#1 |
WIIGII!
bit-tech Staff
Raspberry Pi gets 'Turbo Mode' support
Overclocks to 1GHz and enables overvolting, without sacrificing your warranty.
http://www.bit-tech.net/news/hardwar...rry-pi-turbo/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#2 |
I *am* a Dremel
SO 1080p with doulby surround should play fluid now?
__________________
PC: Silverstone TJ08B-E, 2500K, Corsair H80, 120GBVertex 3 MAX IOPS,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711 PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1 |
#3 |
I like wood ಠ_ಠ
I just got the USB cord for my Pi last night. It's pretty good but browsing the internet can be a bit slow with the CPU is loaded at 100% all the time just because you have two tabs open
. I wasn't expecting a lot for $35 but it's still pretty sweet.Hopefully this should help
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
#4 | |
WIIGII!
bit-tech Staff
Turbo Mode will help by giving the system an overall speed tweak, but it won't be pleasant to use until (unless) an accelerated driver is provided.
__________________
#5 | |
I like wood ಠ_ಠ
__________________
#6 | |
WIIGII!
bit-tech Staff
![]() | | V
__________________
#7 |
I like wood ಠ_ಠ
I've done sum stuff in Ubuntu setting it up to be mom-proof, hopefully this pi will help me learn even more
__________________
#8 |
jack of all trades
Shameless plug is shameless. Only you "forgot" to provide a link Mr. Halfacree.
Hopefully the bugfix will allow 24/96 output to a USB DAC without artifacts/stuttering... |
#9 |
I Mod, Therefore I Own
I still want fullHD blu ray playback at 40mbps without stuttering. Please.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
#10 | ||
ARM Evangelist
My warranty was already gone when I tried overvolting about a month ago
. I still can't achieve much over 850MHz though... My power supply is a lot better than the last one I tried, but I still can't rule out the possibility that it might be struggling under load. The test points now read ~4.8v/4.9v, as opposed to ~4.6v with my last power supply, but that was measured at idle; I'll have to test it under load, I guess. I'll give this new firmware a shot first though. 1GHz is the goal, but if I can get to 900MHz stable then I'll be happy!Quote:
![]() Quote:
The Pi can only use the CPU to decode audio, so anything at 5.1 or over will likely make the Pi struggle, even with an overclock. The solution is audio passthrough. And bear in mind that it was never designed to be a $35 HTPC; the fact that the GPU can handle 1080p video is purely a bonus.
__________________
What's that? You don't care about my site? I don't care that you don't care - I'm going to spam you with the link anyway. Why yes, I do have a YouTube channel on which I put out Minecraft videos on a somewhat "regular" basis, thank you for asking. |
#11 |
I like wood ಠ_ಠ
Get this PSU, not a phone charger
http://www.adafruit.com/products/501 5.25V 1A is nice if you want a stable RPi or want to OC. I can do 1000Mhz easy but I haven't pushed it any further
__________________
#12 | |
ARM Evangelist
__________________
#13 |
WIIGII!
bit-tech Staff
Not if you've got signatures switched on, I didn't...
__________________
#14 |
Gimp dog!
With the keys available for MPEG2 playback and this update, it's nice to see the RPi moving on. All we need next is for audio decoding to be "discovered", and the tiny HTPC world is conquered!
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse |
#15 | |
I have a surround receiver for the audio decoding so that shouldn't be a problem. Though all of my BR rips are uncompressed 40gb *******s.
__________________
#16 | |
ARM Evangelist
My ripped copy of Avatar was exactly the same: just a 40gb file dumped from the disc. I can only play that over a gigabit network, even on a "proper" PC; not even 5GHz 802.11n WiFi can cut it... There'll be a new release of RaspBMC soon (RC5.0) which will incorporate the new "Turbo" mode. Will be interesting to see how much difference it makes. That's the one thing that bugs me about using the Pi as a media centre: the interface is quite laggy, and you can forget about any other skins bar the default one... XBian seemed faster, but I've since learned (amidst all the GPL kerfuffle) that this is because XBian uses a faster overclock than RaspBMC.
__________________
#17 |
No disassemble!
What does the overclock do to the Pi's power requirements? Should we be making sure it is getting a guaranteed 1 Amp?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|240 UT60 |
#18 |
Minimodder
I remember when "Turbo Mode" was a button for swapping from 33mhz to 66mhz.
WHOAH TOO FAST!
| Tags |
| arm, arm11, armv6, bcm2835, broadcom, overclocking, overvolting, raspberry pi |
| Thread Tools | |
