#1 |
Multimodder
Remote Desktop using Xrdp
Hi All
For those people who prefer using a graphical user interface to typing commands into an unforgiving black console, I have found a very user friendly way to access Ubuntu 12.04 from a Windows PC. Ubuntu includes a VNC program called Vine, Windows remote desktop uses RDP. A program called Xrdp enables them to talk to each other so you can use Windows remote desktop to access your Linux folding rig. There is a good guide here. Read the guide because it explains how this works but you do not need to do all the steps in the guide. I did not bother with the VNCserver implementation, I just used Vine. Vine is already installed on Ubuntu 12.04 so the only thing you need to install is Xrdp. Code:
sudo apt-get install xrdp .I hope this makes sense.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. Last edited by Slowlemon; 24th Sep 2012 at 06:52. Reason: Correction |
#2 |
Hypermodder
Alternatively you could install the TightVNC client on windows.
#3 |
Thinking about which mod to do 1st.
Thanks for the heads up!
__________________
#4 |
Another CPC refugee .....
+1 for for TightVNC - been using it for years - really easy to use when X11vnc is installed under Linux.
#5 |
Multimodder
Hi All
As I see it Xrdp has two advantages. 1. You don`t need to install any software on the Windows machine. This may be useful for some people, say you want to check on your folding rig from a computer at work. 2. I am told the RDP protocol is better or faster than VNC. This setup uses RDP over the network and only converts to VNC locally.
__________________
Fold till it hertz. Desktop: Core i7 3770K, Asus P8Z77-V, 2x GTX560ti, Corsair HX850 PSU, Windows 7. Workstation: 2x Xeon E5-2650, Asus Z9PE-D8 WS, Corsair HX650 PSU, Ubuntu 12.04. |
| Thread Tools | |
