Reply
Thread Tools View Mode
Old 11th Jan 2013, 11:30   #21
Zoubiey
What's a Dremel?
Zoubiey has yet to learn the way of the Dremel
Do you know it it's possible to keep the harddrive rack in the bottom with the pump ontop and use the same radiator setup? But except for the 140mm it will be a 120mm.
Right know I have a 240x47mm radiator home but I might have to buy a slim to get everything in, what you do think? Will also use DDC pump with EK-DDC X-Res 100 CSQ.
Zoubiey is offline   Reply With Quote
Old 11th Jan 2013, 13:01   #22
Chanc3
Minimodder
Chanc3's Avatar
Chanc3 has yet to learn the way of the Dremel
Looking great! used to have a prodigy myself but ending up selling it due to moving
Chanc3 is offline   Reply With Quote
Old 11th Jan 2013, 16:04   #23
saxovtsmike
Modder
saxovtsmike has yet to learn the way of the Dremel
It even fits with my slim 140 rad. Tried it but made no picture.
Itīs not helping as its too junky and would take too much place. As Iīm only using 2.5" drives (2x ssd, 1xhdd) it doesnt matter..
Played with my cam a bit and made some pics of my stuff..
I hope you enjoy ...
saxovtsmike is offline   Reply With Quote
Old 11th Jan 2013, 16:22   #24
Zoubiey
What's a Dremel?
I don't any 2.5" drives so I have to stick with the hdd cage. But thanks, now I know that I can order my stuff and get my rig watercooled!
Old 15th Jan 2013, 18:09   #25
saxovtsmike
Modder
Workin 10h a day doesnīt leave much time for modding when you have a Child too, but at least a little update.
First custom Cable done, easy start with the 8 Pin CPU
Changed the Plug to a connected 4+4, as the original Asus one was just two 4 pin plugs
Old 15th Jan 2013, 19:28   #26
saxovtsmike
Modder
As I donīt wanna start the 24Pin yet (it scares the Sh*** out of me because of the double Wires and the 2 plug mess) I started playing around with an optional front
Some more details on the front chapter, last things for tonight
Old 1st Feb 2013, 19:42   #27
saxovtsmike
Modder
Sadly not much of a progress on this build, RL and work keeps me buisy, so thereīs not so much hope to get any big progress in the before march...
But some final parts came 2day.
XSPC Raystorm CPU Block and a couple bottles of DP Ulra in Blue arrived.
Old 4th Feb 2013, 10:08   #28
saxovtsmike
Modder
Little update done to the build:
I mounted the Raystorm, gladly its backplate fits like a glove and no contact to the mainboard tray.
Drilled holes in the top for the offset mounted Radiator
Added the needed Breakthoughīs for the 2 Bitspower bulkheadconnectors to got to the external radiator via Kollance VL3n with G1/4 connectors.
I also made use of a spare powe/reset Button array of a V351 which will be mounted on the backside of the case left of the psu
So I can finally ditch the original io bracket of the Prodigy in the sidepanel.
Fluidwhise the decision was done too, I got myself 3 bottles of DP-Ultra in blue
Pics to follow.
Old 4th Feb 2013, 18:30   #29
saxovtsmike
Modder
Forgot to do all the needed holes in the top
Modded Back :
And the raystorm @ itīs new home
Old 5th Apr 2013, 17:11   #30
saxovtsmike
Modder
8pin + 24pin shortening and recrimping is done... My fingers still hurt
GPu Power is next. Blame me for the Boxed cooler, but as long Iīm not finished with the modifications on the case, it wonīt see water.
The front is allready de-riveted and rotated, but at it doesnīt clear enought, I need to rebuild the front complete to fit the Aquabay Res and AE5
Old 10th Apr 2013, 06:43   #31
saxovtsmike
Modder
After lots of pain swearing and other not so nice words I finally finished the replacement plug for the power switch & stuff to connect to the mainboard to be used with the buttons showed in #29 (lili V351 stuff)
Old 18th Apr 2013, 16:50   #32
saxovtsmike
Modder
After I got some crimps I could do the 2x6pin GPU power.
