Hardware Fractal Design Node 304 review
Discussion in 'Article Discussion' started by brumgrunt, 19 Sep 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. guvnar
    guvnar What's a Dremel?
    19 Aug 2010
    Aaaah SilverStone Sugo SG08 take note... price/size much closer!
  3. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Silverstone has a lot of other cheaper Matx cases.
    Looks like this is the case I'll go with. I was really unsatisfied with the SG02 I bought and ended up giving it to my stepfather to load his AMD fusion rig.
    Thanks bit-tech for covering all these cases.
  4. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Loving all the MiniITX coverage.
  5. Krikkit
    21 Jan 2003
    Me too.
    This looks like an excellent bit of kit, the PSU solution is a really good idea to let you use proper CPU coolers, rather than crappy low profile jobs.
    OT: Spelling mistake in the 2nd paragraph, first page, "bushiness" should be "business" methinks. Also, last sentence of the 4th paragraph should probably be "so read on" rather than "but read on".
  6. David
    7 Apr 2009
    No ODD = stupid, IMO, as mITX systems are popular as media boxes - it's a bit early to expect people to consign their BluRay drive to the spares cupboard.
    Also, does a mITX system need room for a 165mm HSF? There's easily enough room to design a slimline mount and raise the mobo 20mm.
    I'd rather buy the Prodigy and do something about the rattly panels.
  7. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    I still miss a closeup picture of how the HDD are mounted in that bracket.
    Would be a nice replacement for my home server which is actually housed in a A05NFB
  8. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    Me three
  9. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    I love this chassis.
    :D
  10. Lance
    Lance Ender of discussions.
    6 May 2010
    I like the concept, but I still want my disk drive. It seems that once I have a bit of cash it will be the SU08 for me, mostly because of the depth.
    Cheers for all the reviews.
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice one, but feel like a Jack-Of-All-Trade. No ODD, have to trade HDDs bay when long card is installed, big CPU cooler compatibility .... but few mobos allowing both big cooler AND GPU installed. I'd like to see a vibration test with all HDDs fitted.
    For a NAS, I think a PC-Q25 is best suited, with a nice low power cpu. Only 30€ deerer but it has hotswap capability, supports more HDDs and it has a smaller foot print.
  12. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    What options are for mounting the PSU?
    Upwards facing air intake of the PSU possible?
    Are there holes on the bottom for the PSU to suck cold air from beneath the case?
  13. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    yeah awesome reviews lately.. but i kinda love this case.. and would be the perfect home server i think, so i'll skip the HP NL40 and build my own!
  14. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Steel & plastic = partial demote...
    Would like to see a test with an AIO added...
    dunx
  15. Combatus
    16 Feb 2009
    It's pretty much facing down or nothing. The base has a vent and fan filter - sorry should have mentioned that in the review - and the cage has mounting holes for facing down only. As far as I can tell, you'd only be able to secure one screw if you have the PSU facing upwards.
  16. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    Is Bit-Tech nuh be writin' wit a Jamaican accent, mon? Yah intrestin' style choice, but I an I irie bwoy!
    Nuh, weh di lambsbread?
  17. Adnoctum
    27 Apr 2008
    Have the Bit-Tech offices been burgled? That is my theory on why the case looks like it has been fingerprinted by the police. What a fingerprint magnet!
    The lack of an ODD isn't such a pain for me. My MITX gaming system doesn't have one even though there is space for a slim drive, but I don't miss it because when I need to use a CD/DVD I can use a USB drive. If you are using the drive all the time, then it may be an issue.
    I think I'd be wary of the PSU and might err on the side of caution and get one that has an 80mm exhaust fan. This is due to two things in my experience: 1) PSUs with obstructed intakes get hotter which causes the fan to run faster, and 2) better quality PSUs with 80mm fans are no noisier than those with 120mm fans at a normal desktop power draw. Plus internal PSU airflow/cooling is better with a rear facing fan pulling air through the PSU.
    Lastly, my sense of aesthetics is mildly annoyed, but not offended, by the slightly curving slab front. I would prefer it if it was squared off and flat. Also I'm not thrilled by the switch/ports being on the side, I'd prefer them along the bottom edge, perhaps off-centred to the bottom right corner. But that is just me.
  18. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Nah, it's talk like a pirate day today. :D
  19. Chicken76
    10 Nov 2009
    Thanks for the clarification. I'm wondering how much clearance is there on the bottom of the case, as in how tall are the "legs"? If the PSU is starved for fresh air, its case will get warm and that will raise the temperature inside, especially with the fans on low speed, which is the setting most people will use.
  20. [EOCF] Tim
    [EOCF] Tim What's a Dremel?
    26 Oct 2005
    Seems close to perfection to me. Bitfenix has an identity crisis. IMO if you are going to build small it should really be mini ITX small. This fulfils all my requirements, and can be easily water cooled with thick single rad with dual fans. The HD bays are just genious. Air flow looks spot on. I find it hard to fault this case.
    Instant buy for me (as soon as I have the money for a new setup lol)
    And the removing of a drive bay is fantastic. I still need a drive now and then, and I'm getting a SATA to USB caddy with cheap 2nd hand slim laptop DVD burner. Blueray is for my Sony player, I'm not getting my PC to do that.
Tags: Add Tags
