Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Sep 2012, 10:48   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Razer announces Game Booster beta
It's IObit's Game Booster, but... boostier?
http://www.bit-tech.net/news/gaming/...game-booster/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 21st Sep 2012, 11:12   #2
Byron C
This space for rent.
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
disabling a series of non-critical processors
I sure hope it doesn't disable processing cores! Think you mean processes there
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 21st Sep 2012, 11:13   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Hah! Yes, yes I do. Fixed, ta!
__________________
Old 21st Sep 2012, 11:37   #4
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
I'm highly sceptical of any software that claims to boost the performance of your pc.
theshadow2001 is offline   Reply With Quote
Old 21st Sep 2012, 12:26   #5
bigc90210
Teh C
bigc90210's Avatar
bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.bigc90210 is the Cheesecake. Relix smiles down upon them.
Same, hows about BT gives it and some similar "game fps boosting" software a run down to see if its worthwhile? I cant imagine it making much of a difference tbh
__________________
Asus Maximus VI Extreme, i7 4770k @ 4.7GHz, EK Supremacy, Custom Triple Rad Loop, 32GB (4x8gb) Crucial Ballistix Tracer 1600Mhz 1.5v, 3 x W/C Titans in SLI, 2x500gb Samsung 850 RAID 0, 2x2TB WD Greens in RAID 1, Corsair 540, Logitech G19, Razer Naga Molten, Razer Vaspula, Razer Kraken, Leap Motion, Double 27" 2560x1440p Dells, 4k Acer G-Sync,
bigc90210 is offline   Reply With Quote
Old 21st Sep 2012, 14:16   #6
Phalanx
Needs more dragons and stuff.
Phalanx's Avatar
Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.Phalanx is the Cheesecake. Relix smiles down upon them.
The logic of it makes sense, if you watch the video. However if your machine isn't being taxed on the resources it free up already, then you'll see no difference. I'm in the beta for this and I can definitely see the benefit of it for people. Not for myself, but then I still want to contribute to the beta.
__________________
XBOX Live!: Ph4lanx | Steam: Catachan
I'm an author! ChrisDamico.co.uk
Phalanx is offline   Reply With Quote
Old 21st Sep 2012, 14:42   #7
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
I used to have Game Booster installed. It definitely freed up lots of memory. Not sure I saw any benefit though. The best part was when it classified Steam as one of those "non-critical processes" and stopped it running until you set it as one of the things to ignore.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 21st Sep 2012, 16:34   #8
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
I'm sure older systems would see some benefit from it but a modern gaming box shouldn't need it.
GravitySmacked is offline   Reply With Quote
Old 21st Sep 2012, 17:49   #9
Showerhead
Ultramodder
Showerhead's Avatar
Showerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run Crysis
Yeah it's more for awfully weak systems. It makes skyrim playable as opposed to a slideshow on my gfs laptop which has 2GB ram a 2.6Ghz dual core and some awful 4 series integrated intel graphics.
Showerhead is offline   Reply With Quote
Old 21st Sep 2012, 17:50   #10
suragh
Derp
suragh's Avatar
suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.
Downloaded it and tried to use the FPS overlay but it didn't work - 100% garbage
__________________
i5 4670K - MSI 7970 Lightning - ASUS Maximus VI Gene - Fractal Design R4 - Dell U2412 x 2 - Samsung 840 256GB - 16GB RAM - Xonar DGX w/ T40s - EVGA 850W
Steam: Louis - Origin: Grexthor
suragh is offline   Reply With Quote
Old 21st Sep 2012, 19:13   #11
digitaldunc
Hypermodder
digitaldunc's Avatar
digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.
I vote bloat.
I have a 395 byte batch script that kills any random unnecessary processes.
Any self respecting geek should have disabled unnecessary services and startup guff anyway.
__________________
Event-horizon: i7 2600K @ 4.5 @ ~1.3v | 16Gb Corsair Vengeance @ 1866 9-10-9-24-2T | 2 x 580 1.5Gb (SLI) 772/1002 | Asus P8P67 Deluxe | Crucial M4 256Gb | Spinpoint F3 1TB | Corsair HX1000 | ZM-MFC1 Fan controller | XSPC Dual res | 2 x DDC 18W | Black ice stealth 360 | ThermoChill PA120.4 | EK Supreme HF Nickel | 2 x EK 580 Plexi | 7 x Scythe Gentle Typhoon 1450RPM | Modded TJ07
digitaldunc is offline   Reply With Quote
Old 21st Sep 2012, 19:35   #12
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
I used to have an Acer Travelmate laptop, awful thing with 256MB RAM, 1.5GHz processor, IGP. To get a few more FPS in most games I went into task manager and force-killed many of the running processes including explorer.exe - this actually worked quite well, so I imagine IOBit's software does too.
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 21st Sep 2012, 23:05   #13
CowBlazed
Supermodder
CowBlazed has yet to learn the way of the Dremel
So if it disables all non critical processes, does it disable itself before launching the game as well?
CowBlazed is offline   Reply With Quote
Old 22nd Sep 2012, 14:29   #14
ajfsound
Multimodder
ajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpitajfsound is almost as Godly as yodasarmpit
Lol - yes I actually did.
ajfsound is offline   Reply With Quote
Old 22nd Sep 2012, 14:54   #15
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
For people still running ancient Vista systems with old dual core tech
Star*Dagger is offline   Reply With Quote
Old 22nd Sep 2012, 19:40   #16
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
It probably works. AMD had an app of a similar nature floating about the web a few years back. In full boost mode it crippled various bits of Windows. The result on my old PC was a 20-30% effective boost in CPU power, but at the cost of zero security features. I just disconnected from the internet and made sure to switch the app off and restart the PC before going online again. Not something I'd want to use nowadays though.
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 23rd Sep 2012, 23:35   #17
Ninja_182
Enginerd!
Ninja_182's Avatar
Ninja_182 has yet to learn the way of the Dremel
Bring back game specific boot disks!
__________________
Athlon X2 4000+ @ 19.7GHz
Ninja_182 is offline   Reply With Quote
Old 23rd Sep 2012, 23:56   #18
aramil
One does not simply upgrade Windows
aramil's Avatar
aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.
It has been a while since I had to make one of those.
Although that is sort of what I do with DosBox.
Sent on my CM10 JB powered i9100 by TapaTalk 2
__________________
System: Intel i5 3570K delidded CLU @ 4.4Ghz | Asus Stabertooth Z77 |Palit GeForce GTX 980 Super Jetstream 4Gb | Samsung 840 EVO 250Gb | Samsung 1Tb F2 | WD 1Tb | Corsair 750TX v2 | 16Gb (4x4) Corsair Vengence | Corsair K90 Keyboard | XSPC-Raystorm-750-RS2400 | Zalman MS800 | AOC 27" 2560x1440 | Windows 10 Pro 64bit | Linx10 Tablet ED: CMDR Aramil Lorrathain Become a Star Citizen get 5,000 free Credits HERE
aramil is offline   Reply With Quote
Old 24th Sep 2012, 00:02   #19
The_Beast
I like wood ಠ_ಠ
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Razer....
.....no thanks
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Reply
Tags
game booster, gaming, iobit, iobit game booster, pc gaming, razer, razer game booster
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
