of course with som OC ![]() Got any bench program you like me to run? |
| Tags |
| build log, mod, prodigy, white, x79 |
| Thread Tools | |
| View Mode | |
