Old 23rd Sep 2012, 10:48   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Opteron back online
Had to reboot the server for a problem with my TV card and when it powered back up I got the 5 short and 1 long beep.
Unformtunately away from home so cant reseat the DIMM's and nobody in the house who is able to either.
Edit:
I let the server cooldown and then got me bro to pull the power leads for 10 minutes. When he put them back in it started up ok.
I guess the memory fault is due to the temperature the sytem gets to. *shrug*
__________________
Folding stats
Folding Summary
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX Titan X Pascal; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 24th Sep 2012, 09:25   #2
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyankirk46 is a Super Spamming Saiyan
glad its back up and running Scorpuk
__________________
3770k @ 4.8GHz, GTX980 OC'd, Custom loop,
kirk46 is offline   Reply With Quote
Old 24th Sep 2012, 13:36   #3
Scorpuk
Hypermodder
So am I.
Picked up an 8102 and getting a TPF of 11m.
Also MythTV is back up and recording programs.
__________________
Folding stats
Folding Summary
Old 24th Sep 2012, 14:07   #4
kirk46
Cheesecake Nom Nom
kirk46's Avatar
I noticed!
Sent from my BlackBerry 8520 using Tapatalk
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
