Old 24th Sep 2012, 10:34   #1
Lambo_uk
What's a Dremel?
Lambo_uk has yet to learn the way of the Dremel
Xeon Server Folding Set-up
Guys,
I currently have a couple of XEON Servers fol;ding away for me, However as i normally only us a single processor machine am not sure the best way forward with these.
They currently have server 2008 R2 on the using the V7 client with 16 cores enabled for folding (they need to do some less stressful normal work to)
So what is the best way to set these up. The older guides all suggest 2 clients (1 per Physical CPU) but with the V7 Client this dowes not appear to be overly simple (unless it is just the "add" button on the adv and expert modes of course but only seems to show as one client in HFM)
Any ideas would be much appreciated
Matt
Lambo_uk is offline   Reply With Quote
Old 24th Sep 2012, 20:28   #2
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.DocJonz is a hoopy frood who really knows where their towel is.
You only need to run one client these days, and it uses multiple cores automatically, so the default setup of v7 does most of the work for you.
Depending on the speed of the processors, you might want to add one of the -bigXXX flags (XXX being 'adv' for 'big advantage' and 'beta' for 'big beta', though the latter is really designated for official beta testers ....)
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 25th Sep 2012, 09:17   #3
Lambo_uk
What's a Dremel?
Cheers Doc
helps a bit as all the info i have found seems to be around V6 clients
For BIGADV what is the minimum processor speed or is it around cores?
All the machines are 24 cores total 2 @ 2.53Ghz and 2 @ 2.8Ghz
Again apologies for nooby questions is new ground for me
Matt
Old 25th Sep 2012, 21:20   #4
fuus
Confessed Rep Addict
fuus's Avatar
fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.
http://folding.typepad.com/news/2012...v-rollout.html
16 cores minimum from what this says!
__________________
:: i5 3570k :: EVGA GTX 670 :: Z77X D3H :: 8GB RAM :: 800W PSU :: Filco with Browns :: 23' 1920x1080 :: 19' 1440x900 :: Microlab FC360 ::
GiffGaff
fuus is offline   Reply With Quote
Old 25th Sep 2012, 22:19   #5
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
Sorry to say Bigadv is only available on Linux at the moment so you will have to settle with running the v7 client on server 2008 but with the v7 client you will pick up the A4 cores and they will give you a 10% bonus
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 26th Sep 2012, 21:39   #6
Lambo_uk
What's a Dremel?
Cheers Guys,
Was just wondering what to do with a 4p Opteron box I have....
The CPU's only run at 2100Mhz though so may not up to it (although is 32 cores)
Just need to get it up and stable that's all
Matt
Old 27th Sep 2012, 16:36   #7
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
Originally Posted by Lambo_uk View Post
Cheers Guys,
Matt
Give it to me?
Few questions first:
Is this to be used solely for folding?
Are you comfortable with linux?
If yes to both, then the following is a step-by-step for putting on Ubuntu and the Kraken:
http://rog.asus.com/forum/showthread...bigadv-folding
TaRkA DaHl is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