Came out not that bad, but I feel not the satisfaction I would like to.
When you look closer you will see where the new cables for the power switch will be routed.
Quite some space left in the case to add a waterloop..
Old 18th Apr 2013, 18:39   #33
saxovtsmike
Modder
while playin with my stuff , I stumbled across this layout...
Old 27th Apr 2013, 18:44   #34
saxovtsmike
Modder
still w.i.p status but weīr getting there
Old 27th Apr 2013, 19:45   #35
Pliqu3011
Opposing Coconut Reptile
Pliqu3011's Avatar
Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.Pliqu3011 is the Cheesecake. Relix smiles down upon them.
Looks great. Very minimalistic. Can't wait for the final result.
__________________
“Think not those faithful who praise all thy words and actions; but those who kindly reprove thy faults.” - Socrates
“Ὁ βίος βραχύς, ἡ δὲ τέχνη μακρή, ὁ δὲ καιρὸς ὀξύς, ἡ δὲ πεῖρα σφαλερή, ἡ δὲ κρίσις χαλεπή.” - Hippocrates
Pliqu3011 is offline   Reply With Quote
Old 28th Apr 2013, 17:11   #36
saxovtsmike
Modder
First drafts of Custom Sidepanels.
Will be mounted on the original points were the "bars" where mounted.
No Clue how to close the big window, ether full size perspex or a mix of venting slots or only slots...
Old 29th Apr 2013, 16:51   #37
saxovtsmike
Modder
Sidepanel fits
Now it can go into production, Next step => Window
Old 29th Apr 2013, 20:47   #38
Hukkel
Multimodder
Hukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the Dremel
Now that is some serious weight saving. Should defenitely add some FPS
Hukkel is offline   Reply With Quote
Old 30th Apr 2013, 20:01   #39
saxovtsmike
Modder
Getting hot air out of the case will be a task
Iīve really no big clue what fans I could use, so at the moment Itīs a mix out of Gentle Typhoons for the 240 Rad Blowing fresh air inside and Noisblocker 140mm Fan for the same task on the bottom mounted slim Rad.
Rear Exhaust could be a 140mm Fan (undecided) and in the front I can fit a 120mm fan to get heat out of the case.
At the moment Iīm quite lost as there is no real chance to get good silend fans ether Black or White to fit the theme AND beeing avaliable in 120 and 140mm fitment.
Equal choices would have been the new bionic Fans from Noisblocker, but therse donīt exist in 140mm fitment, and of course Corsairs Interchangeable color Ring Fans.
For 120mm they would even offer the Static Power ones for RAdiators and the Airflow ones as Exhaustfans, but sadly no Static Pressure one in 140mm fitment avaliable.
Well the Rad fan is hidden so only the rear exhaust would be visible, so nearly "corsair only" would be possible.
Anyone with a discont coupon from Corsair online ???
Final Sidebladedesign is done and went off to the lasercutter 2day, and I allready got a quote for both sidewindows. These alone will set me back for about 80€īs damn...
Will be in a color called 7C83, its Gray and light shines through, might come out quite nicely.
Some Prevew pics from the CAD proggy ...
That where the Windows...
To get the Front side done I had to think a bit but ended in a 3 Layer setup
Base Layer mounts to the Prodigy Front, and holds the Bayres and the Exhaust Fan
Middle Layer could be optional Perspex/clear acryl and could be treatenend with a led
Top layer is Cover with matching vents to the sideblade.
I could even Mesh them, well Iīll see
And a final pic of how it could look like when itīs done...
Old 30th Apr 2013, 20:32   #40
Hukkel
Multimodder
How about the Enermax Cluster fans?
Or noiseblocker eloops? Or are they only in 120mm?
And otherwise you will have to grab your spraygun
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
