Reply
Thread Tools View Mode
Old 20th Nov 2012, 12:14   #21
fr0Zen
sabertooth 990FX
fr0Zen has yet to learn the way of the Dremelfr0Zen has yet to learn the way of the Dremel
I love the silverstone inspired hot air rises design element. The execution is over the top and overall quality
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing
fr0Zen is offline   Reply With Quote
Old 21st Nov 2012, 11:45   #22
ShinyAli
Supermodder
ShinyAli's Avatar
ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!
Thank you for all your comments, much appreciated
As you get near the end of a build and you stop and take a step back to look at what you have made I often find it surprising how it all happened, sometimes I can't really remember making some parts, it's like an endless reverie
ShinyAli is offline   Reply With Quote
Old 21st Nov 2012, 19:09   #23
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
really great build! and you are right about the conceptual sketches, the first thought i had was "ooh another alubar build, giant case no sides or really messy... but i was wrong! and i really like this chassis
A suggestion that i have is however that you dont put a knob that points out of the chassis side, i think it would look wrong! try to cut out a rectangular hole in the side and make a little handle thats folds out when you press at the top/bottom of the cutout, the turning point on the inside so all you'll see on the outside will be a flat surface.
kinda hard to explain, english is not my native language.... >.<
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 21st Nov 2012, 19:14   #24
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
I agree with that 100%.
Great work
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 21st Nov 2012, 19:38   #25
ShinyAli
Supermodder
ShinyAli's Avatar
Hi kelmannen, Your right, no sticking out door knobs As the doors are held shut by magnets and a steel plate I have an idea to use some even stronger Neodymium magnets set into a detachable door knob to pull the door open, It's an idea I had a while ago but forgot about...I need more magnets
Old 21st Nov 2012, 21:07   #26
kelmannen
Supermodder
good, i'm relived now
__________________
Old 2nd Dec 2012, 01:47   #27
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Really nice creation ShinyAli, looks a perfect layout & I'd say if not the best then at least amongst the best layouts I've seen for a regular ish form of case, love the way you access the insides too, wish I had space to add gas struts now, it's doubtful but of course I'll double check, still not totally sure how I'll be mounting mine, was going to go with a plug in place type system but gas struts are pretty sweet.
Looks awesome too.
Sure had no idea you was beta brain too.
Waynio is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
