Reply
Thread Tools View Mode
Old 30th Oct 2012, 19:19   #101
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
Originally Posted by Gtek View Post
Own brand new plasma or laser is not an option for me just now. I spend over 2 grand on my cnc already, but I was thinking about swapping spindle for plasma cutter. but I'm not very sure about the idea, tbh
If thats the case then the conversion could be relatively simple (assuming you have a bedded CNC like most DIY people make). Though I would imagine you might get a cleaner cut with laser over plasma (or that was the case in my professional experience). The other option you could take is investigating water jet cutting. I haven't put a ton of time into researching it, but I know the quality of cut can be top notch.
sixfootsideburns is online now   Reply With Quote
Old 6th Nov 2012, 01:36   #102
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.
On your site it lists it as a product - how much?
Could you make it a bit wider so I can fit a PCIe card in? A short PCB GTX 670 would be perfect
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is online now   Reply With Quote
Old 8th Nov 2012, 12:25   #103
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
hey Bindi
280 GBP including fans and DVD slot loader. There is no need to make it wider as Tenuis is designed to take PCI express card via 90 degree raiser (which I can supply). GTX 670 pcb will fit in.
however I'm not going to make any more of hand build versions, as I just cannot keep up with orders (I can still make one for you). Major part will by fabricated by contractor in future, but I don't now exactly how much will it cost yet.
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 8th Nov 2012, 14:42   #104
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
Incredible! I like it very much. Can you give us some pics of the inside with the components installed?
How difficult was the wiring - did you have to use wiring extensions?
Do you have internal USB ports for wireless dongles (keyboard, mouse, etc)?
I really like the stealthed drive and the hidden ports - well done!
Karrek is offline   Reply With Quote
Old 9th Nov 2012, 09:52   #105
Rgart
What's a Dremel?
Rgart has yet to learn the way of the Dremel
It's very nice...
And i decided to inspire to your project
I don't need of dvd player and don't put the botton and I/O in the top of tower for simplify the project but if you want you can give us a foto of the joint between wood and steal in the lateral face...
I don't understand how did you do it...
Rgart is offline   Reply With Quote
Old 1st Dec 2012, 21:46   #106
Gtek
Supermodder
Gtek's Avatar
sorry for late reply.
Thanks! I will post new set of photos, including internals soon. hopefully
Originally Posted by Rgart View Post
It's very nice...
Thank you. There is no wood on that photo, it's just aluminium chassis, but if you ask how I joined wood to alu, answer is that i simply glued it together, using Rhinobond. It's a PU adhesive, and it's really reliable from my experience. Here is a test bond, 5mm walnut + 5mm alu. It's almost impossible to separate them without using brute force, that would most likely destroy at least one of them . No chance wood panels falling off Tenuis or something
__________________
Old 21st Dec 2012, 19:43   #107
Gtek
Supermodder
Gtek's Avatar
Hi all. I took some fresh photos of another Tenuis, so I thought I could share them
__________________
Old 21st Dec 2012, 19:47   #108
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
SO MUCH GORGEOUS!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is online now   Reply With Quote
Old 21st Dec 2012, 19:57   #109
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Veeeeeeerrrrry nice.
Didn't know about the slide out piece for IO access, nice.
Waynio is offline   Reply With Quote
Old 21st Dec 2012, 20:39   #110
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Ooo I feel all warm and fuzzy on the inside when I see this
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 21st Dec 2012, 23:58   #111
theshadow2001
Ultramodder
theshadow2001's Avatar
theshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for president
OK, so this may be some kind of design sacrilege but if you scaled the dimensions slightly to fit a micro-atx mobo, such as a nice asus gene 5. You could totally put a watercooling loop in there and have a sexy gaming rig.
theshadow2001 is online now   Reply With Quote
Old 22nd Dec 2012, 02:54   #112
Mankz
________
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
In some of those shots it looks so good its almost a render
Mankz is offline   Reply With Quote
Old 23rd Dec 2012, 16:30   #113
Gtek
Supermodder
Gtek's Avatar
Originally Posted by KidMod-Southpaw View Post
SO MUCH GORGEOUS!
Thanks man
Thank you Wayne. I need to take a pick of the mechanism behind it one day
Thanks Nate
Yeah, some people asked me for microATX version, but... I'm working on completely new design for microATX system, so...
Thanks. Good to hear, because I'm rubbish photographer
__________________
Old 24th Dec 2012, 12:03   #114
abezors
Lurking since '08
abezors's Avatar
abezors has yet to learn the way of the Dremelabezors has yet to learn the way of the Dremel
Incredible, I had not seen this until the MOTY nominations (you got my vote of couse!).
I was just going to see if you were selling these pieces, then saw plenty of discussion here already. IMHO £280 odd is a great price for something this well crafted that would likely last upwards of 10 or 20 years in a house before looking outdated. Have you tried different wood types? Black stained oak is a personal favourite (but perhaps all-black would be a bit much).
If you were looking to go public and sell multiple numbers of these I would suggest approaching a high-end audio store such as one of the Bang & Olufsen franchises (or maybe somewhere like Richersounds), as this is the kind of thing that would appeal to these customers. These shops often like having interesting window displays...
Stunning.
abezors is offline   Reply With Quote
Old 26th Dec 2012, 12:30   #115
MiNiMaL_FuSS
There be Cows.
MiNiMaL_FuSS's Avatar
MiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run CrysisMiNiMaL_FuSS can run Crysis
I've voted this for MOTY, so elegant, well done.
You could build and sell the barebones cases, I reckon the demand on this forum would be very high if you came up with an easier to build/slightly dumbed down version!
__________________
すべてのあなたのチーズケーキは私たちに属している[/size]
MiNiMaL_FuSS is offline   Reply With Quote
Old 26th Dec 2012, 20:59   #116
abezors
Lurking since '08
abezors's Avatar
A kit for buyer to assemble? Good idea, potentially cheaper too.
Old 26th Dec 2012, 21:10   #117
Gtek
Supermodder
Gtek's Avatar
Thanks guys!
Different woods, I can do mahagony, but I don't really like that wood. Black stained oak is very nice, maybe with combination with silver, or polished alu, but I would have to find supplier who can do 5mm thick boards... cheap.
When It comes to other variations of Tenuis and other form factors, I'm working on 34mm thin-ITX version with options of i3, i5, i7 desktop chips and up to 16GB 1600 memory, as I see a lot of potential in this new form factor. other than that... miniITX desktop/barebone version? I don't
know... maybe
Self assembly. Would be possible if there was no wood
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
